10-18-2022, 01:22 AM | #793 | |
Rep 62
02-04-2023, 05:17 PM | #794 |
Rep 238
Drives: F16 X6 M50i
Hoping to revive this thread 🤞🏼.
Anyone had a Mandrel built custom exhaust system on their X5/6 M50i? |
02-10-2023, 12:32 PM | #795 |
Rep 651
Mandrel bent custom likely won't make any difference compared to a complete AA system (also mandrel bent?) with HF cats, only cost more $ and time to figure out.
If the X5 was an NA not Turbo, getting all bends etc perfect, might have made a difference. IMHO; With Turbos and it being an X5, not a supercar, going full custom is a waste of money. The only advantage with custom, over what many people here have done, is that you could get a less restrictive X-Pipe (or H-Pipe), compared to the inexpensive stamped X-pipes that seems to be the only options available to buy "off the shelf". |
BlackBeans75.00 |
02-10-2023, 03:22 PM | #796 |
Rep 238
Drives: F16 X6 M50i
Thanks 1norseman. Thinking of going Res delete with x-pipe for now and leaving rear muffler intact. Let's see how that turns out.
Also seriously considering adding KW V3 Coilovers. |
02-11-2023, 09:16 AM | #797 | |
Rep 651
If you go back to my posts in this thread, you can see a picture showing how some or maybe most the store bought X-pipes are built. Can be quite restrictive/ disruptive to flow, instead of free flowing. If you have the V8 and want to hear it rumble, you will need to do a muffler delete. When it comes to the suspension, many good threads on the forum, for what to do. KW is a good choice. |
03-25-2023, 10:29 AM | #798 |
F15 daddymobile
2352
Rep 3,518
so the stock muffler must have an internal x pipe of sorts?
03-25-2023, 08:45 PM | #799 |
Rep 651
[QUOTE=shimmy23;29969499]so the stock muffler must have an internal x pipe of sorts?[/QUOTE
Check this tread by Cbozz: https://f15.bimmerpost.com/forums/sh....php?t=1669185 From what I can see, the right and left side are separated inside the muffler, by a perforated plate. I guess you can call that "an x-pipe of sorts". |
shimmy232351.50 |
03-30-2023, 05:34 PM | #801 |
Rep 238
Drives: F16 X6 M50i
Definitely getting the muffler delete.
My only reservation is that most that have done it have an X5 while mine is an X6 with a valve actuator. Not sure what impact that will have on my SAV. Opinions welcomed. |
04-25-2023, 02:37 PM | #802 |
Rep 238
Drives: F16 X6 M50i
Appreciate this thread was started way back in 2017 and I'm very late to the party.
BUT, my 2017 X6 M50i is booked in for a muffler delete on the 11th of May. I already had the two resonators deleted and replaced with an x-pipe a few month's back. I appreciate many on this thread who have done the mod are no longer active, but if you are, and think the mod was a bad idea in the long run, please speak now or forever hold your peace! 😂 |
04-27-2023, 10:11 AM | #803 | |
Rep 206
Drives: 2015 BMW X5 50i
2015 X5 50i - Current
2011 E92 M3 - Sold 2016 F30 340i - Sold |
meds1976114.50 |
04-29-2023, 10:09 PM | #804 |
Rep 27
Just done a muffler delete replaced with 2 x Vibrant resonators in its place (also retained the OEM resonators), an X pipe plus some quad tips…it now sounds like it should have done leaving the factory and there’s no drone on the slow twisties or on the highway. In fact not much louder than stock at 70mph while cruising but a lovely throatiness and burbling now when idling and at lower speeds.
04-30-2023, 10:10 AM | #805 | |
F15 daddymobile
2352
Rep 3,518
04-30-2023, 12:21 PM | #806 | |
Rep 238
Drives: F16 X6 M50i
Will remove muffler and see how loud it is and then if needed, will add the resonators back on. But hoping I won't need to 🤞🏼. |
04-30-2023, 02:41 PM | #807 |
Rep 27
So to clarify my set up kept the 2 stock resonators but I did add an X-pipe and then essentially I replaced the muffler with 2 more resonators. So I can only imagine no resonators and a full muffler delete will be VERY loud!!
meds1976114.50 |
04-30-2023, 02:49 PM | #808 | |
Rep 238
Drives: F16 X6 M50i
Will definitely do before and after video/audio clips. |
mattingamells69.50 |
04-30-2023, 02:56 PM | #809 | |
Rep 27
meds1976114.50 |
04-30-2023, 02:59 PM | #810 |
Rep 27
04-30-2023, 03:02 PM | #811 |
F15 daddymobile
2352
Rep 3,518
Thank you!! i really like how clean your setup looks
mattingamells69.50 meds1976114.50 |
05-06-2023, 10:05 AM | #812 |
Rep 3
Thanks to everyone of the posters over the years who've shared their setups and video clips/sound clips, made working out what I wanted nice and easy..
I've went down the following path after lurking this thread for about 8 months: First: Deleted the stock resonators and put in an X-pipe with stock muffler Results: Way more pronounced "V8" tone, especially on vacuum when off throttle, less crackly overrun, more deep and burbly, overall volume is mostly the same unless over 50% throttle under 3k rpm, then about 10-15% louder. WOT the volume didn't seem that much different. Second part, loved the idea of the vibrant ultra quiets and the videos posted by pennsiveguy(?) Setup is now: Stock downpipes, deleted resonators, 2.5" X pipe, into 2x Vibrant ultra quiet resonators (part # 1142, the 2.5" in/out piping) into quad stepped, angle cut double wall 3.5" quad tips Results: Love the volume, I'd say about 35% louder than stock. Without the resonators I think there's a touch of low drone only between 1150-1300 RPM, but it doesn't seem to go through the entire car, nor did my partner notice/give me any grumbles in the car. Super deep/bassy exhaust sound now, thunderous overrun now with really nice V8 tones. Here's a quick video of me stuffing around at night playing with the exhaust. |
meds1976114.50 |
05-06-2023, 05:33 PM | #813 |
Rep 238
Drives: F16 X6 M50i
NaTe-Von I'm in a similar situation with my 2017 X6. Deleted the resonators and added a custom x-pipe.
Now booked in next week for a muffler delete with vibrant resonators as back up in case muffler delete is too loud. Also planning on adding quad exhaust tips. Will post clips when done. |
05-06-2023, 08:09 PM | #814 |
Rep 3
meds1976 So with the muffler delete it will essentially be straight piped?
There was a person on YouTube to had a video revving with the same setup: I think they're a member on here too if I remember correctly. Doesn't seem insanely loud but sounds really nice |
meds1976114.50 |
