12-29-2023, 05:05 PM | #1 |
Rep 496
Well, looks like at almost 125k miles my injectors need replacing. Keep getting “bank 2 lean” when I give it a good amount of throttle.
For those of you who have replaced your injectors, any special tips or tricks? Anything I should look out for? Special tools needed? Maybe an “injector puller” I’ve seen? I know the injector compensation numbers will have to be put in the ECM. |
12-29-2023, 06:38 PM | #2 |
Rep 760
Drives: 2019 BMW X6M
You would be better off asking in the F15 forum.
2019 BMW X6M
2013 Lexus RX450H 2010 Nissan GTR AMS Omega 14 |
12-29-2023, 07:45 PM | #4 |
Rep 41
They can be removed (very carefully) with a pair of multigrips. Put a nut on the injector (in place of the fuel line nut) and pull. As you mentioned, there is also a special tool for this however I have never required it. As tempting as it is, best not to wiggle side to side however if these injectors are going in the bin, then damage to the injector isn't a concern. However, you dont want to damage the bore in the head where the teflon ring seals.
I have done a few, some come out relatively easily whilst some are an absolute pain in the ass. Luck of the draw... Also, check the injector bore and clean as best as possible before removing injectors. At 125k miles, there's a good chance the bores have dirt and debris in there, you don't want that dropping into the cylinder. |
tfunk88201.00 |
12-30-2023, 02:01 AM | #6 |
Rep 41
Its very tough to clean them spotless. Try and loosen the debris (gently) with a q-tip or similar.
Then use a shop vacuum, or get a vacuum cleaner and stick a tube in the nozzle, then tape up. You can then stick the tube down near the injector. If debris do fall in the cylinder through injector port, you can also stick this vacuum tube in via either injector port or spark plug hole to try and suck debris from top of piston. |
tfunk88201.00 |
12-30-2023, 01:17 PM | #7 |
Rep 10
I use special tool, dont think it's needed for damaged Teflon seals like minds. For dirt I use compressed air, then straw duct taped to vaccum. Still saw dirt fall in after pulling Injectors out, stuck vaccum in there but waiting for borescope camera to be sure. I'm doing valve cover gasket n spark plug gaskets since they failed. I do a lot of summer driving.
Injector puller https://a.co/d/8WsbEnh |
tfunk88201.00 |
12-31-2023, 09:41 AM | #9 |
Rep 496
Is there anything else I should do while I’m replacing injectors? Plugs and coils were replaced about 30k miles ago. Going to replace the o-ring on one of the PCV hoses where it comes out of the valve cover as well.
12-31-2023, 10:07 AM | #10 | |
Rep 462
12-31-2023, 10:35 AM | #11 | |
Rep 496
What’s interesting is when I checked the values that are in the ECM they were ALL 215…wondering if BMW tries to do matched sets when initially assembling engines, it happened by coincidence, or if they just entered 215 for all of them and went with it 😂 |
12-31-2023, 12:49 PM | #12 |
Rep 462
Mine were 309 I believe. Local euro shop advised that special tool (they have quality brand, not amazon), doesnt work as well as the pry bars, and they do injectors all the time. They let me borrow the bars that they use, was super easy to leverage an pull. Up to you, i am here to help 👍
12-31-2023, 12:55 PM | #13 |
Rep 496
Thanks for any and all tips!
Yeah, I may try pry bar first since I’m replacing the injectors with new ones, not trying to save them…I have a couple different sizes of pry bars |
12-31-2023, 01:02 PM | #14 |
F15 daddymobile
2352
Rep 3,516
is there a DIYer around for this?
12-31-2023, 01:06 PM | #15 |
Rep 496
Ha ha I’m sure there is, I still don’t know how to search this forum 😂
I found a couple videos on YouTube that show using the tool I ordered or similar to remove a couple adjacent injectors, haven’t found a start to finish one. Basically remove a buncha sheeeit and pull the injectors. 😉 |
12-31-2023, 01:09 PM | #16 |
Rep 496
Oh snap! Just found the search button! Hopefully I did this correctly…
https://www.bimmerpost.com/forums/sh...php?p=30621667 |
12-31-2023, 04:16 PM | #18 |
Rep 496
I saw one that was 29”-48”…something like that?
Oh, wait, I’m dumb…you mean the ones that have the indexing head, right? Where you can adjust the angle of the pry head, not the length of the handle, correct? https://www.amazon.com/EARWRENCH-Pc-...iABEgJBRfD_BwE |
12-31-2023, 05:12 PM | #19 | |
Rep 462
Correct, its a lifesaver
tfunk88201.00 |
12-31-2023, 05:56 PM | #20 | |
Rep 462
04-30-2024, 09:41 PM | #21 |
Rep 9
Hi Guys, I recently bought a 2016 f85 at auction, I’ve been carrying out repairs myself and I am enjoying working on this engine. I’ve been having a rich mixture across banks, and been trying to diagnose. Today wort ISTA I found that there is no values added for all 8 injectors. could this be the cause of my issues? do I have to pull the injectors to get the code values? Sorry for hijacking the post but I would appreciate advice from those more experienced.
05-03-2024, 10:33 PM | #22 | |
Rep 96
