      02-16-2024, 07:52 AM   #1
X5Brian
X5Brian's Avatar
873
Drives: 2017 BMW X5
Rear brake caliper
Is the rear brake caliper the same with all models? 35i, 50i, and X5M? I know the mounting bracket is different for rotor size … but the single piston caliper looks identical ….
      02-16-2024, 09:46 AM   #2
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
they're the same AFAIK
https://f15.bimmerpost.com/forums/sh....php?t=2051224
      02-16-2024, 08:16 PM   #3
_ObiJon
_ObiJon's Avatar
Drives: 2015 428i xDrive
I just did a 50i caliper upgrade on my 35i. Bought them used from eBay. The 35i calipers were stamped 44/20, while the 50i calipers were stamped 44/24. I didn't measure them, but I'm assuming the 50i (and M) calipers are slightly taller/thicker/whatever to accommodate the thicker 24mm rotor. However, they both share a 44mm piston.
      02-28-2024, 01:50 PM   #4
X5Brian
X5Brian's Avatar
873
Drives: 2017 BMW X5
So my 35i calipers won’t fit with M bracket ? Or will?
I’m
Trying to use my stock “44/20” rear calipers but change the bracket that came with the f85 set.
I don’t want to spend money and rebuild the f85 42/24 calipers….
Plan to go 4 pot in future …
      02-29-2024, 08:46 AM   #5
X5Brian
X5Brian's Avatar
873
Drives: 2017 BMW X5
So I would like to say, you were all wrong. I have car apart and guess what. Bracket doesn’t fit ….
Sliders won’t go in … they are slightly wider …
      02-29-2024, 09:31 AM   #6
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
post a pic please. I have a 50i and i thought the 35i had the same rear as that... my bad for telling ya wrong.
      02-29-2024, 05:27 PM   #7
X5Brian
X5Brian's Avatar
873
Drives: 2017 BMW X5
The sliders are farther apart on x5M vs 35i…
The caliper is also wider on X5M
