07-14-2019, 10:46 AM | #1 |
Rep 264
OEM Spare ok on XDrive
I'm finally going to ditch my RF's for the Toyo ST III's and wanted to pick up a spare. With that said is the spare ok to use with XDrive? I wouldn't be driving long distance if I had to use as I would go straight to the tire shop to have repaired/replaced.
2015 F15 XDrive 50i MSport
07-14-2019, 09:03 PM | #3 |
1152
Rep 2,426
The OEM donut spare is the same rolling diameter of the factory wheels.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
07-15-2019, 12:25 PM | #4 |
Rep 3,742
Have no experience personally, but we have the factory 20” wheels with the factory spare option which is 18”. One would think this would cause all sorts of issues with XDrive as while as ABS and DSC?
07-15-2019, 12:48 PM | #5 | ||
Rep 264
07-15-2019, 01:50 PM | #6 | |
Rep 7,588
If you run your 20" tires and your 18" spare through a tire size calculator (easily found by googling "tire size calculator)...you'll see that their rolling circumference/diameter is either the same or almost the same (within that 3% +/- range).
07-16-2019, 01:24 PM | #7 | |
Rep 264
07-16-2019, 01:40 PM | #8 | |
Rep 178
I have 20" tires and ditched the runflats. I have the M performance brake upgrade so the minimum rim size I can run is 19" due to the bigger brakes. I run the spare that is for the X5M which is a 19" spare. Same concept at the 18". The ratio is minimal between the tires vs. spare. I have had to use it a few times unfortunately and never had an issue with any drivetrain warnings or issues. You will be fine on the 18" spare if needed. |
07-17-2019, 12:21 PM | #9 |
Rep 535
I carry a 19 inch X5M spare. The 18 inch ones dont clear the M performance brakes just incase you have them. Bought on ebay for $180. Absolutely ok to use and infact, I recommend it.
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors Past: 2013 750i xdrive, 2008 535xi Last edited by sj22; 07-17-2019 at 12:35 PM.. |
JWK170200.00 |
