07-12-2022, 12:41 PM | #1 |
Rep 23
I've seen many forums talking about NBT ID4 CarPlay products they recommend adding to their F15 2015's, but I have seen no one mention this https://a.aliexpress.com/_mtqAg9Y is this a good product? Has anyone installed this into their F15 2015's?
07-12-2022, 01:59 PM | #2 | |
Rep 50
07-12-2022, 02:16 PM | #3 | ||
Rep 2,529
https://f15.bimmerpost.com/forums/sh....php?t=1616260 https://f15.bimmerpost.com/forums/sh....php?t=1646802 https://f15.bimmerpost.com/forums/sh....php?t=1621646 https://f15.bimmerpost.com/forums/sh....php?t=1513235 Last edited by RED_Y_; 07-12-2022 at 02:23 PM.. |
07-12-2022, 02:25 PM | #4 |
Rep 50
NBT Evo ID5/ID6 can have carplay coded without any hardware other than an antenna.
07-12-2022, 02:54 PM | #5 |
Rep 2,529
07-12-2022, 03:31 PM | #6 |
Rep 23
The device I linked has an antenna, but is similar to Andream device, what worries me is one of the cons on Andreams is: "Does not have a vented box like Joyeauto (potentially heat may cause issues)" so I'm trying to figure out if users have had issues with the device linked.
07-12-2022, 04:14 PM | #7 | |
Rep 247
I have the RoadTop version (an older one which at that time was a rebadged Andream) and haven't had any issues. I'd go with one of the bigger names (Andream, RoadTop, Carlinkit and Bimmertech) so you can get at least a few updates (or find them easier for the big names from here: https://f30.bimmerpost.com/forums/sh....php?t=1675929). Mr12Volt is supposedly releasing one for the NBT ID4 soon-ish. Their's is a little different in that the audio doesn't go through AUX but through the MOST bus (although, it sounds just fine through AUX for me). Bimmertech is probably the best supported but the most expensive followed by Carlinkit/RoadTop/Andream. Mr12volt seems to be well supported but will probably slot in between the other two tiers pricewise. |
07-12-2022, 05:05 PM | #8 |
Rep 17
i bought this instead of a box.
it have everything :-) 12" touchscreen Apple Carplay Google maps Google asistant, so you can just use voice command Youtube Spotify Idrive working Usb so you can use a harddrive with music and movies Well working like a Android tablet so you can download all the apps you want https://www.aliexpress.com/item/1005...04936413%21sea |
07-12-2022, 05:16 PM | #9 | ||
Rep 23
07-12-2022, 06:17 PM | #10 | |
Rep 247
xxxJAKOBxxx, I had looked at those, do you know if they use the internal mic in the unit or the oem bmw bluetooth setup for phone calls? |
07-13-2022, 01:15 PM | #13 |
Rep 50
08-19-2022, 05:35 PM | #14 | |
MAGA
39
Rep 159
Do you have any feedback on this since installing? Any pics or videos of it in use? Thanks! |
08-19-2022, 07:37 PM | #15 |
Rep 36
You can swap a newer nbt with an antenna into an older f15 and get carplay. I've done it on a few around me. If you want I can connect you with the guy that sells the newer nbt units vin coded to your car.
08-19-2022, 09:14 PM | #16 |
Rep 7
08-19-2022, 09:21 PM | #17 |
Rep 36
08-19-2022, 11:20 PM | #18 |
184
Rep 308
08-20-2022, 09:01 AM | #20 |
Rep 23
08-20-2022, 09:39 AM | #21 |
Rep 36
