11-03-2015, 04:04 PM | #1 |
Rep 52
Tuning question
Can someone tell me if the RaceChip TB Ultimate BMW N63 / N63tu Gasoline is worth the $ and if so is it easy to install?
Thanks!
2016 BMW X5 xDrive 50i White 2017 Porsche Carrera 911 S White |
11-04-2015, 03:08 AM | #2 | |
Rep 18,788
11-04-2015, 09:27 AM | #4 |
Rep 52
Ok. Thanks guys for the responses. r33_RGSport I ordered the BMS, the non smoker package and the transmission shift cover from your site! Will I see a little better gas mileage with the BMS tune for my big V-8? Damn thing really drinks the fuel!
Thanks!
11-04-2015, 11:32 AM | #5 | |
Rep 18,788
11-11-2015, 07:10 AM | #6 |
Rep 136
Well my Racechip Ultimate just arrived and is set to S1:F and S2:C, I have read this forum inside and out and still cannot be sure what is the best setting, have emailed Racechip, Germany as all the literature that arrived is in German which is helpful. Vehicle is a 2014 F15 MSport 40D. Any members fitted one to this model and if so what did you set S1 and S2 to?. Euro spec in this case.Thanks.
11-11-2015, 07:53 AM | #7 | |
Rep 5,066
http://f15.bimmerpost.com/forums/sho...light=racechip http://f15.bimmerpost.com/forums/sho...light=racechip http://f15.bimmerpost.com/forums/sho...light=racechip
11-11-2015, 08:14 AM | #8 | |
Rep 136
11-11-2015, 08:41 AM | #9 |
Rep 5,066
Sometimes the settings are random and this is just my thought that the packers/assembly are being careless. I would suggest starting at default settings on your tune and go up one setting at a time. Also I suggest using high grade fuel.
11-11-2015, 09:08 AM | #10 |
Rep 136
Hi thanks I will but I don't know the default settings, nice space grey car by the way.
11-11-2015, 09:32 AM | #11 |
Rep 5,066
Thanks
I'm also not familiar with the diesel chip so I'll let others that know answer for you. I know Trojanlaw, 42pilot have done some extensive experiments on RC tune, maybe they can provide the answers to the default settings.
11-11-2015, 09:53 AM | #12 |
Rep 136
OK thank you, this forum has been great so far so hopefully someone will comment, or maybe Racechip in Germany will reply
11-13-2015, 02:33 PM | #13 |
Rep 710
Since you are talking about a 40d, you really need to start with RaceChip in Germany for their starting settings. I called them when I received my chip and they were very helpful and open. I recommend you invest in a phone call to describe exactly what you have and find what they recommend. Let us know what they recommend - I for one, would be very interested.
11-14-2015, 12:43 PM | #14 | |
Rep 136
Per our phone conversation, here is the information about how to change the settings in your RaceChip Ultimate for your BMW X5 (F15) xDrive 40d 230kW. We deliver each RaceChip with the basic settings, this are the optimum ratio between more power and less fuel consumption. On average, the RaceChip Ultimate increases the power of the engine up to 20%. I'ts hard to tell what the maximum settings for your vehicle are without some testing. Each engine is driven under different conditions and different maintenances, which can lead to different results. Therefore, in order to reach the maximum potential for your vehicle, we will have to make some adjustmensts to S1/S2 With the rotary switch S2 the performance of the RaceChip can be increased or reduced. From the basic setting "C" every other position you increase clockwise is a further increase of about 1.5%, up to the maximum position, “7” (values on the website). If you twist the switch on the opposite direction, the output will decrease 1.5%, up to a minimum of ca. 5% at position 8. The rotary switch S1 controls when the RaceChip will switch off. In the basic setting"F" of the RaceChip has an average of 1500-3500 RPM. Each additional position clockwise is an extension of the activity by about 200 RPM, anti-clockwise to a corresponding reduction. Please increase the values one at the time and make a test-drive. Increasing more than two values at once could lead into error messages. For your vehicle the recommended performance levels are S1/S2: Level 1: F/D Level 2: 0/F So I have fitted the Racechip Ultimate in my 2014 40D M SPort, the fitting was very simple. I have for now left the settings as advised by Racechip, S1:F and S2:C. However to be honest I cannot make my mind up if its made much of a difference to be honest so will leave it as it is for one week then change S2 to E. I was told S:1 controls when the Racechip is actually working and setting F is between 1500-3500RPM, to me that seems to make sense and when you need the extra power. Switch S2 is the performance switch so as Racechip claim a 25% increase from 313HP stock to max 390HP I am going to have a play around until I feel its made the difference I was hoping for although given the weight of the vehicle and the fact it is not exactly slow anyway I'm not to sure it will. As mine is a business lease and fuel paid I can perhaps be a bit more ambitious than some. Please feel free to comment as I'm a novice at all this stuff. |
11-14-2015, 09:11 PM | #15 | |
Rep 710
S2 controls the amount of fuel (power) introduced during the injection. The more fuel, the more power, to a certain point. BMW's ECU will not let you go too far because it has other sensors like fuel rail pressure that will limit fuel flow. Also, BMW's ECU will allow a certain amount of additional torque, but will flatten it out after something like 1300 rpm to 3000-sh rpm. You should feel an improvement in throttle response, for sure - it should jump off the line from a dead stop much better than a gas engine. As for horsepower (much different from torque), not many people can tell a 20% difference by the seat of their pants (until your motor hits +500 hp) - it has to be shown on a dyno graph because rarely is horsepower applied to the entire RPM range. It usually peaks at a certain point, usually towards the middle to top-end of the RPM range. Again, be very careful turning up the tune on your 40d, especially if you own the car. If you choose to play with the settings, adjust by one click and drive it around town for a while to see how you like it. If it throws a CEL, you know you have hit the max the ECU will allow, so back off the setting by one or two clicks. One last point - gas and diesel engines are very different, so be careful trying to apply gas principles to your diesel engine.
