07-26-2019, 12:00 PM | #1 |
"Salud"
14050
Rep 4,692
Drives: F01 & F15 / Mineral White
Door Welcome / Puddle Lights
So I have these "BMW" logo welcome lights in the doors on my 750.I really like them and get compliments regularly for them. I want to install some in our X5 too. I ordered some from Amazon that indicated they would fit. But upon pulling down the light, the actual connector is different than on my car. Has anyone ordered/replaced theirs? If so, which set or brand did you get?
Thanks, Marcus |
07-26-2019, 01:18 PM | #3 |
"Salud"
14050
Rep 4,692
07-26-2019, 02:39 PM | #5 |
Rep 2,529
07-26-2019, 02:47 PM | #6 |
"Salud"
14050
Rep 4,692
I guess I will have to take a picture of the X5 connector next to the logo lights I did order online that showed they would fit but didn't...
07-26-2019, 03:19 PM | #8 |
"Salud"
14050
Rep 4,692
07-26-2019, 04:21 PM | #9 |
Rep 2,529
07-26-2019, 04:31 PM | #11 |
"Salud"
14050
Rep 4,692
Thx. I had that part # and used it when I ordered a set off of eBay. But sadly. it did not fit. It does match up however with the same set I did install on my F0/750i.
There are definitely 2 types of connections. |
07-26-2019, 09:59 PM | #12 |
Rep 2,529
Are you sure you are getting them right?May be you need to flip the connector or something? Here is some pictures for you, I also took a pic of my original light connector.
07-27-2019, 12:20 AM | #13 |
Rep 1,354
Drives: 2022 X5 m50i
I ordered from Amazon as well. It is not directly plug and play but they had a pair of adaptor cables with metal ends to stick into the OEM cable plug/socket. I guess the OEM plastic plug has 4 holes and the adaptor cables first need to be plugged to the lights and then the metal cable ends of the cable need to be insterted into the OEM plug and they come on. It is not plug and play but it can be used with the attached adaptor. It is much cheaper than the OEM solution and you get what you paid for.
I bought 2 pairs of these for front and rear: https://www.amazon.com/Shadow-Projec...07Q7GG9BB?th=1
2022 BMW X5 m50i
2024 MB S63 on order '18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3 |
07-27-2019, 08:12 AM | #14 |
Rep 530
Drives: 2020 BMW X5 MSport Arctic Grey
I ordered several different sets...3 to be exact...i learned there are two dif connectors.
Best to just verify on the set you want to make sure they are the same, or, as stated above, have the adapter. The two I have are also different...so i have a big "X" on the front doors (these are OEM BMW), and then the back say "BMW X5" with the silhouette of the car. |
07-27-2019, 07:13 PM | #17 |
Rep 530
Also - if I remember correctly you have to specify 14+...and I think some of the listings showed the connector in a pic...
here are the non-oem ones... https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 The ones I got off Ebay I don't have as my order history was deleted... |
hlrzr19.50 |
07-28-2019, 09:38 AM | #18 |
1152
Rep 2,426
The OEM lights have metal heatsinks (LEDs get hot) whereas a lot of aftermarket ones are all plastic. Just something to be aware of and look out for.
07-28-2019, 03:26 PM | #19 |
Rep 33
I ordered my puddle lights from ebay and found these adapters in order work for my 2016 X5 - https://www.gobadges.com/led-door-li...e-adapters.htm
