2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions F22 coding cheat sheet
      06-13-2014, 12:57 AM   #1
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
Put together a cheat sheet for the F22....
If you have corrections or additions let me know....
https://docs.google.com/spreadsheets...f=true&sd=true
Last update: 6/27/2016
READ IMPORTANT NOTES:
1) NEVER click "Code Default Values" it can reset important stuff and car might not start and need to get towed to the dealer to fix the software
2) Make sure you click "Code FDL" and not "Code" (clicking code will reset the car to the factory setting erasing all the FDL coding for the selected ECU)
3) Always code with the car running or with a commercial grade charger connected to it, else voltage might drop during coding and you could get unexpected errors. (if you are codding the DME ECU you can't have the car running so you will need a charger)
4) Launcher note: E-Sys Launcher Car Series MUST be set to exactly match the car's chassis type you are coding (e.g. F01, F06, F07, F10, F12, F15, F25, F30, F82, F83, etc.). If after install it defaults to F999 and it cannot be changed, change PC Date ahead 4 days, then change E-Sys Launcher Car Series, then change PC Date back to current date. DO NOT create .EST Token and PIN with PC Date advanced 4 days as the Validity Start Date for the token will be 4 days in the future."
What's Needed for coding?
Enet Cable search on ebay http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
E-sys software (http://www.bimmerfest.com/forums/sho...d.php?t=983244)
E-sys Installation step-by-step BMW - E-Sys Installation Procedure.pdf
NEW: Free universal token option http://www.bimmerfest.com/forums/sho...d.php?t=805745
my cheat sheet :-D https://drive.google.com/file/d/0Bwv...ew?usp=sharing
NEW e-sys integrated cheatsheet for E-sys launcher 2.4 http://www.2addicts.com/forums/attac...8&d=1444581337 (remove .pdf extension and replace with file on launcher installation folder)
NCD CAFD tool http://www.bimmerfest.com/forums/sho...d.php?t=749668
Whatever you do never ever ever press "Code Default Values" ... you have been warned :-)
Coding 101 video
E-sys Launcher 2.4 Integrated cheatsheet
Now you can just tick the checkboxes with the codes you want and they are applied automatically
How to VO code
Connect => Read FA => Activate FA => Read SVT (VCM) => Right-Click on ECU you want to code i.e. HU_NBT (the ECU itself not the underlying CAFD) => Select CODE.
Step by step VO code guide sample for TPMS decoding TPMS VO coding RPA or RFA (Country dependant).pdf
Corrupted CAFD
Just inject new CAFD into ECU, and VO Code it.
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
Read I-Level
To determine your I-Level, go to VCM Module => VCM Master Tab => click Read under I-Steps
List of ECU and CAFD id's to quickly find a specific ECU
E-sys_CAFD_ID's_P3.59_v4.pdf
Targets:
F001 psdzdata covers the F01/F02/F03/F04/F07 (5-Series GT is an F07 NOT an F10)
F010 psdzdata covers the F06/F10/F11/F12/F13/F18
F020 psdzdata covers the F20/F21/F22/F23/F30/F31/F32/F33/F34/F35/F36/F45/F80/F82/F83 (There is no Z4 F-chassis yet)
F025 psdzdata covers the F15/F16/F25/F26/F48/F85/F86
F056 psdzdata covers the F64/F55 F56 (Cooper Mini's)
I001 psdzdata covers the i3/i8
I-Levels
1 - I-Levels Through ISTA-P 3.59.4.pdf
File Type: pdf FA (VO) Step-By-Step (MWPos) 8-24-2013.pdf (1.05 MB, 8706 views)
File Type: pdf 141121 List of abbreviations and modules.pdf (44.5 KB, 8290 views)
Appreciate 30
doveer10.50
MASHCT625.50
Dav3948.50
SerenVoX146.00
hoyasaxa702.00
AndrewC198910931.00
///M Houbi1655.00
KjPerry17.50
koston37.00
Resoelg244.00
Kaan810.00
      06-13-2014, 02:12 AM   #2
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
Very happy to see you take the time and energy to compile this list for everyone. Again, I just didn't have the time or desire to do so directly. I find a coding feature I have used that is missing I will send it along to be included in your F22 Master list.
