09-03-2023, 11:06 AM | #1 |
M Performance Class ;)
51
Rep 204
Recommendations for front lip F15 M sport
I had OEM BMW front carbon fiber lip on my X5. I used two sided tape to hold it in place.
It has been 3 years and the lip finally got lose and ripped off on the highway. I want to replace the front spoiler with something that can be secured better. Any recommendations? I am looking for something aggressive like the OEM X5M front lip and prefer carbon fiber. Thanks for any help in advance! |
09-03-2023, 12:13 PM | #2 | |
F15 daddymobile
2350
Rep 3,510
RW makes the 3d lip rep. that looks pretty good too.
09-03-2023, 01:30 PM | #3 |
51
Rep 204
Yep used 3M Auto molding tape the strongest one. I applied it ever where I could plus some extra spots. Over time it gave away and I reapplied it. Same results every time it somehow pulls down. It has to do with force that is applies at the front of the car at high speeds.. Only seems to happen on the highway going 85+ mph. Looking for a front lip that screws in instead. I have one on my Tesla that was well designed and hold no issues even at 120mph.
09-04-2023, 12:14 PM | #4 |
F15 daddymobile
2350
Rep 3,510
i hope i have better results. i also applied 3m primer for better adhesion. to clarify, it's pulling off the bracket and not the bracket from the bumper?
09-05-2023, 07:51 AM | #5 | |
51
Rep 204
I am considering this on as replacement appears to have good number of screws. https://ninteshop.com/products/for-b...=4011543111282 |
09-05-2023, 08:16 AM | #6 |
Rep 5,066
I would get the OEM front lip again and install using betalink adhesives which is the correct way to install this lip from OEM. The 3M adhesives will fail. Has failed on me multiple times even with the bracket and screws. I now have my lip installed with the adhesives and its not moving at all.
09-05-2023, 09:46 AM | #7 | |
Rep 297
09-05-2023, 10:04 AM | #8 |
175
Rep 303
Was looking at this one myself, are the bolts pre drilled or do you have to kinda eyeball it and make it up as you go?
09-05-2023, 05:16 PM | #9 | |
51
Rep 204
I wanted to get one thats CF or CF look. The Ninete one I posted appears to have quite a few holes I assume it requires drilling which IMO is superior to 2 side tape or using a combination of the 2 would be much better. I am going to reach out to company to see if they can give me better details. |
09-05-2023, 05:19 PM | #10 | |
51
Rep 204
09-05-2023, 09:52 PM | #11 | |
Rep 299
I want to attempt fixing the carbon piece, but I also need to replace the original mounting pieces as one of the bracket got torn off. Does anyone where I can just get the mounting gears?
09-06-2023, 05:58 PM | #12 |
Rep 297
Holes are pre-drilled. The surface where the tape goes is pretty well defined too. Pretty easy install, I left the plastic film on the tape, mount the lip up without fully tightening the bolt, then remove the plastic film when the lip is in place then tighten up the bolts to make full contact.
09-06-2023, 06:44 PM | #13 | |
51
Rep 204
Edit ordered the Ninte CF look one as they said it is held in by screws. Will post some pictures once I install. Last edited by PanthersFX; 09-10-2023 at 09:12 AM.. |
11-05-2023, 09:27 AM | #14 |
51
Rep 204
Following up on my Tread with pictures in case it helps anyone.
Just to recap had OEM M Front Lip. Came off on the highway had to be ripped off the car. Decieded to go with something that bolted in better. So far happy with the look and its installed tight, not worried about it flying off at 90MPH. |
11-05-2023, 10:11 AM | #15 |
F15 daddymobile
2350
Rep 3,510
nice! that looks pretty aggressive. would you say it hangs down a good 2" or so below the bumper?
11-05-2023, 02:29 PM | #16 |
Rep 187
Drives: 2013 x5 m57
I feel your pain. I had a 435 that I RIVETED a front lip to and it made it less than a week with a trip up to 105mph and it blew apart. I’ll never run a lip again.
11-05-2023, 05:44 PM | #17 | |
51
Rep 204
I did have to do some thinking and re-engineering the install though. It did not come with any instructions and felt like the screw count vs # of holes was off. There are 4 pieces. the middle bottom piece looked like it would not stay in place so I used multiple bolts and nuts. Everything is is screwed in with self tapering screws on the bottom of the bumper. I went out of the way to add 3M VHB tape in addition on any part connected to the bottom bumper. I would be shocked if this comes apart like the OEM M spolier its bolted in well. |
11-08-2023, 08:26 AM | #18 |
Rep 1,760
It's too bad that the X5 lips do not wrap around the bottom part of the front bumper like my old e92 front lip. I was thinking about purchasing a front lip but with all of these stories of them flying off or getting damaged at what I believe is ok fast speed (90+), I'm hesitant now to pick one up next season.
2015 BMW X5 35i M-Sport (White/Brown) - 4/16/18 (Current)
2011 BMW 550i M-Sport (Jet Black/Cinnamon Brown) - 4/30/14 | 2007 BMW 328xi e92 (Jet Black/Coral Red) - PAST | 2005 Infiniti G35 Coupe (Ivory White/Stone) - PAST | 2005 Acura TSX (Obsidian Black/Black) - PAST | 1998 Acura Integra (Black/Black) - PAST |
11-11-2023, 08:57 PM | #19 | |
Rep 2,633
