10-05-2015, 02:33 PM | #1 |
Rep 3,834
X5M/X6M Gloss Black Grille/Gills Wrap - DIY
Guys... I'm not a cheap ass by all means, but I can't justify $440 for a set of plastic grilles. After reading a DIY thread, I was inspired to wrap my grille surround.
You can do it yourself too, very easy. Just a bit tedious and patience. Tools Needed: T-27, ratchet, 2 flat head screw drivers, heat gun, exacto knife, and 2 working thumbs (you can use felt squeegee, optional). Materials: http://www.amazon.com/3M-GLOSS-Black.../dp/B007EEU58W Time: 1.5-2.5hrs. Step 1: Removing the grilles from the car - Move rubber gasket from top of the bumper (don't remove it, just move it so you can access the 5 screws), which covers 5x T-27 screws. Remove the screws. Lift the top of the bumper out of the 3 guides, then pull slightly. Each grilles have 2 taps on top, 2 tabs on side, and 2 tabs on the bottom. Pop the tabs on top and side of each grille first with screw driver. Then access the 2 bottom ones on each grilles by pulling the bumper out from top and reach down. Use your fingers to feel the tabs then pop them out. It may take a couple tries, wear long sleeves or your arms will be scratched up. Step 2: Separate the chrome from the black pieces. Just observe all tabs, use a crew driver to pop them out. Start with the top and side ones, the bottoms will come out when the top tabs are loosened. Just a tiny bit of force to pry them apart. Try not to break these fragile clips. (you can watch how the M3/M4 guys replace their grille surround, same concept) Step 3: Wrap - cut a vinyl piece 1-2" larger than the grilles. Once the vinyl is peeled, lay flat with sticky side up on a clean surface. Carefully place the chrome side of the grille surround on the vinyl. Use your fingers and heat gun to work the vinyl on top and outer of the grilles until it's smooth. Next, use the H-shape technique as the vid in the below reference thread. Once you've reached the edge, start trimming using your finger as a guide to have a nice trim (you can't see the trimming work if it's not as pretty. Step 4: Snaps the grilles slats and surrounds together, then snap the back into the car. Re-install the screws and rubber weather gasket. Total time for me was 1.5hrs. Step 5: Enjoy your work. Post here if you have questions... Tips: Work the vinyl with both of your thumbs, 1 inch at a time to ensure it's smooth. Only heat 1 sec at a time. Don't cut until the outside and inside reached the edge with no or little kinks. Watch the vid and tricks in the threads below before starting. I'll work on the side gilles next time, which requires heating and removing the X5M emblems. Same concept, slightly easier. I hope you "appreciate" this thread. Inspired by: http://f30.bimmerpost.com/forums/sho...d.php?t=986632 Thanks pablobaq
10-05-2015, 05:23 PM | #3 |
Rep 509
You are so lucky that I don't live closer! I'd be at your house next Saturday with a six pack of your favorite brew (scratch that -- a case) and all the materials!
Great job! Looks good. Thanks for posting. |
10-05-2015, 05:38 PM | #4 |
Rep 18,715
@JNoSol , good job!!!
10-05-2015, 06:38 PM | #5 |
Rep 2,775
Drives: F95 X5MC
Great DIY and fantastic write up!
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
10-05-2015, 08:21 PM | #6 |
Rep 3,834
Gloss Black Gills Wrap - DIY
I got bored so I did the gills too... Follow other DIY on how to remove and replace the gills. Only difference is you have to separate the chrome piece from the black plastic before wrapping. Use 3M outdoor mounting tapes to replace all tapes, then reverse the install.
FYI: It's a bitch to remove from the fenders. You have to break some of the clips to get them off. Our fenders are ABS plastic, so don't worry about denting it. Total Job: 2hrs Wrapping process is the same as the grilles. You'll have to remove all the tape residue and X5M/X6M emblem. Use a heat gun and razer blade to start it, then use a flat head to slowly ply it off (it's aluminum so don't bend it too much). Once wrapped, use a blade to poke holes where the emblems sit to get the bubbles out then head/press. I used a cotton swab to go around the edge of it.
Upurock47.00 |
10-05-2015, 08:28 PM | #7 | |
Rep 3,834
P.S. This is a time consuming DIY. Wraps last about 2-3yrs, so if you plan to keep the car longer or don't want to mess with it - buy M Performance parts from r33_RGSport or painted ones from iND.
10-05-2015, 08:34 PM | #8 |
Rep 3,834
Thanks bro. Notice the chrome gills on my 6GC? Too tired to mess with it tonight.
10-06-2015, 02:32 PM | #11 |
Rep 3,834
Interesting.
Painting these would work if a shop strip the chrome plating off the plastic. When you get a rock chip on the M Performance pieces, you see black under the shiny surface and not chrome. Even with good prep work, painting on chrome plated plastic doesn't stick in the long run (it will flake off). This is why Wrap is more durable on chrome plastic pieces. I believe iND use raw BMW OEM parts that's plastic to paint, not chrome plated.
10-07-2015, 07:08 AM | #12 |
Rep 271
This is amazing; If I were more handy I would do this!
Past: 2007 328i Coupe, 2009 M3 Coupe, 2014 Range Rover Sport S/C, 2014 Range Rover Sport ATB, 2015 M4 Cvt
Present: 2016 x5M, 2017 c63s Coupe (current) |
10-07-2015, 08:06 AM | #13 |
Rep 3,834
You can do it. Wrapping is very easy to learn. Just buy extra for mistakes if you're doing it the first time. I thought the harder part of this project was removing the grilles/gills. The wrapping is time consuming, requires patience, but easier than R&R.
More photos...
6lacksheep88.50 |
10-07-2015, 09:05 AM | #15 |
Rep 3,834
I thought about it. I'm not sure how to make a clean cut on the wrap w/o damaging the paint. There's WrapCut and Knifeless, but they don't cut that clean sometimes. I'll leave that alone for now.
10-07-2015, 09:09 AM | #16 |
Picture me rollin'
307
Rep 1,130
Yeah you would need to use Knifeless tape, but it would look great along with your winter wheels.
10-07-2015, 10:20 AM | #17 |
Rep 3,834
LOL. I'll order more 3M 1080 soon.
10-07-2015, 01:21 PM | #20 |
Rep 729
If you're going to wrap the plate bar, wrap it in a black material that matches the finish on the matte plastic air intakes on either side of the front bumper. Otherwise, I think it'll look out of place if done in gloss black.
10-07-2015, 03:48 PM | #21 |
Rep 3,834
Good suggestion. I might just plastidip then, matte black.
10-08-2015, 10:55 AM | #22 |
Rep 1,188
Drives: 2023 BMW M2
Garage List 2018 BMW i3s REX [10.00]
2021 Audi SQ5 [0.00] 2020 BMW M2 CS [10.00] 2018 Audi SQ5 [0.00] 2020 BMW X3M Compet ... [10.00] 1999 BMW M3 [10.00] |
Nice write-up. Thanks for sharing!
2024 Acura Integra Type S White/Red
2021 Audi SQ5 Black/Red(wife's car) Instagram: Bklyngarage Follow me! |
Tags |
diy, gloss black grille, vinyl wrap, x5m |
