03-27-2018, 02:22 AM | #1 |
Rep 10
Problems Opening Tailgate from Remote
Hi all - newbie here with a F15 X5 40dM in the UK.
Just collected it on Friday past. Always love that moment when you look at the odometer and it reads 00007 miles. Going to be hard sticking to the contracted mileage on this one though I fear! Anyway, all good so far but for one really frustrating thing. When I try to open the tailgate using the remote, following the instructions in the manual that state 'press the button for 1 second' the tailgate just 'pops' open but doesn't lift. Pressing the button again closes it. On occasions, repeating the button press will fully open the tailgate, although it can take several attempts. If I press the physical button on the tailgate, it just pops it open, and I have to press it again to fully open it. Same story with the button on the drivers door; one press to pop it open then have to press and hold it to swing it fully open. Having used other BMWs with power tailgates, I'm pretty sure it should all work with 'one press' of either remote button, tailgate button or door button. Can anyone help here? Thanks experts |
03-27-2018, 04:34 AM | #3 |
Rep 10
Thanks Catalin. Even keeping the button pressed results in it just clicking open. It takes several attempts before it wakes up and swings the tailgate open as it should. Have tried just about every combination of button pressing with the same results.
I reckon my neighbours think I'm mad! |
03-27-2018, 05:19 AM | #4 |
Rep 30
I have a 2015 F15 3.0 D M Sport. If I hold the key fob button down until the hatch unlatches then it continues to open fully. The switch on the door panel only needs to be pushed once for it to open fully.
As CatilanP has already commented I would check the opening height setting in the iDrive. Hope this helps |
03-27-2018, 05:23 AM | #5 |
Rep 10
Checked iDrive and it shows as being able to open to full height. Messed about with it but still getting the same symptoms. When it does finally open, it does go right to the top.
03-27-2018, 11:28 AM | #6 |
Rep 1,180
There’s an issue with some tailgates sticking. Mine does it occasionally. Not enough to make me take it in to get fixed yet. Yours seems pretty severe. Take it to the dealer.
It’s only opening about 6 inches then stopping ya?
2018 X5 35i M-Sport
03-27-2018, 04:37 PM | #9 |
Rep 73
There’s definitely a ‘knack’ to opening the x5 boot (an issue I’ve never had with my previous Audi’s) anyway, I’ve coded mine (with bimmercode) to open with a single button press for a split second. It seems to work much better than the holding the button to open does.
03-27-2018, 04:39 PM | #10 |
Rep 1,180
I think you're right actually. It's just been awhile since it's happened. I'm not sure if it's my imagination but it seems to open with more force when I use the button above the license plate.
2018 X5 35i M-Sport
03-27-2018, 09:47 PM | #11 |
Rep 164
03-28-2018, 04:57 AM | #12 |
Rep 10
Thanks for the replies folks. I'll update after it's been at the dealers - my i3 is in there at the moment for a replacement head unit so I might just swap 'em over.
At least you get a good coffee at my dealership :P |
03-28-2018, 07:31 AM | #13 |
Rep 10
Been pondering and suddenly realised the consistency of how the various buttons operate. It seems it needs the initial action to pop the tailgate, and a subsequent press to actually raise it.
Press once on the tailgate button to unlock and release it from the catch, then another press to open it fully. Same with the door button, and I've just done same with the remote. A '1 sec' press, then another '1 sec' press and it opens fully. Could it be that it's now a two stage process to auto open the tailgates then? Seems a bit daft to me if it's coded that way. |
03-28-2018, 10:37 AM | #15 |
Rep 120
I think the rubber seal that touches the lower hatch sticks to the paint. When it initially tries to open, the force required to “unstick” the rubber seal from the paint is enough resistance that it causes the hatch to abort opening, kind of like if it were to hit a low ceiling.
04-19-2018, 11:38 PM | #16 | |
Rep 42
It happens intermittently, did the dealer figure it out? |
05-12-2018, 06:45 PM | #17 | |
2018 F15 X5 X40d #BSM #IvoryWhite
39
Rep 334
It’s driving me nuts as I can’t figure it out but the point made above about it sticking and aborting the opening sounds plausible because it works flawlessly the second time as if whatever causes it to stick the first attempt has become less sticky?! |
05-22-2018, 06:44 PM | #19 |
Rep 1,180
Haven’t had any issues since the temps have warmed up a bit around here.
Maybe try wiping down all the contact points with some quick detailer to see if that helps.
2018 X5 35i M-Sport
06-19-2018, 01:18 PM | #20 |
39
Rep 334
So the car finally went into BMW today regarding the tailgate issue and turns out to be faulty struts, BMW said they take about a week or two to come in so I have to come back and book my car again
Once they're fitted I'll come back with an update to see if it solved it. I've been told that the tailgate should open fully every time and is not designed to 'pop' first then open at the touch of the button a second time. |
06-25-2018, 05:31 AM | #21 | |
Rep 42
