      02-02-2023, 12:38 AM   #1
///M_Martin
///M_Martin's Avatar
72
Drives: F85 X5M Edition Black Fire
Agressive/Flush fitment 22" wheels build thread
Hi ///M Fans
Now i will "build" 22'' wheels for my F85 X5M and looking for flush fitment and want some opinions from owners, which use 22" wheels.
The car is dropped with H&R VTF Adjustable Coilover springs may be will exchange with KW V3 for smooth ride and more adjustable options
In the moment i was use OEM 612M wheels + H&R wheel spacers:
Front 10x21 ET40 with 285/35 R21 + 15mm H&R wheel spacers
Rear 11.5x21 ET38 with 325/30 R21 +20mm H&R wheel spacers
New set will be with "Classic" specs:
Front 10.5x22 ET? 295/30 R22
Rear 12x22 ET? 335/25/22
The major problem of course is ET values for front and rear wheels
Now with OEM wheels/tyres and H&R spacers have this "room":
Front have over 13.5mm gap from the outer edge of wheel and inner edge of the fender
Rear have a 8mm gap from the outer edge of wheel and inner edge of the fender
After a lot of measure i thing FRONT will be ET20/25 for flush/agressive fitment
REAR will be ET13/ET15 for flush/agressive fitment
I attached some photos of the OEM wheels and how they sit on the car
Thank you in advance
      02-02-2023, 08:47 AM   #2
TexasRiderBMW
TexasRiderBMW's Avatar
Drives: BMW X5
I just picked up a set of 22s of the same size and I have 35ET/Front and 25ET/rear. Although I don’t have them on yet to show the stance. I am also not lowered (yet) and do not have big M brakes. These should be aggressive enough for me to not use spacers.
I’m sure others will chime in and see what they went with!
      02-02-2023, 09:11 AM   #3
///M_Martin
72
Thanks mate,but prefer more agressive look and need more low values of ET
      02-03-2023, 12:43 AM   #4
LOW4LYF
LOW4LYF's Avatar
2176
Drives: E92 M3 & F85 X5M
ET20 with 295 tire will be too aggressive.
      02-03-2023, 01:19 AM   #5
///M_Martin
72
Thanks mate!
All around will be ET20,how wide is wheels?
      02-03-2023, 05:23 PM   #6
LOW4LYF
LOW4LYF's Avatar
2176
Originally Posted by ///M_Martin View Post
Thanks mate!
10.5 & 12"
      02-03-2023, 08:47 PM   #7
mcanzio
mcanzio's Avatar
Drives: 2018 F85 X5M
2023 Audi SQ5  [0.00]
2018 BMW X5M F85  [0.00]
Hi there,
My wheel specifications are as follows:
Vossen Forged LC-104
22x10.5 Front - Offset ET 28
22x12 Rear - Offset ET 25
Suspension is KW V3 coilovers. Fits flush with no rubbing or issues.
musa423.00
      02-04-2023, 02:53 AM   #8
///M_Martin
72
Thanks guys,
Very helpful info will “chase” perfect fitment
      02-06-2023, 12:24 AM   #9
///M_Martin
72
Any another setup's on 22" to take a final decision
Thanks!
      02-21-2023, 09:36 PM   #10
Ryanx5m
Drives: 2016 bmw x5m
Originally Posted by mcanzio View Post
Hi there,
Interested in selling the wheels?
      02-21-2023, 11:57 PM   #11
shimmy23
F15 daddymobile
shimmy23's Avatar
2356
Drives: GS X5
i love 22s but i don't miss the butt pucker moments daily driving here in washington. so many potholes!
      02-23-2023, 03:41 AM   #12
///M_Martin
72
If you thing have a potholes in Washington, come in Bulgaria
      03-30-2023, 10:17 AM   #13
robbie2883
Drives: 550i M-Sport
Hi there,
tires look more square than stretched (which i prefer) what size tires did you use?
      03-30-2023, 11:53 AM   #14
Msondeck
Msondeck's Avatar
Drives: f85 x5m
2016 X5M  [0.00]
2024 M2  [0.00]
22s no spacers w springs
295/30
335/25
NYBulldog1312.00
      04-02-2023, 05:47 PM   #15
mcanzio
mcanzio's Avatar
As the previous post mentioned. I am also running 295/30/22 up front and 335/25/22 in the back.
Added a few more pics as well. 👍
      04-12-2023, 11:01 AM   #16
Influence
Drives: 2020 X3M, 2016 X5 35i
Warning for all of you. Do NOT run 295/30s with the 335/25s in the rear. It WILL lead to transfer case issues eventually. The overall diameters are just outside of the 1% limit.
I got about 25,000 miles with the combo before I started getting slippage at the front end. Luckily caught it in time but the transfer case fluid was black from all the clutch rubbing.
Solution is to run 285/30s at the front. The only issue is that the only tires available in that size are Michelin PS4S, so not exactly a cheap combo.
Just want to help you guys avoid a costly mistake.
shimmy232356.00
      04-12-2023, 02:53 PM   #17
JVX6M
JVX6M's Avatar
166
Drives: 2023 BMW M3 Comp
I kindly disagree with the above, maybe a random rare issue of some sort but I personally have done it 295/335 on both E70 and F86 for the last almost 10 years with zero issues…. Just my .02.
      04-12-2023, 03:06 PM   #18
LOW4LYF
LOW4LYF's Avatar
2176
Yep, correct.
Back in the day there was no 285/30-335/25 combo as the PS4S is still a fairly new tire.
I saw tons on issues in Germany with the 295/335 combo, maybe something to do with Autobahn speed?
      04-12-2023, 07:11 PM   #19
Influence
Diameter difference is almost 1.4% with the 295/30/22 335/25/22 combo, well outside the 1% limit of the transfer case. How many miles did you do in those 10 years between the two cars? Also, the clutch slippage is not that noticeable when it starts so many people never seem to notice. I didn’t notice it until about 5 years into my ownership (only ran the 22’s in the summer) with about 50,000 total miles on the car (26,000 of them with the big 22 295/335 combo).
But it’s your money. Just trying to help people before they run into an expensive issue. It WILL happen eventually. Highway miles may make it worse. You may have been one of the lucky ones.
      04-13-2023, 07:05 AM   #20
///M_Martin
72
Almost all people, which run on 22'' use 10.5J front and 12J rear for X5M/X6M specs and all of them use tire combo 295/30+ 335/25.
All calculators,which use in EUROPE allow this tire setup....
      04-13-2023, 07:20 AM   #21
Influence
You make a key point here. You mention X5M/X6M platform. I don’t know if there is a difference in the transfer case between the M’s and the regular X5/X6s.
I had the issue on my 2016 X5 35i and if you look through these boards you will see a LOT of regular X5/X6 owners who developed transfer case issues running the 295/335 combo. It also takes a lot of miles/years before the problems show up (probably even less time if the diameter difference were larger than the 1.4% of this combo).
Again, feel free to ignore the learnings/advice of the many experienced forum members as well as the BMW spec of less than 1% overall diameter difference front to rear. We are just trying to help you avoid a potential problem.
      04-14-2023, 05:10 AM   #22
///M_Martin
72
I thing this is great discussion because this is popular tire choice
I need to check and ask some BMW transfer case specialist here and write you have a difference between regular F15/F16 and F85/F86 (I thing is different)
In Europe have 285/30/22 Continental SC6 and new SC7 too.
If have another member which run X5M/X6M platform on 295/335 tire setup and have a transfer case issue to write here
