      05-09-2018, 09:36 AM   #23
perry8912
Drives: bmw x5
Originally Posted by menelaos View Post
When coding, can ignition be in any state?
Quite a novice!
I always start my car first before coding.
      05-09-2018, 09:40 AM   #24
menelaos
menelaos's Avatar
1226
Drives: 2015 BMW X5 F15
Originally Posted by Kzang View Post
If the mileage is passed the warranty threshold.
My car had a prior salvage title...all BMW warranties have been voided.
      05-09-2018, 09:41 AM   #25
mkdan2004
Drives: BMW X5 F15
Depends what option you use, E-sys or Bimmercode. Bimmercode recomends coding with the engine shut off, E-sys, it is recommended to use it with the engine running (to avoid running out of electrical power). There is also Carly but i have not tried it and do not know for sure how it works.
menelaos1226.00
      05-09-2018, 09:44 AM   #26
menelaos
menelaos's Avatar
1226
I got Bimmercode, so engine shut off also means ignition off too?
      05-09-2018, 09:47 AM   #27
mkdan2004
Drives: BMW X5 F15
No, ignition must be on. I also coded with the engine running, so it can be done. It will throw some errors that automatically clear up once you restart the car. Once its done and the car is restarted, everything should be ok (might need to setup clock again).
menelaos1226.00
      05-09-2018, 03:15 PM   #28
gt0279a
Drives: 2009 E90 335i
Dealer had to replace my steering column to fix this.
      05-09-2018, 07:16 PM   #29
menelaos
menelaos's Avatar
1226
Quite "encouraging"
      11-01-2019, 11:51 PM   #30
happydude
Drives: E92 M3 / F15 X5 35d
This just started on mine. No factory warranty but still have some time left on CPO warranty. Anyone know if this would be covered under CPO?
      11-02-2019, 08:40 AM   #31
menelaos
menelaos's Avatar
1226
I hope it does, but you will need to read the fine print.
      10-02-2022, 12:01 PM   #32
parthpatel1
Drives: 2015 X5 M Sport
Anybody recently code this to disable it?
      10-03-2022, 08:22 AM   #33
dr_greenthumb
Drives: 14' F15 X5 35i x
Just lube the steering column, I used a silicone based spray and it's quiet and works fine. Split the plastic column around the steering wheel and on the left side there is some gears and elbows, just spray them good. Worked for me, YMMV.
