      02-15-2023, 05:25 PM   #1
mike126
mike126's Avatar
Drives: bmw x5 50i
BMW X5 50i  [0.00]
want to mod my 50i brake
I really want to upgrade my 50i' brake! Any recommendation?
      02-15-2023, 08:21 PM   #2
jiggz
Drives: E90 M3|F15 X5 50i
https://www.getbmwparts.com/oem-part...b3J5IFBhZ2U%3D
      02-16-2023, 07:26 AM   #3
dentprotony@gmail.com
Drives: 2018 f85
Let me know if you are looking fir a budget-oriented big brake kit, i can get you on my list 👍
      02-16-2023, 09:05 AM   #4
RED_Y_
Drives: 2014 X5 3.5d
https://f15.bimmerpost.com/forums/sh....php?t=1464952
      02-16-2023, 11:44 AM   #5
mike126
mike126's Avatar
Drives: bmw x5 50i
BMW X5 50i  [0.00]
yes!that's what I am looking for.
      02-16-2023, 04:34 PM   #6
sukhk527
Drives: BMW X5 XDrive35i
+1 for the kit from dentprotony@gmail.com. Very happy with mine!
      02-16-2023, 04:58 PM   #7
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
50i huh? is Tony's kit much of an upgrade over your larger 50i brakes? I know you'll get better calipers, but the rotor sizes are about the same on his kit. With the BMWBK you get x5m sized rotors, but unfortunately still the lame clamp style rear caliper.
      02-16-2023, 05:31 PM   #8
djrabbi
djrabbi's Avatar
Drives: G05 M50i
I have a set of X5M calipers for $1750. You will need to get your own rotors and such
      02-17-2023, 09:13 AM   #9
Drives: 2018 f85
Very true, i often get asked to compare the 50i kit and my set up, so theres a few things id like to mention/compare between 50i and my kit first:
Size of the rotors is 374mm vs 365mm, weight 30.1 vs 31lbs. Rear rotors are the same but you get a larger pad surface and a full size monoblock caliper. So you are looking at a much larger pad in the front, aluminum hub, larger and lighter rotors readily available everywhere online, with excellent prices and fast delivery from rockauto. These kits are a significant bump in looks and braking performance/consistency, and is super popular with those who tow and take their x5 to the track. They look great and fill the wheel up very nicely.
Now on to the mperformance (old x5m set up) and my kit comparison:
Weight front 30.1 vs 36lb (f85) or 38-40lb (old x5m). Full cast like zimmerman are 40lbs+ which is a crazy amount of rotational weight. Rear weight difference is pretty major, given the size difference, i will get 50i rear rotor to know the exact weight for future reference.
Price: best fronts that you get with my kit cost 125 ea , rears are 50-60ea. There is much cheaper full cast front examples available. Mperformance EACH front disc is 360-380 (f85) front, and around 200-250 rear. Every time you replace rotors would be 1000+. My kit will be 400ish.
So is picking up a ballpark of 25-30lbs in rotational weight (pretty major imo) and cost difference of the parts (rotors/pads ) of at least 600+ worth the looks difference ? Not sure. I believe my kit to be perfect balance in cost, in what you ACTUALLY get, and what these brakes ACTUALLY are capable of, and when its time to replace pads/rotors , you dont stress where you can come up with 1100-1200 right quick and rather would spend the 600 different towards the rear tires for example.
Long story short, best thing you can get imo is f10 m5 set up in the front, and my x5m set up for the rear. Thats if money dont matter. You pick up a little weight but performance amd looks are outstanding. But id stay away from old x5m set up because of weight and cost, imo.
1norseman398.00
shimmy232350.00
Edwardsc1251.00
      02-17-2023, 02:14 PM   #10
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
does your f15 kit clear a 18" spare tire?
