07-24-2023, 08:13 PM | #1 |
Rep 36
New brakes vibrating, fixable or buy new ones?
I recently replaced my front brakes and rotors on a 2014 X5 50i. The last time I got this done for the rears at the dealership and it cost me $1000, so I decided to try it myself this time.
I bought a set of Brembo rotors and non-ceramic Brembo pads. I thought I followed the bedding procedure properly, with gentle braking for the first few hundred miles and then a few hard stops, letting the brakes cool down before stopping the car. But after about 2000 miles the brakes have developed an annoying vibration between 35-50 mph. It's less perceptible if you brake very gently or quite hard, but the in between makes the brake pedal feels like driving over cobblestones. I tried braking hard again a bunch of times which might have made it slightly better. But it's still pretty noticeable. Apart from grinding down rotors, is there anything you can do to fix this? Or should I just buy a new set of rotors and pads? Coincidentally I was talking with my local gas station/indy repair shop owner, who owns an X3 and just replaced his rotors too. He ran exactly into the same issue as me and ended up going back to OEM BMW rotors and pads. Though I don't like how soft they brake and rusty they get, I'll probably do the same if I can't fix these. If not OEM, is there any other brand people have been happy with? Looks like RockAuto doesn't sell the OEMs unfortunately. |
07-25-2023, 07:31 AM | #5 |
Rep 41
Brembo components should [key word] be a suitable replacement so hold tight on thinking about immediately replacing them or grinding down.
When you first drove off to start bedding, was there any vibration in the pedal? Or did the vibration develop post-bedding? |
07-25-2023, 08:17 AM | #6 |
Rep 1,340
Your rotor(s) could be warped/defective from factory. Happened to me with a brand new OE rotor for my F85. You can take the rotors to a machine shop and have them examine and turn the defective rotor or if you just bought them recently, do a warranty replacement?
07-25-2023, 08:34 AM | #7 |
F15 daddymobile
2358
Rep 3,535
since it developed after 2000miles i'd say it's likely a warped rotor or you have pad deposits that are unevenly burned onto the rotor. have you take the wheel off and looked closely at the rotors for pad material that may be stuck on them?
07-25-2023, 10:23 AM | #8 |
Rep 630
Not sure it's related to your issue (probably not) but figured I'd post my brake bedding procedure that hasn't ever let me down (30x?).
1. Drive car to straight open road using light braking as little as possible to get there. 2. Put hazard lights on and accelerate quickly to 60mph. 3. Engage brakes HARD. 4. Repeat 2 and 3 at least 3x... your brakes will be HOT. 5. Using the brakes as little as possible, get on the highway and drive for 10 minutes to allow the brakes to cool down. 6. Done. Never had any issue with the above procedure. Again, probably not your issue, but figured the info might be useful to someone. |
Vivek.1367.50 |
07-25-2023, 10:59 AM | #9 | ||||||
Rep 36
Lots of helpful comments here, thanks!
When I replaced the rotors and pads there was a ton of rust everywhere (New England winters ) so I took the wire brush wheel and metal file to the pad tabs, then applied white lithium grease (only on the tabs). I'm now seeing that wasn't the proper grease to use. Perhaps one of the pads stopped sliding properly? I don't know if taking it all apart and re-greasing with the proper grease would help, or if I'd still needs new rotors. |
07-25-2023, 03:52 PM | #10 |
Rep 499
Honestly what I would do is lube the pads properly and then re-bed them, getting them nice and hot. Could take care of it.
As far as cleaning the rotor with brakleen…some rotors come with a dry corrosion protection coating that doesn’t need to be wiped off before installation…and brakleen won’t take it off anyway. But a lot of rotors come with a “residue” coating that needs to be cleaned off as it will contaminate the brake pads |
07-25-2023, 05:09 PM | #12 | |
Rep 36
I just ordered a new warranty replacement, same exact set. Guess we'll find out in a week or so if that resolves my issue? Hopefully I can keep these operating properly.
07-25-2023, 05:53 PM | #13 | |
Rep 451
07-25-2023, 08:51 PM | #14 | |
Rep 2,529
Some pads manufacturers say that bedding is not needed, especially for ceramic brakes. Brembo recommendation is actually to avoid sharp breaking and overheating:
https://www.bremboparts.com/europe/e...dding-in-90374 Quote:
08-03-2023, 01:54 PM | #15 |
Rep 36
Thanks for the help and recommendations everyone. I just replaced my rotors and pads with the same Brembo types, and will claim warranty for the old ones. Unfortunately, I just noticed that after 20 miles of driving there's a noticeable scratch/gash on the left rotor.
It doesn't look like something got caught on the pad. Otherwise it would be a circular pattern. Casting defect? I really don't want to return and install another set... |
08-03-2023, 03:56 PM | #16 | |
156
Rep 358
If it comes back, I would wonder if you adequately cleaned the rails during the job? Also, did you fully seat the caliper piston back plenty? The pistons can get sticky -especially if you do not flush brake fluid regularly. As was mentioned by another member, Akebono pads and PowerStop rotors will work terrifically for a fraction of the cost of the Brembo stuff. |
