      12-27-2023, 01:49 PM   #1
compsyndrome
Drives: X35D
Replacing struts
I am tempted to replace my front struts. X5 diesel 2015 120K miles.
She drives fine. Is this a stupid idea? Will I be disappointed? I hope to regain some of the "new car drive" feel.
      12-27-2023, 02:03 PM   #2
tlow98
Drives: 2009 E91, 2014 F15 x35i
I replaced mine at 76k miles and was shocked (pun intended) how much better the ride was.
Also, at that mileage your front tension struts and lower control arms are likely due, especially if you’re chasing a new car feel.
I did them all and drive like a different car. Also, stopped chewing through front tires
      12-27-2023, 04:16 PM   #3
compsyndrome
Drives: X35D
You convinced me.
      12-28-2023, 06:10 AM   #4
compsyndrome
Drives: X35D
May I ask you if you replaced the coils and if you have any recommendations regarding a brand? Also, did you have to unscrew the axle? Thanks.
      03-10-2024, 08:19 PM   #5
compsyndrome
Drives: X35D
In case someone faces the same dilemma, this is what I replaced:
Rear shocks:
BILSTEIN 19240336 , 19240329 $ 95.79
Front struts/coil spring assembly:
FCS 3337073 $82
MOOG RK622956, RK622957 Complete Arm w/ Ball Joint
Front Left, right Lower Rearward $56
MOOG RK623279, RK623280 Complete Arm w/ Ball Joint Info
Front Left, Right Lower Forward; without Active Steering $68
X5 2015 35D with 3rd row, air suspension, 110K miles
I had a shop do my front; then I did the rear shocks myself. The front replacement probably improved the drive some but it wasn't a striking difference.
Changing the back shocks made a more significant difference.
      03-10-2024, 10:52 PM   #6
tlow98
Rear shocks:
FCS 3337073 $82
I’m surprised. Did you pick the car up used? Maybe the control arms were already done?
I noticed no more wandering in the lanes on the highway. Obviously the ride got better and the handling was much more precise everywhere.
      03-11-2024, 05:27 AM   #7
compsyndrome
Drives: X35D
No, I am the original owner. Did you do an alignment after?
      03-11-2024, 07:38 AM   #8
tlow98
Yes, but if you’re not noticing any abnormal wear on the tires than the components you replaced shouldn’t have changed much other than to help get the geometry where it should have been.
      03-11-2024, 09:58 AM   #9
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
always get an alignment after suspension work. You did you control arms! yes, get an alignment
      03-11-2024, 12:03 PM   #10
compsyndrome
Drives: X35D
I was wondering if some (most) of the benefits you saw were from the alignment. Especially the lane thing.
In any case, which helped more is very subjective. The bottom line is, after doing both front and rear, I have a much better drive.
      03-11-2024, 01:03 PM   #11
tlow98
That’s a good point, and one I hadn’t thought of!
I also found the rear to have a huge impact. Those rear shocks must be a bit over worked.
      03-11-2024, 04:59 PM   #12
musa
musa's Avatar
Drives: F86, E92, E53, E39.
Rear shocks:
FCS 3337073 $82
Where did you buy these parts?
      03-11-2024, 07:05 PM   #13
compsyndrome
Drives: X35D
Rockauto. All of them.
musa423.00
