11-04-2023, 09:32 AM | #1 |
Rep 31
Drives: F15 E60 911C4 SL560 66C10step
Sagging Right Rear Suspension
Hello everyone. I have a 2017 two row with DHP.
Right rear deflates after engine off Can hear compressor when car awakens but does not raise right rear Upon starting car right rear raises to normal and stays there while driving. 36K miles No codes. Checked other threads but nothing with my exact problem. Your thoughts and recommendations are appreciated. |
11-04-2023, 04:10 PM | #5 |
Rep 31
11-04-2023, 05:12 PM | #6 |
Rep 546
Airbag problem dude. Simple fix… search the forums. Plenty of topics on this.
Also, get under and check that your compressor is not cracked where it connects to the lines. It is plastic, and can break. I’d check this before you order new air springs though. If you get new ones, get the Arnott’s! |
11-05-2023, 01:23 PM | #7 | |
Rep 31
11-05-2023, 01:30 PM | #8 |
Rep 31
Any one else? Can I drive it this way? Cannot get into the dealer until end of November.
Seems like air bag right side. Any other ideas other than compressor connections? Thanks. Hello everyone. I have a 2017 two row with DHP. Right rear deflates after engine off Can hear compressor when car awakens but does not raise right rear Upon starting car right rear raises to normal and stays there while driving. 36K miles No codes. Checked other threads but nothing with my exact problem. Your thoughts and recommendations are appreciated. |
11-05-2023, 01:36 PM | #9 | |
Rep 546
It happened to me crossing a bridge… both went out… needless to say I was pissed and so were the people behind me 🤷🏽‍♂️ Just look at the curvature of the bags, where it folds back in… if it has that “dry rotted look” (like it can be a cheese grader) then your bags are bad. They should look smooth, with no rough surface if you understand what saying…. And if you post a picture of them, people here will be way more helpful too… |
11-05-2023, 02:20 PM | #10 | |
Rep 10,256
Suggest to buy Arnott's aftermarket air springs and find an indy shop willing to install them. |
BriceApp1.50 |
11-05-2023, 07:44 PM | #11 |
Rep 442
This. Order the airbags and find a local mechanic. Even one who doesn't know bmws should be able to swap them out. And for a lot less money than dealer.
11-07-2023, 10:15 AM | #12 | |
Rep 31
Is the bag a high probability??? I have a indy 1.5 hours away. I could have the bag drop shipped there for him to install but he's not that great at diagnosing problems. If it's not the bag, then I'm kinda stuck. If the bag is high probability then I am tempted to roll the dice. Roll the dice?????? |
11-07-2023, 10:47 AM | #13 | |
Rep 442
11-07-2023, 12:35 PM | #14 |
F15 daddymobile
2350
Rep 3,510
indy is 1.5 hours away? you could have both rear bags replaced if youre comfortable DIYing it. i did both mine in about 45min, but i've been wrenching for a while.
11-07-2023, 04:16 PM | #15 |
Rep 31
11-07-2023, 04:19 PM | #16 |
Rep 31
11-21-2023, 06:50 AM | #17 | |
Rep 31
Returning the Arnott but will loose money on the return. |
11-21-2023, 09:06 AM | #18 | |
Rep 611
My Diesel Information Thread | My Wheels, Tires, and Fitment Thread | My Teardrop Camper Build | My F15 Suspension Lift Thread |
shimmy232350.00 |
11-21-2023, 10:30 AM | #19 |
Rep 442
Yup. Almost guaranteed to leak at some point. Personally I would have just replaced them regardless.
11-21-2023, 11:44 AM | #20 |
Rep 611
Yep. I have two on hand at home. I bring one with me when we go on our overland trips. They are easy to replace, even when out in the sticks.
11-23-2023, 10:09 AM | #22 |
Rep 10,256
