09-25-2020, 01:54 PM | #1 |
Rep 104
BMW X5M Rear Air Suspension DIY
All,
Today i changed out my rear suspension, some pics and tips from my work. Step 1 Remove passenger side cover to access compressor. 9mm 10mm screws and fasteners. Step 2 Raise rear of car on jack stands, i used jack and wood block under rear diff. Step 3 Unplug compressor and lossen air lines blue and red use 10mm wrench, you should hear air leaking out. I didn't remove them completely to avoid dust entering the lines. Step 4: Unsnap bottom of air bag i used screw driver. Step 5: Twist air bag 1/4 and pull out, be careful of air line Step 6: Remove air line use 10mm wrench, remove cover but leave that in place with air line to reuse. When air line is off i would recommend cover it from dust. Step 7: Screw on air line to new air bag, cover, snap in line on air bag and 1/4 turn to insert in upper frame Step 8: Pull / push hard on air bag to snap in place on the bottom Step 9: Hook air lines back on compressor and plug power back to compressor, Reinstall front under cover. Step 10: I lowered car with jack until just below level, i started the car to give the compressor time to bring the car up then remove jack from diff. All Good! Last edited by Franktea1$; 09-25-2020 at 02:01 PM.. |
09-25-2020, 02:00 PM | #2 |
Rep 592
Drives: 2018 X5M , 14%E2%80%99640i ver
Nicely done, thanks
09-25-2020, 06:29 PM | #3 |
Rep 90
Pardon my ignorance but why not just unplug the fuse for the compressor?
2016 X5M DGM BM3 Stage 1 91
RK Autowerks Intake & RW Carbon parts |
09-27-2020, 09:08 AM | #5 | |
Rep 104
1. I thought about that but i figured for a DIY this was more reliable then someone pulling the wrong fuse. 2. One less step to do! Last edited by Franktea1$; 09-27-2020 at 09:17 AM.. |
09-27-2020, 03:40 PM | #6 |
Rep 90
Gotcha. I would rather remove the fuse than the cover and connector. Exterior connectors have burned me in the past with how brittle they can get.
09-27-2020, 07:54 PM | #7 |
Rep 30
Drives: 2013 BMW 335i SportLine
What year and how many miles? Trying to get an idea of when this usually needs to be done.
2013 Melbourne Red 335i SportLine, 2016 Glacier Silver Metallic X5 40e
09-27-2020, 09:32 PM | #8 |
Rep 185
09-27-2020, 09:48 PM | #9 |
Rep 30
Wow, must be based on time and not mileage. Wonder if dryer climates or colder climates contribute to the bags wearing out quicker. I guess I should prepare for it soon on our 2016 40e with 35k miles.
09-28-2020, 08:25 AM | #10 |
Rep 104
09-28-2020, 09:37 PM | #11 |
172
Rep 340
Drives: Several
Garage List 2004 Ferrari 360 Sp ... [0.00]
2015 Ford F150 Lari ... [0.00] 2015 Porsche GT3 [0.00] 2017 BMW X5M [0.00] 2020 BMW X7 M50i [0.00] |
Looks like mine is having the same issue at 38k. I’m still in warranty so I should be good. Are the newer parts more durable or should I just see this as a maintenance item going forward? Thanks for this great post.
2023 GMC Denali Ultimate
2021 Porsche Cayenne GTS 2019 Ford Raptor SuperCrew 2015 Porsche GT3 2004 Ferrari 360 Spider 6M |
09-29-2020, 09:00 AM | #12 | |
Rep 104
Thanks, Frank |
8202632172.00 |
09-30-2020, 03:22 PM | #14 |
Rep 15
Good information here. Dropped my 2017 X6M off yesterday and they replaced both air springs under OEM warranty. So it sound like this air spring suspension is only good for around 3 yrs. My driver side is 31-7/8” and the passenger side is 31-5/8. I complained about this and they replaced it but nothing change.
10-01-2020, 02:34 PM | #15 |
184
Rep 364
Drives: M2C X5M M4
I would say 1/4 of an inch is acceptable but if it's an issue for you I wouldn't have thought it would be caused by a leaking bag as the compressor would compensate. I would think it needs a calibration run where you input wheel size and distance from if I remember right the bottom of the rim vertically to the bottom of the arch if then recalculates and after a drive should be good. Also worth checking is the level sensor arms have a metal ball in the plastic sockets of the regulating rods and the balls can corrode and stick in the rod and give incorrect heights due to stiff movements even bending the plastic rods. (This may be a UK thing as it rains a lot so possibly more corrosion)
musa424.00 |
10-01-2020, 02:43 PM | #16 |
184
Rep 364
Drives: M2C X5M M4
To help with the bag install, I usually extend the bag an inch or two before putting in the pipe and hold it out the then tightening it will be a little more awkward to get in due to the length but it's squashy so should be ok. This reduces the issue that when you drop a massive heavy wheel on and it pulls down on the suspension arms the bottom tang can unclip unnoticed and then if it inflates will jump sideways and crack the plastic bottom.
As an aside, in the arnott bags packaging in UK there is an instruction manual that says under no circumstances must you unscrew the brass fitting, always eject the pipe cut it clean and reinsert. This is utter crap and only once did I do it this way and it was the only leak I've ever had therefore throw away the leaflet and listen to the op! I always hand tighten the brass nut into the bag a few turns which can be springy as the nut turns around the plastic pipe but eases after a few turns, the danger of using a spanner early is if they are a plastic thread in the bag the metal nut if not bang on will destroy the thread. |
10-16-2020, 12:30 PM | #18 |
Rep 104
05-04-2024, 09:47 PM | #20 | |
Rep 2,665
Drives: Goggomobil
As per the instructions, just inserted the air lines and pulled back to secure. Didn't force it. It has been great since and no issues in terms of leaks. This community is amazing in terms of sharing experiences with DIY. Definitely an amateur-level DIY but patience is required. The first bag took a long time to get out and secure back but the second was less than 10 minutes. There you go. Again, thank you for sharing your respective experiences. I think inserting a screwdriver and prying out the bottom tabs is the best solution.
F86 X6///
