08-20-2017, 01:40 AM | #1 |
Rep 2,388
Hate body roll - what springs to make it go away?
Compared to stock that is (I realize it won't go away completely).
I have stock suspension on my 50i, no air or self-leveling, nothing like that. I don't want H&R - because it makes car too stiff and bouncy jarry ride - a Pogo stick. ACS or Eibach - seems only alternative. Which one will make body roll less while keeping ride close to stock? I don't care for lowering. I care for reducing body roll |
08-20-2017, 01:59 AM | #2 | |
Rep 2,194
08-20-2017, 02:10 AM | #3 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
I would vote for ACS or just spending the extra money on Coilovers setup.
My friend with X5 35i base suspension got KW V3 and car is lowered;happy and handles better than ever. Although if it was me, I would go with another Coilover company or just throw AC Schnitzer springs. My X4 m40i currently on H&R and its exactly how you describe it
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
DuSh2113.50 |
08-20-2017, 02:38 AM | #4 | |
Rep 2,388
FSociety3812.50 |
08-20-2017, 02:41 AM | #5 |
Rep 2,388
I've heard that ACS is made by Eibach as well. Not sure if true. Are they both progressive springs? I know stock springs are constant rate springs and it would be nice to have some numbers to compare, but it's hard to find this info on internet for f15
08-20-2017, 03:14 AM | #6 | |
Rep 11,136
DuSh2113.50 |
08-20-2017, 10:47 AM | #7 | ||
Rep 18,715
Spring rate probably different.
DuSh2113.50 |
08-20-2017, 12:13 PM | #8 |
Rep 993
A spring isn't "bouncy". The factory shock, ie dampner, is not correctly paired with the higher spring rate. I don't know what the spring rates are, but obviously if your pairing an aftermarket spring that has a higher spring rate, with the stock struts/shocks and the spring rate is outside the dampening capability of the stock components, then yes it's going to be bouncy.
DuSh2113.50 |
08-20-2017, 01:01 PM | #9 | |
IG @bmwF9xG80
3813
Rep 7,593
Waiting to hear a friends experience on BC Racing Coilovers with Swift Springs. Swift Springs are amongst the favorite within the F80 M3 right now. Have a friend with H&R Super Sport and he bent 2 wheels/2 flat just recent and has a Competition Pkg M3 which already comes with better dampers than stock F80 i think.
DuSh2113.50 |
08-20-2017, 06:01 PM | #10 | ||
Rep 18,715
Remember that all of these springs are progressive rate. The other issue that have to be considered is the damper length. With lowering a car, you will have less compression length and more rebound length. And since the stock damper valved softly, with more rebound length and higher rate or even the same rate, the damper will rebound fast and compressed fast. But again, it will depending on how much you are lowering the car. With Eibach and ACS, the spring still put a pre-load to the damper, while H&R, it have less preload. Quote:
If you are looking for a proper coilover, I wouldn't even consider BC Racing Coilover, which is the same as Megan Coilover, and some other chinese brand. Also, you can't blame a spring for a bent wheels or flats. There are a lot of variable that can cause a bent wheels, such as; tire pressure, wheels material, the size of the pot hole, how hard the impact, etc. Don't ever expect all M cars are built with the best. Trust me, I have hard core track customers that came in to replace their M cars stock suspension into high end coilovers.
08-20-2017, 07:30 PM | #11 | |
Rep 993
2024 X5 50e, previous- 2024 X7 M60i, 2021 X7 40i, 2019 X7 40i, 2017 X5 50i, 2015 X5 35i
08-20-2017, 08:07 PM | #12 |
Rep 2,388
I've heard good things about Ohlins Road and Track coilovers, but I don't think it's available for our f15
I wonder what is the best ultimate coilover system for f15 for road usage, not looking to track it |
08-20-2017, 08:30 PM | #13 |
Rep 18,715
KW Variant 3 is the best street coilover available in the market for the F15/F16 X5/X6 and F85/F86 X5M/X6M.
08-21-2017, 09:46 AM | #14 |
Rep 785
I just like Violator above went with Eibach springs and spacers which I got from Ben at r33_RGSport. It's exactly what you are looking for.
Ride height is roughtly X5M stance and spacers make it look tough. Ride is just what I wanted. Slightly tighter but with much less lean in the turns. Ideally as Ive said in a few other posts, a rear sway bar would finish it nicely. It's amazing on long drives and is still smooth over imperfections. I'm in the Northeast which says a lot about them since the roads are crap...
991 Turbo
993 GT2 Outlaw |
