10-30-2022, 03:25 PM | #1 |
Rep 1
14 xDrive 35i multiple error codes after battery disconnected
Hi there, disconnected my battery to replace the valve cover and oil cooler gaskets, now upon reconnecting it I get a barrage of codes. I've cleared all codes a few times but still am getting the following:
ECM (Engine Control Module - DME/DDE) 1 problems exist 1.101F01 Air Mass System, Plausibility: Calculated Air Masses In The Air Intake System Not Plausible ICM (Integrated Chassis Management)/RLM_2L (Tail Light Module, Inner Left) 1.48006F ICM: Rear Left Ride-Height Sensor, Measuring Voltage 2.48002C ICM, ACC: Interface DSC 3.D01B2A Signal (Actual Position EPS, 51.0.2) Invalid, Transmitter EPS ABS (Anti-Lock Braking System - DSC) 5 problems exist 1.4806AD ICM Interface: Steering Angle, Phase 1, Signal Invalid 2.4806AC ICM Interface: Steering Angle, Phase 2, Signal Invalid 3.4806CC ICM Interface: Yaw Rate Setpoint Value, Phase 1, Signal Invalid 4.4806CD ICM Interface: Yaw Rate, Setpoint Value, Phase 2 And 3, Signal Invalid 5.48078B ICM Interface: Steering Angle, Following Initialisation Phase, Signal Invalid EPS (Electronic Power Steering) 2 problems exist 1.48239C EPS Torque Sensor (Steering Angle Index): Index Faulty 2.D51A53 ICM Interface (Actual Steering Angle, Front Axle, 57.1.2): Signal Invalid KAFAS (Camera Based Driver Assist Systems) 2 problems exist 1.E06C43 Signal (Warning Object Coordination Status, 0x21F) Invalid, Transmitter DSC / ICM 2.E06C44 Signal (Warning Object Coordination Status, 0x21F) Invalid, Transmitter DSC / ICM Any insight on this? I'm at a loss on it. Thank you in advance. |
11-04-2022, 07:38 PM | #2 |
Rep 105
check this thread here, it might help: https://f15.bimmerpost.com/forums/sh....php?t=1683268
