      10-29-2023, 04:55 AM   #1
Frslam
Drives: E92 325i MSport
2014 BMW X5 F15  [0.00]
X5 F15 Brake upgrade
Hi, really hope someone can help me. I'm looking to upgrade the brakes on my F15 30D to (front) 6 pot M Performance Brakes and matching brakes for the rear. It's a jump in size for the Brake Disks. The vendor tells me I would just use the stock Brake Disk Backing Plates which are already fitted to my car. My question is - were the Back Plates all the same size? I'd be increasing the Disk size from 332mm to 395mm Front and 320mm to 385mm Rear. Many Thanks
      10-29-2023, 09:22 AM   #2
BeegBM
BeegBM's Avatar
I convert my brake kit as well and i have to change the back plate as well all stock has to come off
      10-29-2023, 11:00 AM   #3
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
I'm 99% sure the backing/dust shields are larger for the larger rotors. You could confirm this by looking up the PN on RealOEM. Do you mean X5M front calipers (6pot) or the M performance calipers (4pot)?
If you buy the MPBK, it comes with everything you need to upgrade to larger front calipers (4pot) and f/r rotors. Search up on the forum. There's lots of info posted on upgrading to either the MPBK or X5M brakes and the parts you need.
      10-30-2023, 05:04 PM   #4
dentprotony@gmail.com
Drives: 2018 f85
Contact me ill get you a full 6/4 set
      10-31-2023, 05:34 AM   #5
Frslam
Hi, I was looking at the M Performance Kit, it would keep things kind of standard in a way because it was an option for my vehicle and still listed as a retrofit package on Real OEM. But I've also seen (on EBAY) a full BREMBO Kit for F85/F86 (395mm/385mm Disks)with 6 pot callipers up front, minus the dust shields. I guess these would fit my F15 30D? Thanks
      11-03-2023, 02:24 PM   #6
Drives: 2018 f85
6 pot, brakes, f15, m performance