      02-18-2023, 10:26 AM   #11
Drives: 2018 f85
Rears yes, front clears the 19” spare (x5m 5 spoke spare), i was yet to find an x5 with a steel spare.
shimmy232350.00
      02-19-2023, 06:03 PM   #12
mike126
mike126's Avatar
Drives: bmw x5 50i
BMW X5 50i  [0.00]
20
      02-20-2023, 06:52 PM   #13
Drives: 2018 f85
20
My kit clears 19” and larger wheels, fills the wheels very nicely. Pm me and ill get you on my list if youd like to go ahead
      02-24-2023, 10:43 AM   #14
Edwardsc1
Edwardsc1's Avatar
Drives: 2015 BMW X5 50i
2015 BMW X5 50i  [0.00]
Man IMO the 50i stock brakes suck after any sort of hard braking. They start fading so fast, it's kind of pathetic haha I can't believe BMW chose to put single piston calipers on a 5,100+ lb performance SUV. Besides the irritatingly quiet exhaust, it's really the only complaint I have about the way it comes from the factory lol
2015 X5 50i - Current
2011 E92 M3 - Sold
2016 F30 340i - Sold
      02-24-2023, 11:24 AM   #15
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
Right!!! so what makes a bigger impact? bigger calipers (Tony's kit), or bigger rotors (BMWP kit)? I can see bigger rotors helping with that fade.
      02-24-2023, 11:31 AM   #16
Edwardsc1
Edwardsc1's Avatar
I'm sure a mix of both, but I think having the 6 piston calipers up front and 4 piston rear would be a huge improvement with dispersing that braking power over the rotors. Also would just be more efficient with fixed piston calipers all around instead of the sliding single piston.
2011 E92 M3 - Sold
      02-24-2023, 01:04 PM   #17
Clifton
Clifton's Avatar
Drives: Cars with tires
If fade is of concern, your biggest impact and cheapest mod is start by up'ing the boiling point of the brake fluid. For $20 you can buy DOT 4 race brake fluid with 600F boiling point. That will eliminate pedal fade since it will be difficult on the street to boil your fluid. Your pedal will always feel solid regardless of how hard you brake.
Next, step up to higher temperature pads. Since your upgraded fluid will no longer cook, your pads will need to be able to withstand higher operating temperatures since heat will transfer to a much more resilient fluid. Add a little bit of air to brake ducting wouldn't hurt either, something the M-sport package introduced in 2017.
Combine those elements, and a stock brake setup will be pretty much fade free, even with light track work.
Regards,
Clifton
shimmy232350.00
      02-24-2023, 03:07 PM   #18
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
anyone have pics of Tony's kit behind 21" wheels?
      02-24-2023, 04:59 PM   #19
Drives: 2018 f85
Very good point on stepping up to a proper brake fluid. @shimmy23 what brake fade are you experiencing, do you think it might be pad compound, or more like rotors getting hot and sort of glazing over ? Bigger rotor surface definitely helps, also bigger pad surface and proper compound helps greatly with the fade.
I think i have picture of my brakes behind 22” wheels
      02-24-2023, 05:26 PM   #20
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
I'm not experiencing any fade. Edwardsc1 mentioned it in a post above. I'd be upgrading brakes purely for aesthetic reasons... i just can't seem to decide between your kit and the BMWP kit. I'm running 21s in the summer and 20s in the winter. I'm curious to see how your kit looks behind 22's.
      02-25-2023, 11:05 AM   #21
Drives: 2018 f85
Something to keep in mind is both added weight and replacement cost. If you are after looks and money is not an object then I recommend f10 m5 front set up (400mm front rotors) and x5m rear rotors with my 4 piston monoblock calipers. Adding 10lbs per rotor from the mkit is kinda rough, you will feel it every time on take off or brake. Proper pads and tires with my set up will be more than plenty and still somewhat budget oriented. My set is super popular with guys who tow or track.
Attached is my front kit with 22s on e70 35d
      02-25-2023, 11:07 AM   #22
Drives: 2018 f85
Heres the same vehicle other side
