11-01-2015, 02:29 PM | #45 | |
Rep 18,795
What it was meant, "No way" in a shocking way, surprised by the law for making that illegal. And my mentioned that I have sold to some shop and end user in OZ, of course that doesn't mean that I am changing their law and making them legal. As for the unsprung weight etc, yes of course I do understand them. By adding that much spacer width, there is no negative effect to the car. As I said, it reacts similar as to adding weight to the car itself. So if you said that it will cause an affect to the dynamic suspension, you may not want to put any passenger or load to the car.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
11-01-2015, 07:23 PM | #46 |
Rep 5,066
I think 15mm Front, 20mm Rear would hardly affect the vehicle in a negative way..
What about aftermarket wheels that Tire Rack and many vendors who sells in various sizes, weights, different offset than stock? I've never heard of any car that got damaged due to spacers being added..
11-02-2015, 09:42 AM | #47 |
Rep 1,547
Or coilovers that read "off road use only"
11-04-2015, 10:29 AM | #48 |
Rep 208
I'll be installing my spacers on Friday. Should I apply antiseize to the rotor hat as shown in the picture? Should I just apply to the wheel hub where the spacer will rest, and then on the spacer hub?
Thanks |
11-04-2015, 10:46 AM | #49 | |
Rep 7,063
11-04-2015, 11:10 AM | #50 |
Rep 1,547
Bigb348, yep...exactly. If anything, that's a little more than I normally use when applying it. That said, I've had spacers on my A4 since '09 and have never had an issue with them ceasing onto the hub...maybe I'm lucky?
11-04-2015, 11:22 AM | #51 | |
Rep 7,063
But since the vehicle's still new may not have this issue but why risk it for a $8 bottle of anti seize
11-04-2015, 11:24 AM | #52 |
Rep 18,795
@Bigb348 wow, that's too much.
You only need to put it on the hub ring section.
11-04-2015, 11:38 AM | #53 | |
Rep 1,547
11-04-2015, 01:43 PM | #54 |
Rep 7,063
Oh deliveries from Ben at the office
11-04-2015, 03:05 PM | #56 |
Rep 208
11-04-2015, 08:16 PM | #57 |
Rep 173
Anyone who has the 15 front and 20 rear for a period of time? I'm concerned about whether spacing out the front wheels will cause damage to the rear door and side skirt/ quarter. Had that problem on my e70
11-04-2015, 08:33 PM | #58 | |
Rep 18,795
As for living in California, I don't have a problem with my side skirts or flares. I have one nick on my rear fender, I think it came off from another car kicked it off the ground.
11-04-2015, 08:34 PM | #59 |
Rep 422
does anyone know what are the H&R part numbers for the 15 and 20" spacer ?
also i assume new lugnuts are needed, what will the correct size will be ?
2023 I4 40 Msport White/red interior 19"Rims
2023 Ix 50 MSport Hraphite Gray.Oyster interios 22" Rims Retired 2020 X7 MSport 40i 2020 I3s Bev |
11-04-2015, 08:37 PM | #60 | |
Rep 18,795
11-04-2015, 09:23 PM | #61 |
Rep 422
Can you give me a quote for the set of spacers (front and baack) with lugnuts
11-04-2015, 09:43 PM | #62 | |
Rep 1,328
1. No Spacers 2. Cannot widen the track by 26mm (wheels, spacers, anything) |
11-05-2015, 09:31 AM | #63 |
Rep 1,547
My spacers and springs should be arriving soon, thanks Ben!
11-05-2015, 10:09 AM | #64 | |
Rep 7,063
11-05-2015, 10:53 AM | #65 | ||
Rep 18,795
Anytime stewy604 . Thanks for the business.
11-05-2015, 05:36 PM | #66 | |||
Rep 7,063