      06-13-2014, 06:45 AM   #3
MikeG12
Drives: 2020 X3M40, 2000 Z3M, 2017 X1
How do you open this or download to Excel?
      06-13-2014, 07:38 AM   #4
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
Thank you very much
Maybe put a last updated date on the sheet for fyi
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      06-13-2014, 07:39 AM   #5
soghetto
Drives: MY14 MG M235i 8-AT
2014 m235i  [10.00]
this will come in handy, thanks for taking the time and putting something together!
      06-13-2014, 07:42 AM   #6
soghetto
2014 m235i  [10.00]
CTRL+S should open the save dialog to download it where you want.
      06-13-2014, 07:49 AM   #7
bman6074
Drives: 14 M235i and 07 Lotus Exige S
Thank you. I get my car this Saturday and was looking to start coding my preferences. I want in my way lol like burger king "have it your way".
      06-13-2014, 10:27 AM   #8
pikcachu
pikcachu's Avatar
1403
Glad to be able to contribute...... I'll add date thanks for the comment
      06-13-2014, 10:42 AM   #9
pikcachu
pikcachu's Avatar
1403
k added date to file title
      06-13-2014, 10:53 AM   #10
bimmerbuff
Slightly Less Obsessed
bimmerbuff's Avatar
Drives: Between BMWs
Awesome. Thanks for putting this together!
      06-13-2014, 10:57 AM   #11
alz0rz
What goes here?
alz0rz's Avatar
452
Drives: 2019 G30 M550i
Curious about the ENABLE WIFI HOTSPOT entries.. can anyone enlighten?
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      06-13-2014, 11:19 AM   #12
pikcachu
pikcachu's Avatar
1403
what i read so far is that it allows connecting devices that suport DLMA to stream to the car.... but seems like you cant use it to share the internet of the car through the wifi
      06-13-2014, 11:20 AM   #13
pikcachu
pikcachu's Avatar
1403
can read more at http://f10.5post.com/forums/showthread.php?t=809017
      06-13-2014, 03:18 PM   #14
furii
Drives: 2014 m235i
awesome, thanks for doing this!
what's the difference between the green and blue entries?
      06-13-2014, 03:49 PM   #15
pikcachu
pikcachu's Avatar
1403
green is the ones confirmed to work... blue is unknown
      06-14-2014, 07:32 PM   #16
Oyinko
Drives: M235i
Have you find anything regarding the lights? They light the road a little bit too low. Would it be possible to change the setting?
      06-14-2014, 10:14 PM   #17
pikcachu
pikcachu's Avatar
1403
maybe
Xenon brightness Fembody 3050 HELLIGKEIT_FL_BIXENON
DRL brightness Fembody 3050 HELLIGKEIT_DRL
actually that looks like it's for the F30... can't seem to find it in the F22 cafs
      06-15-2014, 10:28 AM   #18
Jerich0
Love to Drive
197
Drives: X4 & M4
Could you please add the coding for the following:
Five blinks when changin lanes
Last setting remember auto start stop
Last setting remember air conditioning
Thanks!
JC
      06-15-2014, 12:37 PM   #19
pikcachu
pikcachu's Avatar
1403
Blink was already there line 18
Added 23 24 58
      06-15-2014, 01:37 PM   #20
furii
Drives: 2014 m235i
would love to see the amber lights disable added to the list
      06-15-2014, 02:12 PM   #21
pikcachu
pikcachu's Avatar
1403
Done... line 25-26
      06-15-2014, 02:15 PM   #22
darkerosxx
37
Drives: '14 M235i
Is one of these for mirrors folding in when turning engine off and folding out when engine turned on?
2addicts
