08-09-2021, 07:07 PM | #177 |
Rep 8,364
This is good guide to help you achieve desired behavior.
08-12-2021, 09:22 AM | #178 |
Meat Popcicle
10
Rep 18
11-27-2021, 10:27 PM | #179 | |
154
Rep 355
I wonder if it was ever offered on the F15? |
11-28-2021, 04:31 AM | #180 |
Rep 1,038
It was.
I would love to look at doing this retrofit. My googlefu ia been weak. I haven't been able to comeup with the p/n and wiring/pinout needed for it. I wonder would it be just plug and play? |
11-28-2021, 08:36 AM | #181 | |
154
Rep 355
As i mentioned, it was not an E70 option. But, hearing BMW actually offered it on the model, it should be far more straightforward on the F15 to retrofit. |
12-01-2021, 06:22 PM | #182 |
Rep 1,038
You would think so, but every time I looked into it. All i could find were threads of people going back and forth over how complicated it was. Without really stating why its so complicated.
if you do end up doing it on yours, please do let us know how you did it. |
12-07-2021, 07:56 PM | #183 | |
Rep 1,038
https://www.bimmerfest.com/threads/s...trofit.835896/ https://www.car-auto-repair.com/bmw-...etrofit-guide/ Any volunteers ? |
12-09-2021, 12:04 AM | #184 |
154
Rep 355
The links you found show the FRM module being used to retrofit the option on older models. My E70 has the FRM.
I only see a functional description offered in ISTA for Contact-Free Tailgate Opening with the USA X5. The Evaluation Module is not showing up in the literature as being actually installed in the vehicle. I looked in 2015 & 2018. It is pretty trivial to buy the hardware and connect the module to the LIN bus. I do not know if the option exists in the BDC module firmware or anywhere else. Having said that, here is the solution for an F16. https://f15.bimmerpost.com/forums/sh...1540680&page=3 And, skoold2003 got it working on his F15. Last edited by Tomcat_F15_STL; 12-09-2021 at 12:21 AM.. |
12-09-2021, 10:49 PM | #185 |
154
Rep 355
lol. just ordered all the parts for Smart Opener off Fle*Bay.
61-35-7-391-043 sensor -lower round style 61-35-7-391-045 sensor -upper round style 61-35-7-429-824 control unit $75.00 w/ above sensors 61-35-7-496-165 second control unit to replace cracked case on the other $14.00 61-13-2-359-997 connector $22.04 |
12-11-2021, 07:33 PM | #186 | |
Rep 1,038
Also, whats the difference between: 61-35-7-429-824 61-35-7-496-165 61-35-7-422-700 Just reading the part descriptions and they all say Smart Opener Control Unit. Reading through skoold2003 post, it looks like he got the 700 unit. |
12-11-2021, 10:16 PM | #187 | |
154
Rep 355
I have no idea what they may have changed from one to the next! lol. |
12-11-2021, 10:26 PM | #188 |
Rep 1,038
Yeah but from that list, only the
61-35-7-429-824 61-35-7-496-165 seem to be interchangeable. The guys in that thread were talking about 61-35-7-422-700, just curious how the 700 comes in play. |
12-12-2021, 01:07 PM | #189 | |
154
Rep 355
A safe bet would be to buy used controller and sensors which came off the same car. |
12-28-2021, 12:08 AM | #191 |
154
Rep 355
F15 Smart Opener Installation Details
I just wrapped it up. Works fabulous.
61-35-7-391-043 sensor -lower round style 61-35-7-391-045 sensor -upper round style 61-35-7-429-824 control unit $75.00 w/ above sensors 61-35-7-496-165 second control unit to replace cracked case on the other $14.00 61-13-2-359-997 connector $22.04 Coding in the BDC Body module using eSys: CAH_SMART_OPENER_COD_FAHRZEUGTYP = 5e VAM_SMART_OPENER = activ_HK VAM_ENABLE_SMART_CLOSE = activ All Solder Connections: Controller Pin1 - LIN wire to PIN 42 on connector 258*4B into BDC located in Passenger Footwell Controller Pin2 - +12VDC from Fuse F150 behind tailgate fuse block Controller Pin3 - GND to ground bus filled with brown wires located next to tailgate fuse block Last edited by Tomcat_F15_STL; 12-28-2021 at 02:15 AM.. |
12-29-2021, 06:10 PM | #192 |
Rep 1,038
Tomcat_F15_STL Legend, cheers for the write up.
hey Question, the module ends in 797. Its none of the part numbers on the list. It seems to be only used in the Wraith RR5?? Is that the one you ended up using? |
12-29-2021, 10:57 PM | #193 |
154
Rep 355
Man! I wish I had a Wraith RR5 - that would be epic!
The first three shots are random internet photos to fill in the blanks for others. Perhaps, I should have noted it on the pictures. I used 61-35-7-496-165 because the tabs were cracked off on the other module I had purchased. I used those tabs to zip-tie it to the metal behind the bumper cover. fyi, it was not necessary to remove the bumper cover as there was plenty of room to reach up from underneath. The biggest stinker was fishing a wire up to the BDC module in the passenger footwell. The carpeting and insulation is insanely thick and grippy to push past. Surprisingly, BMW has improved their mounting clips and nothing broke or snapped pulling off trim pieces. Last edited by Tomcat_F15_STL; 12-29-2021 at 11:10 PM.. |
TaraRene0.00 |
09-21-2022, 08:56 AM | #195 |
Rep 7,568
Type this following phrase into a google search box. and see if you get any results: BMW coding cheat sheet pdf
Coding parameters are basically the same for all BMWs that have the same communication system & modules. Which means an F15/F06/f10/f01/f30 (X5/6/5/7/3 series) will have the basically the same coding parameters if they have the same modules (CAS/BDC/JBE/FEM/FRM/etc). If not exactly the same...they will be very similar. EDIT: found this cheat spreadsheet doing a google search: https://docs.google.com/spreadsheets...it?usp=sharing
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 09-21-2022 at 09:41 AM.. |
09-21-2022, 04:47 PM | #196 | |
Rep 123
Does anyone know if you can set the wipes to be on auto via coding? |
09-21-2022, 07:55 PM | #197 | |
Rep 101
That one had more features and a slightly bigger cheatsheet I had both but didn't get to save the other one to be offline This one is still good too though
Current:
2015 F15 X5 35i MSport - BSM/Black - RC RS - BMS CP Past: 2002 E53 X5 3.0i Sports Pkg - Titanium Silver/Black |
09-23-2022, 11:19 AM | #198 | |||
Rep 123
Tags |
2014, coding f15, f15, f15 coding |
