      10-29-2015, 01:46 PM   #23
igorsvrub
Drives: X5, 40d
Originally Posted by stewy604 View Post
I would love to run amber turn signals in the rear. I've put the EU tail lamps in my A4 to have this...looks way better, and safer too IMO since its a colour differentiation over the red tail lamps.
      02-05-2016, 05:58 PM   #24
AHCPAX5
Drives: 2017 BMW X5 50i M Sport
Has anyone succesfully installed a rear fog switch on US spec F15/85? If so, please share details from soup to nuts and pics if you dont mind.
      02-06-2016, 10:46 AM   #25
MrTookies
MrTookies's Avatar
Originally Posted by wdimagineer View Post
Accomplishing what you want isn't possible without significant wiring, coding, and of course a set of European tail lights. Rear fogs also require a different switch.
wdimagineer opasha
Do you have notes somewhere or, DIY instructions, I would be interested in that.
      05-13-2016, 02:57 PM   #26
golovan
Drives: 2015 X5 35D
Originally Posted by PlayTookies View Post
wdimagineer opasha
Any comments on this?
I am moving to Germany and wanted to know how difficult it is to convert my car to European specs.
      09-29-2016, 08:46 AM   #27
jabba1900
Drives: N/A
Same here. Sorry to resurrect an old thread, but I'm getting frustrated trying to figure this out. Has been told by dealers both here and in Europe that it can't be done (or more likely - they don't want to do it). I've tried numerous independent shops, but same answer.
How and where can this be done? I get that it won't be easy or cheap, but I'm willing to pay the price!
      11-22-2016, 02:35 AM   #28
golovan
Drives: 2015 X5 35D
I am in Germany now and maximum what I could do with European rear lights was to enable rear fog lights when I press brakes. Can someone please share how to code or rewire US Spec car to get European rear lights work properly?
      08-16-2017, 07:02 AM   #29
AHCPAX5
Resurrecting an old- As I was washing my car an idea popped. So our F15s have two separate lamp housings,, one on tailgate and one on side panel. Both lamps will light up for brake and turn signal using the same red LED pattern here in the US. My idea is this- Can we disable the turn signal function on the tailgate- inner lamp housing? This way it will only light up as a brake light. The outer lamp will still retain both brake and signal function. This obviously is not a fix for those who want amber signals but neverthelss it can make it appear that we have a dedicated brake late in the inner housings. Hopefully one of our coders can have a Eureka moment on how to disable the inner turn signal.
      10-06-2017, 08:38 AM   #30
monkiboy
Dominican Republic
535
Drives: '17 x5 3.5i w/MPPK & MPE
just wanted to update on my 2017 f15 USA build i installed the euro switch and coded rear fog lamps successfully. i like it a lot and integration into the 6WB also swapped over with the OEM lamp light is very clean and i like that all the buttons on the lighting switch panel light up unlike on my f30 where it was dead unless you also swapped the panel.
retx117.00
      02-03-2019, 08:04 AM   #31
cpalacay
Drives: '15 M6 GC and '16 X5M
So euro switch, and then did you code the following?
REM Module
REM -> Mapping_Nebelschlussl_L_output: nsl_l
REM -> Mapping_Nebelschlussl_R_output: nsl_r
FEM_BODY
3060 NSL_Verbaut: verbaut
      02-03-2019, 08:34 AM   #32
monkiboy
Dominican Republic
535
REM Module
FEM_BODY
i can’t confirm as it’s been too long and don’t have the car anymore. reach out to okee at codemycar.com for all your coding needs. he is amazing.
      02-03-2019, 04:58 PM   #33
F15GorDe
F15GorDe's Avatar
Drives: F15d, F10
+1 ^^^^^
Okee is the go-to guy.
      09-06-2021, 10:04 AM   #34
JaviDrama
Italy
61
Drives: 2018 BMW X5 35i
REM Module
FEM_BODY
Did you ever figure out if these We're the 3 you needed to code?
2018 BMW X5 35i X Drive
2019 Honda Civiv Si coupe
2009 Yamaha FZ6R
      09-06-2021, 10:49 AM   #35
RED_Y_
Drives: 2014 X5 3.5d
It sounds right for rear fog lights, yes.
      05-04-2023, 01:01 PM   #36
mrfochon
Drives: X5 F15 M package
Folks
I shipped my x5 to Europe and trying to figure out how to change the back lights and enable amber signal.
I am not sure anyone was able to do it DIY. But I will be trying as it’s required to keep the véhicule here.
I have the parts. Can anyone give me a 5 - 10 steps to do ?
Much appreciated.
      05-05-2023, 05:03 PM   #37
RED_Y_
Originally Posted by mrfochon View Post
Folks
Much appreciated.
This was done,but you need new lights and change the connector pin out if I remember correctly.
UPD: Found the thread:
https://f15.bimmerpost.com/forums/sh....php?t=1699816
      06-10-2023, 03:48 PM   #38
mrfochon
monkiboy are your back light working properly when breaking ?
      06-12-2023, 05:36 PM   #39
mrfochon
Was able to code it all.
  1. Changed the nebleschluss L/R output to NSL_l and r
  2. Activated the nsl_cernait to verbaut (means installed)
  3. Turned off the blinken 2 H L/R output
  4. Turned off the brems (breaks) output as they were set to blinken (blinkers)
Now when I break the break lights are on.
All good, I think ! Not sure if the EU regulation requires also the fog light to be on.
I ll be told soon ..
      06-29-2023, 03:55 AM   #40
mrfochon
Which pin is to be switched ? Not sure I doubt the information.
Thank you for your help.
      06-29-2023, 05:57 AM   #41
chumbedi
Drives: BMW X5e40 (F15)
Giving picture of EU Backlight (German car, but EU should be all the same, they are different for US-Spec and attempt of coding to EU-Spec will not work.
Rear Fog light has different postion, above lamps coded seem to be using flashlights for emergency braking.
Next turn signal is white back-up light.
Funny thing about this, I really like US-Spec backlight, no amber light, but one is never satisfied what one has LOL
