12-27-2017, 07:04 PM | #1 |
Rep 4
Speed limit info
Proud owner of X5 F15 X25D M package MY2017
I have problems with speed limit info, for some reason HUD and control panel does not "read/display" speed limit info from signs. I we searched entire forum but i didn't find this issues with X5. I have connected drive camera with line tracking, front collision warning, pedestrian alert, HBA and also i have navigation pro with touch screen and iDrive 5. How can i activate this feature or fix issue? Thanks in advance! |
12-28-2017, 07:14 AM | #3 |
Rep 4
Yes, there is option to enable on HUD or display, but i see only icon without traffic limit like this:
https://i.ytimg.com/vi/7bZinfFQZt8/maxresdefault.jpg |
12-28-2017, 05:29 PM | #5 |
Rep 4
As i know, camera working fine, since HBA feature using camera for incoming cars and HBA working fine... i have issue only with signs... I am wondering is there a option to check this feature over coding or etc...
12-28-2017, 05:49 PM | #9 |
Rep 1,417
Since you have both HUD and Speed limit info/SLI .
If all is well, you should be able to see SLI on both Instrument Cluster and Windshield/HUD. I always find HUD is best as it is in your line of vision as you drive. You should see be able to enable this through settings. Let me check my x6 tomorrow. |
12-28-2017, 05:52 PM | #10 |
Rep 1,270
There is nothing wrong with the camera, hud, settings or signs.
The navigation map for Serbia does not have speed limit information, therefore the system will not work, even if the camera reads the signs. If he will drive his car to Germany, the speed limit info will work fine. |
12-28-2017, 06:11 PM | #11 |
Rep 4
turboawd i ordered car in Germany
CatalinP Thanks for answers i will check with dealer tomorrow.. Also is there a way to update maps Since is very funny that cheap navigation systems like iGo, Here have those data and bmw don't |
barcelona271.00 |
01-20-2018, 06:23 AM | #12 |
Rep 453
Drives: 2017 X5, 2020 X5 & 2021 X5
SLI also not working in Australia
I also have the same issue here in Australia where SLI does not work. BMW Australia deliberately removed it from the X5 model range here sometime ago due to litigation reasons. I am now trying to reactivate it in mine as one forum member has just bought a new G series X3 here in Australia, and has confirmed he has the function working. I have also updated my maps to the same as what he has. I also have all the appropriate hardware plus more installed, so it's just a matter of coding it back
I have managed to code the NBT2 unit to display the option to turn it on in both the instrument display and HUD but sadly it did not work. I don't even get the blank sign as seen in the OP's link to the pic of the instrument panel Is there anybody out there with a 2016/17 X5 with SLI working that does E sys coding that can send me a copy ncd files of their Kombi and Kafas2 modules so I can compare them using Tokenmaster's Software Tools. Ideally it would be good if I could get an EU ROW model as my experience with VAG autos is the US/Canadian models differ somewhat compared to the ROW. However something is better than nothing Please PM your email address so I can send you mine and copies of my ncd files for your perusal and verification. I have also had a look at my 2016 Garmin maps of Australia and they all have the speed data then so I don't believe it's a map data issue
Current: MY 21 X5 3.0d xDrive MSport
MY 20 X5 2.5d xDrive MSport MY 17 X5 2.5d sDrive Last edited by Bambazonke; 01-20-2018 at 06:33 AM.. |
04-30-2018, 01:43 PM | #13 | |
Rep 4
With my X5 F15 I have tested the speed limit info in the folowing countries: In Germany, Austria, Croatia and Romania works fine. In Serbia, BiH, Macedonia and Bulgaria does not work. I bought the newest map updates and installed but still doesn’t work in mentioned countries. I’m not sure it depends on maps, if I am not wrong camera reads signs and all the maps should contain speed limits because it should be the main parameter how the navigation calculates trip time estimation for choosed destination. Could you please share your expirience with RTTI - real time traffic information in Serbia or other Balcan countries. I bought RTTI service but it worked fine only when I was in Austria and Germany. Thanks! |
04-30-2018, 01:58 PM | #14 |
Rep 535
I believe default speed data is provided by maps, and if the kafas2 camera does read a sign, it will update and override the display from the sign. So if the maps don't have the SLI, this will not work.
Present: 2014 X5 50i
05-01-2018, 03:26 AM | #15 | |
Rep 674
https://www.ebay.com/itm/Speed-Limit...19.m1438.l2649 Read this thread for more info! https://f30.bimmerpost.com/forums/sh....php?t=1203393 |
02-28-2022, 11:13 AM | #16 | |
Rep 12
And yes, I dont wanna upgrade some Chinese SLI Emulator Last edited by baiibyy; 02-28-2022 at 11:14 AM.. Reason: Forget to write about Chinese adapters |
03-01-2022, 08:09 PM | #17 | ||
Rep 453
MY 20 X5 2.5d xDrive MSport MY 17 X5 2.5d sDrive |
03-02-2022, 04:08 AM | #18 |
Rep 12
My car already has a 7E SLI FSC Code issued to it and Option Code 8TH Road sign detection but still doesnt work in Bosnia/Serbia, only Croatia, Germany, EU etc
03-03-2022, 06:21 AM | #19 |
17
Rep 80
03-03-2022, 06:22 AM | #20 |
17
Rep 80
03-05-2022, 11:10 AM | #21 | ||
Rep 12
05-29-2023, 11:57 AM | #22 |
Rep 3
My car is one F15 m50d with driving assistant plus and kafas2 camera but I can not code the speed limit info .
I have made all the coding with bimmer code software but the only thing I see in cluster and hud is “ - - - “ Can anyone help me ?? Thank you |
