      01-08-2024, 06:57 AM   #23
dentprotony@gmail.com
Drives: 2018 f85
Originally Posted by redpit107 View Post
Thank you for the reply. I would need rotors as well as mine is a 35ix. Or do you prefer we source them ourselves? I run 22" wheels but also have the original 20".
Yes, you have to source the rotors yourself but i help with part numbers and locating best price available. Front/rear rotors are from 2014 bmw 550iGT 364/370mm
      01-08-2024, 08:44 AM   #24
hypnotiqdmg
Drives: BMW X5 (F15), M2, i3, S1000RR
Can't brag enough about this upgrade. Tony's kit is the way to go! Two years in and still beautiful and stopping on a dime.
2017 (F15) X5 50i M-Sport
2015 (I01) i3
2010 (K46) Motorsport S1000RR
Retired: 14 (F25) Alpine White 3.5i MSport, 2005 (E53) Imola Red 4.8is, 95 (E36) Boston Metallic 325i
      01-08-2024, 10:32 AM   #25
redpit107
Drives: 2017 BMW X5
Originally Posted by dentprotony@gmail.com View Post
These kits are 2490, and i have options for both 19” and 20”+ wheels. For 19” wheels my kits are made to work with 374 and 370mm rotors, if you run 20” wheels or larger i have 400 and 385mm kits. Only difference is size and rotor price (kit doesn’t come with rotors but includes everything else ). ///M rotors are a hood bit pricier.
Heres a video from the install i done for one of my local customers:
Tony, just want to confirm rotor size. You mention several sizes in the thread. As I mentioned, I run 22" wheels and my stock one are 20". Thank you.
      01-08-2024, 10:38 AM   #26
sukhk527
Drives: BMW X5 XDrive35i
+1 for Tony’s kit. Have had the front and rear installed for almost a year with zero issues. Didn’t even need to do the coding.
      01-15-2024, 03:09 PM   #27
expertsedan
Drives: F15 X5 50i, F82 M4, E36 M3
Without the coding, do you feel a change in paddle firmness?
I am look into getting this kit for my f15 50i, the stock brake does not give me much of confidence even during daily driving. The paddle feels softer to what I like also the braking power is just not good enough imo.
sukhk5272169.50
      01-15-2024, 03:57 PM   #28
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
good lord, do you just slam on the brakes?
      01-15-2024, 06:52 PM   #29
tfunk88
192
Drives: F15 X5 50i
I’m with him on the brakes…my stock 50i brakes felt horrible. Lots of pedal travel with no braking, then all of a sudden you’d get SOME brake action, but not much, then you’d have to press pretty firmly to only get kind of decent stopping power. At first I thought it was electric over hydraulic brakes. Then when I put the brakes from an F85 on all was good…pedal feel was “normal”, thankfully.
      01-15-2024, 07:18 PM   #30
sukhk527
Not a huge change in pedal firmness but I did do stainless lines and upgraded fluid at the same time so I’m sure that helped.
      01-15-2024, 08:31 PM   #31
expertsedan
I might do stainless lines as well while in there, would you mind share the link for the lines?
      01-15-2024, 08:34 PM   #32
expertsedan
Your discription is very accurate! That is exactly how mine feels now!
tfunk88192.00
      01-15-2024, 09:11 PM   #33
tfunk88
192
Drives: F15 X5 50i
I’d try flushing your brake fluid…that helped some on mine. But the big difference in pedal feel and power was having the 6 piston brakes up front with larger rotors. The rear is now larger rotors but the same caliper. I’m definitely going to upgrade the rear caliper at some point when funds allow.
      01-15-2024, 10:49 PM   #34
expertsedan
I actually just did the brake fluid flush with my oil change two days ago. It helped maybe like 5%, funny how similar my experience is to yours.
I have other bmws and by far brake feels worst on this one. That’s why I started searching for solution haha
      02-06-2024, 09:42 PM   #35
Sp749
Drives: 2017 x5 35
Still have ? Front and rear f15?
      02-07-2024, 08:09 AM   #36
Drives: 2018 f85
I do, please text me at 6016181023 i will get you a set 👍
      02-11-2024, 08:48 AM   #37
Nexo
Nexo's Avatar
Drives: E70 x5 2011
2011 X5 e70  [0.00]
Where are you located?
      03-03-2024, 09:55 PM   #38
TDOT_X5
Drives: 2017 X5 35i
2017 BMW X5 35i  [0.00]
Interested in the rear calipers.. pm me quote
      03-20-2024, 11:39 PM   #39
Drives: 2018 f85
Please text me or email what vehicle you have, ill do my beat to get you a kit 👍👍👍
