      02-02-2023, 05:13 AM   #1431
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by simonatgg View Post
Hello all, anybody know how to disable the auto start/stop for 40E(hybrid), i google for weeks but i cannot find a correct way to do that, setting without expert mode won't works.
Disabling not easy, but setting memory is possible and can be used as long as you have button to disable.
      02-02-2023, 12:12 PM   #1432
grim69
Drives: BMW F15 M50D and BMW F16 40D
Can someone help me please im trying to code my fog lights to turn on with my welcome light on my 2015 f15 and this is the code i found for it
3063 MAPPING_NEBELSCHW_L_PART_OF_WL set to: werte=01
3063 MAPPING_NEBELSCHW_R_PART_OF_WL set to: werte=01
on my ecu the line only reads
then when you go into it its either off 00 , or FLB_UEA 03 changing to the 03 option seems to do nothing and adding 01 manualy also does nothing
does anyone know if theres some other code line to change to make it work or is it becaue i have the led fog lights with bi xenons and adptive lighting that i cant make them work? any help would be appreciated thank you
      02-02-2023, 06:38 PM   #1433
R4ndy
Drives: BMW
Hi, need some assistance, want to retrofit speed limit info, checking my BMW in real OEM there is a retrofit option
01 Retrofit speed limit info IBAC 1
65502184753
only in conjunction with
-- Enabl.code retrofit road sign detection ASAP 1
66502444948
After ordering 2 444 948 please
download enabling code 007E via ASA
Is there anyway in enabling this with Bimmercode as opposed to purchasing essentially a licence to retrofit via ISTA?
Some of my vehicle options
S5AC High-Beam Assistant
S5AG Lane Change Warning
S5AL Active Protection
S5AS Driving Assistant
S5DL Surround View
      02-02-2023, 06:42 PM   #1434
shawnsheridan
shawnsheridan's Avatar
65502184753
66502444948
S5DL Surround View
No, need 7E FSC Enabling Code, which must be Imported with E-Sys, and then Coded.
      02-02-2023, 07:12 PM   #1435
R4ndy
Drives: BMW
Is there a retrofit option using ISTA as opposed to ESYS, if I was to purchase the genuine FSC code?
(Just recently added retrofit coding option for my BBK, that worked fine via ISTA)
      02-03-2023, 10:20 AM   #1436
shawnsheridan
There should be.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      10-27-2023, 04:53 AM   #1437
CMYACHTIE
CMYACHTIE's Avatar
Drives: 545i,2017XC90,2018F15 X5 35iM
Originally Posted by notchy View Post
I had to search around and found out that the instructions via Bimmercode to fix the tailgate slam actually has different steps to follow for any F15 from the year 2017 and newer.
Hope this helps anyone trying to get this to work.
Go to:
Tailgate Function Module -> 3011 APPL_PLG_SPEED_PROFILE
Change the values to '00A0' in the following 4 sections.
ProfileCloseStopNode1PwmPlg = 00A0
ProfileCloseStopNode2PwmPlg = 00A0
ProfileCloseStopNode1PosPlg = 00A0
ProfileCloseStopNode2PosPlg = 00A0
After I did this my trunk does not slam anymore. It took a few hours of scouring to piece together the info.
Tried the above yesterday as my dealer performed a free(recall) software update recently on my 2018 F15, which made my hatch noisy again and the final result has reduced my slam once again.
However the steps I had to go thru in BimmerLink were somewhat different than the four lines above, unfortunately I didn’t document the steps I had to go thru but one of the lines didn’t have the option of 00A00 and during the final coding there was another line that popped up, which I selected the 00A00 for which allowed me to complete the coding process.
Just a heads up for anyone going thru the same struggle as I……
2004 545i and then 2017 XC90 and now 2018 F15 X35i Msport
      10-27-2023, 10:37 AM   #1438
50iXman
50iXman's Avatar
34
Drives: 2014 X5
waittttt can we actually code apple cart play/andrioid auto to work?
      10-27-2023, 10:58 AM   #1439
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
I believe you need a 17 or newer.
      10-28-2023, 12:00 AM   #1440
callmeorsan
Drives: bmw 335 range rover evoque
Originally Posted by Maverik259 View Post
You've heard conflicting stuff cuz it depends. Most error codes will reset by just shutting the car down for awhile. Some may not which require to be cleared. BimmerLink isn't the only option just the easiest. But as you said since you don't have apple products then not sure if the question cuz you can't download it anyway lol. Use esys or ISTA.
Wouldnt protools be just as good?
      10-30-2023, 02:47 AM   #1441
irzayev
Drives: BMW X5 F15
Hi everyone, is there any way to turn on fog lights with AngelEyes in night mode?
      11-02-2023, 01:41 PM   #1442
Waka99
Drives: BMW X5M
I have a 2017 X5, can anyone elaborate on this please?
      11-03-2023, 12:30 AM   #1443
RED_Y_
Drives: 2014 X5 3.5d
Check you VIN, if your head unit is compatible you need set of FSC codes to enable Apple CarPlay. No Android auto.
