11-28-2020, 09:26 AM | #1 |
Rep 4
Replacement Tires Input?
Hi folks,
Looking for your input. Sorry if I’m duplicating but couldn’t find a previous discussion on this topic in the scores of pages of threads. After 37K miles, I need to replace the original tires that came on my 2015 X5 xDrive 35d (F15) when I bought it new. Don’t know what is best or what I should consider getting. I’m an around town and freeway driver, rarely on ice or in snow, but I don’t want to rule out that possibility. I have a bunch of questions: - Other than the Pirelli Scorpion Verde All Season tires that came on the vehicle, should I consider some other brand because they’re better? - Should I consider non-RunFlat? - For this next set, should I rotate them regularly? I was told that rotating the originals would void the manufacturer warranty. Other than the tire pressure monitors being reversed, I can’t think of why there would be this prohibition. Do you all have any experience and/or ideas for me to consider? Thanks! |
11-28-2020, 10:14 AM | #2 |
147
Rep 334
Conti DWS06 in Non-Run Flat. What many people go with.
If you have a 19" square setup, no issues with rotating the tires from the front to the back. |
11-28-2020, 11:26 AM | #3 |
Rep 157
Drives: 2015 M5 F10
11-28-2020, 01:55 PM | #4 | |||||
Rep 2,513
Hmm, let me try searching for you: https://f15.bimmerpost.com/forums/sh....php?t=1576749 https://f15.bimmerpost.com/forums/sh....php?t=1550748 https://f15.bimmerpost.com/forums/sh....php?t=1474941 https://f15.bimmerpost.com/forums/sh....php?t=1473264 https://f15.bimmerpost.com/forums/sh....php?t=1536436 https://f15.bimmerpost.com/forums/sh....php?t=1634777 https://f15.bimmerpost.com/forums/sh....php?t=1767338 https://f15.bimmerpost.com/forums/sh....php?t=1655775 Quote:
11-28-2020, 06:01 PM | #5 | |
Rep 7,494
2. Just an FYI...the TPM sensors send a signal (when rotating) to the RDC module...so it doesn’t matter what axle position the wheel is located...it will give that data to the RDC module. 3. I would highly recommend spending some time on TireRacks website (www.TireRack.com) . They have a TIRE DECISION GUIDE link on the site that will walk you through some questions that will narrow down tires that fit criteria that fits your personal preference, finances, and geographical/climatic conditions. You can then red the many surveys, reviews, tests etc for any tire brand/model that piques your interest. YOu can buy from them or take the info you glean from the site and shop locally.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-28-2020 at 06:08 PM.. |
