02-04-2024, 05:27 PM | #3 |
Rep 20
02-05-2024, 08:26 AM | #6 |
Rep 2,669
Drives: e92 + f15
Use a tire calc to determine the diameter / circumference to match your current setup.
Then use Tire Rack for tire reviews / testing to find the best tire in the tire class (summer/all-season, etc) you want. |
onetake1.50 |
02-05-2024, 09:34 AM | #7 |
F15 daddymobile
2350
Rep 3,510
sell those rinky dink wheels and getting something that'll fit better. 10" wide.
02-05-2024, 10:11 AM | #8 | |
Rep 7,489
BTW, you should also look at the wheel offset of those aftermarket wheels. The F15 20" staggered wheels usually have the specs below:
If you mount an 8.5" x 20" wheel...it is already approx 2" narrower than the original f15 wheels...and if the offset specs are similar or greater than above...the wheels are going to look sunken in....or could be too close to the suspension bits. You can use a calculator at a site like www.willtheyfit.com and compare the old vs new wheel/tire combo for each axle to see what the new combo fits vs the old wheel/tire combo. The lower the wheel offset...the more the wheel will be pushed out toward the fender.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 02-05-2024 at 10:22 AM.. |
onetake1.50 |
02-05-2024, 10:45 AM | #9 | |
Rep 20
