11-17-2023, 12:42 PM | #1 |
128
Rep 301
Just flashed my x35i with the bootmod3 91 octane stage 1 tune, took it for a quick test drive and ended up getting a drive train malfunction error with bunch of misfire codes. Just replaced plugs assume it could be a coil issue? All coils are secure. Flashed back to stock also same issue. Any thoughts?
Fixed see posts below was a bad spark plug that was brand new. |
11-18-2023, 10:22 AM | #3 | |
128
Rep 301
Car has been reflated to stock and cleared codes before trying again. |
11-18-2023, 11:35 AM | #4 |
F15 daddymobile
2350
Rep 3,510
ive been reading more and more on injector issues on both 50i and 35i. is this really that common? i've owned several BMW and cars and none have ever had injector issues.
11-18-2023, 01:47 PM | #5 |
128
Rep 301
I solved it, sometimes it’s so simple it’s hard. Brand new plug in cylinder 4 was causing the issue. Pulled it put it into cyclinder one got the same misfire codes. Swapped it and all is good, just coincidentally happened when I did the bm3 tune. 😂 cheers!
