03-02-2020, 11:30 AM | #1 |
Rep 12
Drives: BMW X5 F15 and X5 E53
OEM 2016 BMW X5 F15 Rear Tail Light Set US Specs - Shipment included in price
Rear Tail Light set off a 2016 BMW X5 40e US Spec - LOOKS BRAND NEW I imported my car from Canada, but due to the laws in Greenland, I had to convert the tail lights to EU spec (amber turn signal). The car had 26K KM when the lights were replaced with EU lights. I will ship the lights with Track and trace and shipping is included in the price. Last edited by Taatsi; 03-05-2020 at 09:59 AM.. |
03-02-2020, 11:53 AM | #3 |
Rep 12
I ordered European rear taillights from Schmiedmann. I installed the lights and got amber turn signals without coding but amber lights also worked as brake lights. I got no error. I had no red brakelights at all.
With bimmercode i code PDC MAPPING_BREMSL_1_L_OUTPUT and MAPPING_BREMSL_1_R_OUTPUT to 00. This will disable yellow light as brakelights. Then code MAPPING_BREMSL_2_L_OUTPUT to nsl_l MAPPING_BREMSL_2_R_OUTPUT to nsl_r. This enables fog lights as brakelights. Now rear turn signals are amber and brakelights red using fog lights. With my brothers help we looked at the wiring for taillights. The inner lights in the US car has 5 wires but the EU lights has 6. One of two red wiring on the lights was not connected at all. That is for the brake lights. So we connected this red wire to the green wire on the lights which is connected to fog lights. No error and now the inner brake lights work. For the outer taillights we had to push the harness a bit down and up to access the wiring and connected the same green wire from inner lights to the red wire on outer lights to make the outer brake lights to work. The wiring from inner to outer lights is along the tailgate. Now everything works but where the fog light also is brakelight. But that is okay. Last edited by Taatsi; 03-03-2020 at 09:24 AM.. |
03-02-2020, 12:36 PM | #4 |
1636
Rep 2,995
Thanks for the info. I'm guessing there needs to be an additional wire run from the light control module to the lights to do a factory style conversion? Seems like it would be a lot of work. But looks like you found a solution that works.
By the way, are there many bmws in greenland? Is there even a dealer there? |
03-02-2020, 12:47 PM | #5 |
Rep 12
I tryed to look on forums on how the conversion could be done easily, but yes you´re right, the wiring from control module to the lights were missing so there was not a easy way round. In addition to use the rear fog light as brake light don´t look weird. There are few BMW´s here in Greenland. There is no dealer here, which is a shame, because the car, expecially X5 looks to be in their right conditions here in the cold arctic. :-)
03-02-2020, 04:55 PM | #6 | ||
Rep 1,025
Drives: Mein F Fünfundachtzig Einhorn
03-02-2020, 05:29 PM | #7 |
Rep 12
The two red wires were on the EU spec inner lights. I connected both red wires on the green/red wire on the blue harness. This is fog light. Then connected a long wire from this green/red through tailgate directly to red wire on the outer lights. Nothing is connected to the black harness. Hope that makes sense. On both harness you showed is the missing wire the one for brake lights which for EU spec lights are wired alone.
Kraftwerk AG460.00 |
03-02-2020, 06:21 PM | #8 | ||
Rep 1,025
One more thing: on the black plug, which pin is used? 2, 5 & 6 are not used on mine. This will come in handy when I get my Euro's. Thanks!
03-02-2020, 06:25 PM | #9 |
Rep 12
The difference is that you dont have to rewire when EU spec car wants US similar lights because all the wiring is done. They have all 6 wires on their blue harness to each type of lightning. They just has to code it.
03-02-2020, 06:33 PM | #10 | |
Rep 12
03-02-2020, 06:58 PM | #11 | ||
Rep 1,025
03-04-2020, 10:01 AM | #12 | |
Rep 12
You can´t receive PM - Sashok87
05-01-2020, 06:36 AM | #13 |
Rep 12
BUMP
05-12-2020, 06:49 AM | #14 |
Rep 12
New price
09-15-2020, 02:31 PM | #15 | |
Rep 12
05-06-2023, 01:28 AM | #16 |
Rep 627
Drives: X5 F15 M package
Hey guys
Thank you for the info. I am in the same situation where I need to make the change. I got the lights a it don’t understand the wiring update needed. I see there is a difference in the number of wires in the plug. But what did you do to add the missing one ? Also how did you remove the inner light ? Thank you |
Tags |
f15 parts, led light, rear lights, tail light |
