08-23-2015, 02:06 PM | #1 |
Rep 198
front lower grill install help
so i had my lower front grills painted matte black to match my kidney grills, and am not having luck reinstalling. i'd think they would just snap into place...but no dice. masked the tabs when painting to ensure the paint would not interfere with re-installation. anyone have any tips?
TIA |
08-23-2015, 02:51 PM | #2 | |
76
Rep 380
23 BMW X6MC
21 Porsche Cayenne S Coupe |
08-23-2015, 03:30 PM | #3 |
Rep 5,066
Refer to this thread, I think you need to take off your front wheels and undo the (one time use ) tabs for reinstalling http://f15.bimmerpost.com/forums/sho....php?t=1117489
08-23-2015, 03:59 PM | #4 |
Rep 198
not the side vents.....the lower front "blades" (pics attached). really hate to have to remove the wheel wells. this thing should just snap back into the tabs/holes......right?
08-23-2015, 04:08 PM | #5 |
Rep 5,066
Sorry, I was assuming you were talking about the Msport version.
I may be wrong but I think you might still have to remove the wheel well..
08-23-2015, 04:42 PM | #6 |
Rep 1,181
Removal looks like you'd have to take the liner off, but I would think install would indeed just be push/snap back in, just like the grilles.
Do both sides not snap in? If you shine a light into the openings, can you see the mating tabs? Maybe it just takes one extra hard push to get the tab to hook on?
08-23-2015, 07:21 PM | #7 |
Rep 198
success! so the clips require the tab to be pressed into place (from the rear) in addition to being pressed in from the front. there are 2 small screws that can be removed underneath each lower grill area. once removed, the thick rubber above can be pushed upward to gain access to the rear of the clips. took a lot more force than it should have.....but eventually heard 3 "clicks" per side.
08-23-2015, 08:33 PM | #9 |
Rep 5,066
Nice! Glad you got it sorted out without having to remove the wheel well.
