      08-08-2014, 11:17 AM   #45
OuKEnFoLdMX
OuKEnFoLdMX's Avatar
Mexico
26
Drives: BMW F15
well guys i am planning to put this little grills on my space grey, look just so diferent that front, so its just that hard to put them on a x5 35i? or just put them with epoxy? i read someone here try going from under the front truck maybe this is the most easy method. i dont know.
      08-08-2014, 11:53 AM   #46
skalberti
skalberti's Avatar
Drives: 2017 Mineral White M3
I'm just going to drill the wholes out and then epoxy. I got some loctite plastic epoxy that is water proof and actually melts the plastic together from Home Depot
It's good to be bad
      08-08-2014, 12:06 PM   #47
For 35i, it is much easier. You can do it from the bottom cover also. If have access to a lift, it is much easier. Unless if you are planning to change the grill to an open grill, then you will still need to open up the fender liner.
PM for Everyday DEALS!!
      08-08-2014, 12:07 PM   #48
OuKEnFoLdMX
Mexico
26
Drives: BMW F15
well i am in the same boat, what you mean (I'm just going to drill the wholes out and then epoxy), where do you planning to drill the wholes?
      08-08-2014, 12:42 PM   #49
skalberti
skalberti's Avatar
There's 4 pegs that go through the grill and then 4 metal clips slide onto those pegs to lock them on. That's why you have to take the fender liners out. Since our stock grills have the markings for the holes, but the holes aren't drilled out yet, we have to drill for the pegs to slide in. I'm just going to epoxy and then slide the pegs in. Some people say the trim is wobbly with the metal clips and they have to epoxy anyways.
It's good to be bad
      08-08-2014, 01:26 PM   #50
FYI, you don't need to drill the holes, they are open already.
      08-08-2014, 01:39 PM   #51
buckeyewalt
Drives: 2014 X5 50i
Originally Posted by 1230vani View Post
Thank you. Color is great, but boring as my previous car also was space gray, my advice to all is to change the color, as it gets boring after a while. I would go probably for white next time around! It will sound silly to some, but the hood stands out when you drive and is cool to see it in front of you. With space gray it kinda blends in with the road. These M50d stripes look awesome on a white car.
I have a mineral white and have been thinking about doing this except epoxying the strip in instead on using the lock washers. Got the idea from this member. I think it looks great!!!
http://f15.bimmerpost.com/forums/sho...d.php?t=985841
      08-08-2014, 02:27 PM   #52
jpsjr70
jpsjr70's Avatar
Drives: 2015 BMW X5M
Buckeye, I have those painted in mineral white never installed if you want to buy mine. I'm not installing, waiting to place order on X5M. PM if interested....
Joe
      10-13-2014, 03:00 PM   #53
chiplee
chiplee's Avatar
307
Drives: 2015 M3
Just installed these on our sDrive and it was pretty much a snap. The self locking retainers get very tight if you push on the trim piece from the front while locking them down. I see no need to attach them to the Bumper where people mentioned using foam tape.
r33, I thought your write up was good. A few points of constructive feedback though... For people who are changing from closed to open grills, there is no mention of how to remove/replace them. It was rather intuitive, but it had me scrolling through the instructions to see if I had missed a section. There's also no mention of how to install the new white plastic rivets. I came to the board to learn that they are just pulled to yield type things. That's different from the e70 fender flare rivets so I was confused for a moment. Last thing, the left side only has one black plastic fastener, vice the two that your instructions mention, so a person starting with the left insert will hunt around for the second one until he realizes it's just not there. Other than that, it got me through the job with no bloody knuckles and no new scratches on the car so thanks for the write up! They look awesome.
      10-13-2014, 04:00 PM   #54
@Chiplee, Congrats on the install.
I will update the DIY instruction once I got a chance to do another one in house.
      10-13-2014, 04:35 PM   #55
OuKEnFoLdMX
Mexico
26
Drives: BMW F15
can someone tell me the diference between open and close grill? are you talking about the holes in the grill were you put in this trims?
@r33, your are telling me that under the x35 its a cover in the bottom front that i can take off and acces to the 2 grills more easy? intead of open the fender liner. if you can can you take a picture of the bottom cover that i hace to remove plz, and thanks
      10-13-2014, 04:44 PM   #56
chiplee
chiplee's Avatar
307
Drives: 2015 M3
This should explain it.
      10-13-2014, 05:28 PM   #57
OuKEnFoLdMX
Mexico
26
Drives: BMW F15
get it! thanks @r33
and the botton cover front that i have to remove if its the part number 4?
http://www.realoem.com/bmw/showparts...59&hg=31&fg=05
      10-13-2014, 05:59 PM   #58
get it! thanks @r33
That would be #3.
http://www.realoem.com/bmw/showparts...32&hg=51&fg=70
IMO, it is not easier, since you don't have a nice position for you to reach in and push the locking ring.
But, it is do-able. Maybe easier if you have the car up on the lift with that removed.
My DIY is for you who work on it at the driveway and doesn't have access to a lift.
      10-30-2015, 01:32 AM   #59
BayX5
Drives: F85 X5M
Anyone actually go through with the epoxy route? Good results?
      10-30-2015, 07:24 AM   #60
Don't.
Couple guys called in and said it fell off somewhere.
The part is not cheap.
      10-30-2015, 09:47 AM   #61
stewy604
stewy604's Avatar
290
I just used the metal retainer rings on each post. Seems to be holding solid for me.
2007 Suzuki GSX-R 750
      10-26-2016, 12:27 PM   #62
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
Anyone on here have the Part Number for the Driver's Side open grill?
      10-26-2016, 06:25 PM   #63
iconoclast
iconoclast's Avatar
7266
I believe I found it... 51118053883.
      10-26-2016, 06:55 PM   #64
stewy604
stewy604's Avatar
290
Grill, open, left - 51118064633
Grill, open, right - 51118064634
iconoclast7265.50
      10-26-2016, 07:00 PM   #65
You got it right.
BTW, the M50d trim is on sale now.
      10-27-2016, 02:55 AM   #66
1230vani
1230vani's Avatar
653
Drives: G05 40i LCI
Happy with the end result . Would I go through this again? Don't think so.
Looks beautiful! Every time you guys make the Space Grey look better, a part of me wishes I got this color (my second choice), especially considering my current work in progress . Nice job, Ivan .
This thread resurrected, got carbon black car now, as i said earlier i will not add these on, seems to be OK with carbon black, otherwise i think these m50d inserts are a must
