07-13-2015, 11:33 AM | #1 |
Rep 709
Ok... So most things in the BMW are reversed from my Acura (up vs down on turn signal/washers, etc) but one I'm having a tough time with is the pushbutton stop. Push once and the accessory power is on (one push on the Acura was a dead stop). However, two clicks should completely deaden (minus map lights) the car, correct? The LED strips are still on... BUT, most importantly, the doors won't consistently lock unless I use the key fob. When I touch the door handle I see the lock thingy trying to move down, but it won't. I have been able to do it... I just don't think I'm doing anything differently and it used to be so easy one previous car. Press stop button... Get out... Touch handle and door locks. What am I missing???
It's weird and I know I've got to be doing something wrong. Any advice is appreciated. |
07-13-2015, 11:59 AM | #2 |
Rep 5,066
This is the case for me on my X5.
Press once to stop the engine.. radio and air is still running.. here you can get out and shut the door then lock it and everything will shut off. The shifter stick will still emit "P" for a few moments and shut down. I press the button again and it shuts the radio and air off then I close the door and lock the car. |
07-13-2015, 12:07 PM | #3 | |
Rep 709
I was hoping a user error for the inconsistency. |
07-13-2015, 12:33 PM | #5 | |
Rep 709
07-13-2015, 12:40 PM | #6 |
Rep 5,066
I know what you mean... the shifter in M/S position which allows you to manually shift to lower and higher gears is different direction from the japanese cars.
07-13-2015, 12:43 PM | #7 | |
Rep 709
07-13-2015, 12:50 PM | #8 | |
Rep 8
To unlock you put your hands behind the handle as if you are opening the door. Here is a BMW USA video showing how it's done. |
07-13-2015, 12:50 PM | #9 | ||
Rep 709
07-13-2015, 03:09 PM | #10 |
Rep 1,547
[scratches head] What's backwards about the turn signals? Up on the stalk is right signal, down on the stalk is left... Or are you referring to the one touch lane change indicator (3 flashes)?
07-13-2015, 03:11 PM | #11 | |
Rep 709
And on a side note... I think I figured it out and am embarrassed to say. Lol. Apparently my big gorilla hands were getting a little too close to the inside of the handle, so the door wanted to lock and immediately open. |
07-13-2015, 04:12 PM | #12 | |
Rep 8
One other cool thing I noticed about locking the door using the handle is you can push the lock on the handle while passengers are still getting out of the car. For example if some of the passengers are slow to get out and the doors and you have already closed the driver's side door. After the last door closes the car will automatically lock itself and you will hear the beep. I'm using my BMW 550i as a reference point and I assume the X5 will work the same way. There is also a setting on iDrive which will change the lock behaviour if you want it to only unlock the driver's door instead of all doors. |
07-13-2015, 06:34 PM | #13 |
Rep 5,066
^^ I do this all the time.. sometimes my wife has stuff in the back seat and I usually get out first, close the door and touch the area to lock it.. when my wife is in the back seat grabbing her stuff and closes the door the car locks
07-13-2015, 09:16 PM | #14 | |
93
Rep 306
2018 F80 M3, Mineral White, Full Sakhir Orange, ZCP
2015 F15 X5 35i, Mineral Silver, Terra Dakota (Retired) 2012 E89 Z4 35i, Deep Sea Blue, Walnut Kansas (Retired) |
07-13-2015, 09:53 PM | #15 |
Rep 222
when we picked ours up at Spartanburg last week, the delivery advisor specifically pointed out that many people are on the lock and unlock at the same time when trying to lock it, and that we should be careful to ensure we only touch the ridges . |
07-13-2015, 09:55 PM | #16 |
Gamertag: Boardwalk
35
Rep 82
Drives: 2019 M240i xDrive Convertible
Haven't needed to on the X5 yet, but on my 1 I routinely use my elbow to lock the door (e.g., when carrying a coffee and a bag for work in each hand). Super convenient! I have noticed the X5 comfort access door handle is a bit more sensitive, although pleasantly more responsive.
• 2019 BMW M240i xDrive Convertible Estoril/Cognac/Hexagon ZPP, 20Z, 3YA, 674, 552
• 2015 BMW X5 xDrive35d Mineral White/Terra/Hexagon ZMM, ZPP, ZCW, 2VF, 417, 3AG, 688 × 2008 BMW 135i TiAg/Coral/AgAl ZSP, ZPP, 205, 322, 494, 4MG, 677, 6FL |
