08-31-2023, 02:48 PM | #1 |
Rep 20
Silver Neomax Coilovers or Eibach springs?
Hi guys,
Been searching the forum but not much info on the Silver Neomax Coilovers. Im looking to lower my x6 (standard suspension) on either Eibach springs w/ b6s front and rear. Or get the Silver Neomax Coilovers with Swift springs 14k front and 16k rear. My goal is to achieve being low and still have good ride comfort. From what I read, the Eibach are great for comfort, but only provide an 1" drop. The Silver Neomax Coilovers from one thread here has been good reviews, especially compared to the BC Racing Coils, which ive heard only negative reviews in terms of comfort. Looking for any feedback from anyone that is running Silver Neomax Coilovers in terms of comfort. I am wondering if they will be more jarring than just running the Eibachs with b6s. I live in LA and have a kid, so would like to be comfy but still low with steez. V3 are out of budget. Thanks for feedback Last edited by vin3; 08-31-2023 at 02:49 PM.. Reason: typo |
09-01-2023, 03:45 AM | #2 |
Rep 490
I’m running Eibach and B6’s on my 2016 50i. It’s much better than stock, but it definitely would look better a bit lower. Honestly if I were you I’d save up and wait until you could get KW V3 setup if you want to go lower than Eibach does.
Both pics are with the Eibach springs |
_ObiJon201.50 |
09-01-2023, 10:26 PM | #5 |
F15 daddymobile
2352
Rep 3,510
you mentioned that your goal is to "achieve being low." That will only be accomplished with a coilover or HAS so you can dial in the height. The eibach springs will not get you lower, rather "lower" than stock. if you want to go low, don't waste your $$ or time on anything other than the KW V3s.
09-02-2023, 04:34 AM | #6 |
Rep 297
I guess my stock front springs had already sagged. The Eibachs springs were noticeable shorter than stock, but thicker gauge steel. Oh well, a waste of time and money. I'm not shelling out for coilovers.
09-03-2023, 07:50 PM | #8 |
Rep 20
Hers my current set up:
295/30/22 front (10.5) 335/25/22 rear (12) It looks like a dune buggy right now haha. Im considering going with the H&R springs route instead of Eibach, since it'll give me more of a drop. Hows the ride difference between Ebiach and H&R? I hear the H&R do not ride well, but have not heard to much feedback from x6 owners |
09-03-2023, 07:51 PM | #9 | |
Rep 20
Ya saving up for the KW is the best bet. Have you ran H&R springs? Considering this options over the Eibach |
09-03-2023, 10:43 PM | #12 |
Rep 20
The stance looks so good! Hows the ride quality on uneven roads compared to stock? Also, did it improve handling?
09-04-2023, 10:58 AM | #13 |
Rep 3,649
If you do some searching on this forum you'll find quite a few threads regarding H&R, ACS, Eibach, etc. springs.
The common theme/feedback with H&R is the ride sucks. They will get you lower than Eibach, but with a compromised ride quality. So unless you want to live with that, it sounds like coilovers might be in your future since you want to go low. Last edited by jiggz; 09-04-2023 at 01:43 PM.. |
09-04-2023, 04:18 PM | #14 | |
Rep 20
09-05-2023, 12:02 AM | #15 |
F15 daddymobile
2352
Rep 3,510
From what i've read and after speaking to a popular forum vendor, the H&R springs leave a lot to be desired. An X6 will ride like an X5. Same suspensions. Here's mine on Dinans. 50i here!
zero2sixtyZ952.50 |
09-05-2023, 11:11 AM | #16 | |
Rep 20
Ride looks good! I have not ran the H&R. I will most likely get the Silvers |
09-06-2023, 08:58 AM | #17 |
Rep 2,672
Drives: e92 + f15
I have the H&Rs on Bilsteins. Ride is good, handling is great. My other car is low and on coilovers, to put my concept of comfort in perspective.
Does anyone have the spring rates of the various options to compare? Best side shot I have of the H&Rs: |
09-06-2023, 10:14 AM | #18 |
F15 daddymobile
2352
Rep 3,510
zero2sixtyZ I like the debadged side! i might have to do that. car looks clean
zero2sixtyZ952.50 vin31.50 |
09-07-2023, 11:31 AM | #19 |
Rep 20
Looks clean ! What tires sizes are you running here?
09-07-2023, 02:15 PM | #20 | |
Rep 2,672
Drives: e92 + f15
Stock tire sizes on the 469Ms. 275/40-20 F, 315/35-20 R PS A/S3s in the shot, since then swapped to PS A/S4s. |
09-11-2023, 03:05 PM | #21 |
Rep 20
Ride looks good. What wheels and tire size are you running?
09-11-2023, 03:06 PM | #22 | |
Rep 20
