03-10-2016, 08:28 AM | #1 |
Rep 75
Change Ambient Lighting
Hi guys!
Yesterday I coded "Change Ambient Lighting -Dome" All lightning just disappeared! Change Ambient Lighting -Dome BDC_BODY 3070 GROUP_0_FARBE_ENSEMBLE_1 orange (changed to white) - Dashboard BDC_BODY 3070 AMBIENTE_FARBE_ENSEMBLE_1_LAYER_1 orange (changed to violet) - Door's BDC_BODY 3070 AMBIENTE_FARBE_ENSEMBLE_1_LAYER_2 orange (changed to yellow) - Floor's BDC_BODY 3070 AMBIENTE_FARBE_ENSEMBLE_1_LAYER_3 orange (changed to green) I know it is such a strange color combo, but I just wanted to check... Is anybody coded this successfully? What should I do? Code everything back? |
03-10-2016, 09:34 AM | #2 |
Rep 1,181
Is it still dark, even after letting the car sleep? The ambient lighting always goes away when coding certain ECUs, but then comes back after the car sleeps. Happened multiple times last week as I was coding NGHB.
If it hasn't come back, then yes, revert all the coding.
03-10-2016, 11:52 AM | #3 | |
Rep 75
03-10-2016, 12:02 PM | #4 | ||
Rep 570
03-10-2016, 01:36 PM | #5 |
Rep 1,181
Heh heh. I assumed he/she saw your thread because ambient lighting color change was never previously deciphered on the master coding spreadsheet.
03-10-2016, 04:41 PM | #6 | |
Rep 570
03-10-2016, 04:51 PM | #7 | |
Rep 75
Lightning is back, but not these colors I put via coding. I'll do search and I hope it will help. Should I just search our forum with "Ambient lighting" words? |
03-10-2016, 05:15 PM | #8 | |
Rep 75
Btw 2nd page of your thread is not about the ambient light, this NYC guy May I PM to you if I'll have any questions? |
03-10-2016, 05:54 PM | #9 |
Rep 1,181
Where have you been getting all the info for the coding you've been doing lately, Maxipes? Just asking because you've had various issues so far and it may be due to using coding info/values for other car series? Many are probably exactly the same, but I'm sure there are specific differences.
03-10-2016, 09:56 PM | #10 | ||
Rep 570
And yeah that guy...oh well...I just gave up at one point... |
03-11-2016, 07:32 AM | #11 | |
Rep 75
https://docs.google.com/spreadsheets...9s4/edit#gid=0 Please let me know if there is a better (Update) version. I didn't go for details yet in PlayTookie's "Ambient lighting" thread, but compare to coding in google list his coding is more detailed. Am I correct? Thanks, |
03-11-2016, 11:34 AM | #12 |
Rep 1,181
That's the right one. I only asked because you had a problem earlier with the auto unlock, but the coding section/value you used was one that wasn't on the cheat sheet. No worries, though. Sounds like you're almost there and will resolve the ambient lighting issues soon. Good luck.
03-24-2016, 02:08 PM | #13 |
Rep 75
In iDrive in x5 (F15), in lighting section in settings you have 9 different options for the ambient lighting. Is that right? 1. Blue 2. Orange 3. White 4. Orange/white/orange, blue/white/blue and other combos, so there different colors brought together, at least two of them.
So when I coded lighting in Esys I have an option to choose for each group one main color and two others. According explanation in "ambient lighting" thread it choosen main color white and secondary colors are green. After coding all 9 sections I choose main color - blue and secondaries two are the same (yellow/yellow or red/red or green/green) but at the end when I switch color combos in iDrive I have all 3 yellows or all 3 reds or all 3 greens I guess my question is how to make a combo of 2 colors, lets say white/yellow/white or blue/red/blue or something like that. I know this is not such an important field of coding, there are much more really helpful and practical. Still curious. Any help? |
07-03-2020, 12:35 PM | #14 |
Rep 3
Coding Ambient Lighting w/Bimmercode
Hi, thanks for the post. I was able to finally make these changes but can you tell me what layers 4-9 are for? They show as inactive.
When I code the different colors in layers 1-3, it worked just fine, just curious what the other layers are for. Thank you!! |
07-03-2020, 01:17 PM | #15 |
Rep 2,528
