09-04-2020, 10:00 PM | #45 |
Rep 451
Drives: 2017 X5 & 2020 X5
Wiring to SW should be ok not sure on the splines and air bag wiring and air bag size being compatible for the size of the X5 vs the M3 you may also invalidate your insurance policy if the retrofit is deemed incompatible
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive |
NYBulldog1310.00 |
09-05-2020, 09:21 AM | #46 | |
Specialist
1310
Rep 2,707
Its more of trying to get the M3 paddles to work (same part number as F85 X5M), which I'm not convinced will work without some wiring... that I would completely be okay with doing.
09-07-2020, 02:56 PM | #47 | |
Rep 218
Dont know if its the same wheel, but this is the 1M wheel with M paddles installed on my x5 (originally had the normal lux line non paddle wheel). Working 100% except for the M buttons, which do nothing. |
NYBulldog1310.00 |
09-08-2020, 10:45 AM | #49 | |
Rep 218
I think the M paddles confusion was from the E series Ms and standard models which used a different method on the wiring side. The wiring on the inside was correct so all i had to do was plug everything straight on and afterwards code Paddles_Verbaut to activ. Nice to see other forum members taking the plunge, for me it did a great deal of difference because it offers a lot more control, especially since the x5 is a hefty car. |
NYBulldog1310.00 |
09-08-2020, 11:09 AM | #50 | |
Specialist
1310
Rep 2,707
Koer59.50 |
09-14-2020, 12:26 PM | #51 | |
Specialist
1310
Rep 2,707
I installed the M3 steering wheel, coded exactly what you said and every thing is working beautifully.
Koer59.50 |
09-24-2020, 05:35 PM | #52 |
Rep 2,511
Bambazonke
So I got the wheel with paddle shifters and I am a bit confused with wiring, looks like I do need to splice cables,right? EDIT: Never mind re-read your post and I have white and brown cables in the right spot. View post on imgur.com |
09-26-2020, 03:22 AM | #53 | |
Rep 451
10-03-2020, 06:45 PM | #54 |
Rep 2,511
Well good news are I got steering wheel replaced, added 2TB, paddle shifts are working, Spot+ pops up as well but bad news are when I took it for test drive got bunch of warnings about stabilization, pedestrian detection warning and chassis malfunction, drives just fine but gives me all these errors.I tired to clear DTC errors as described in the coding thread using transmitter app but that did not help, connected with ISTA P and there are 2 errors about EPS sensor and position and the service plan requires to lift front wheels up run some calibration. Sounds like a dealer trip ahead :-(
First error I got is Signal Actual Position EPS 51.0.2 invalid transmitter EPS Second one is 48239C EPS torque sensor (steering angle index): Index Faulty I found exactly same issue here: https://mhhauto.com/Thread-BMW-F15-X...daptation-help Any suggestions? Or just go see a dealer and get them re-calibrate this. Last edited by RED_Y_; 10-03-2020 at 06:52 PM.. |
10-03-2020, 10:37 PM | #55 | |
Rep 451
10-03-2020, 10:40 PM | #56 |
Rep 2,511
Hmm, well test it tomorrow morning again. But so far it looks like I need to jack up front wheels to get the steering wheel sensor re-calibrated. Need to find a second jack and probably a jack stand or if I can't get them might need to visit dealer.
10-04-2020, 11:04 AM | #58 |
Rep 2,511
Do you mind sharing the process? When I go to Vehicle Management-Service Functions-Steering angle sensor field doesn't expand and doesn't show any options there. Am I looking at the wrong spot? When I go to the Calculate test plan it offers me to jack up the front and perform sensor calibration. I also found 3-4 different posts where people said they need to jack up the front of the car.
10-04-2020, 12:52 PM | #59 |
Rep 1,260
I am away from home without any access to ISTA, but over the top of my head I think you need to go intro the first line - Electromechanical power steering and there you have the whole calibration process. Nevermind the steering angle sensor, that will be calibrated with the whole EPS itself.
10-04-2020, 05:11 PM | #61 | |
Rep 451
I am trying to remember if I FDL coded the paddles to active as a quick check before I VO coded the 3 ECU's Opasha spoke about in his coding thread. Either way I did not get any errors until I VO coded the ICM module which cleared themselves from the display the following day after I took the X5 on the road to test out the paddle shifts. I was not running Esys version 3.27 & could not clear the recorded faults using the transmitter app I vaguely remember when I replaced the steering wheel on my VW Tiguan a warning light came on for a few minutes which Ross Tech told me was due to the steering angle sensor recalibrating itself after the battery being reconnected. It disappeared after I drove around the block The good point is you now have paddle shift which a couple of years ago you thought was not an option.....enjoy
10-04-2020, 06:37 PM | #62 |
Rep 2,511
I think it has nothing to do with actual steering wheel being replaced this is a random issue after battery disconnect:
https://f15.bimmerpost.com/forums/sh....php?t=1683268 https://f15.bimmerpost.com/forums/sh....php?t=1594296 https://f15.bimmerpost.com/forums/sh....php?t=1566696 I did not FDL code the paddles just VO 2TB and coded 3 modules. Got Sport+ and paddles working. Not sure what triggers this, some people never get this and some people like me do. |
02-23-2022, 09:00 PM | #63 |
Rep 9
Thanks Bambazonke, I got same setup wit F15 2.5D Xdrive
Just install F30 steering with paddles. to I just cut pink wire and ground it then active paddles_verbaut in Pfsteeringwheel paddles from Bimmercode. Works perfectly Now I wonder if possible to set launch control.. |
Bambazonke210.00 |
02-23-2022, 09:05 PM | #64 | |
Rep 451
Can be done remotely but will still need a cable @r33_RGSport I think does it
06-17-2023, 07:42 PM | #65 |
Rep 227
Thanks for this write up, Bambazonke! I upgraded my Lux line wheel (with paddles) to an F25 MSport wheel using your experience as a guide. All works great!
Bambazonke210.00 |
