10-16-2020, 11:22 PM | #1 |
Rep 804
coding soft touch turn signals
Hi I'm trying to code the soft touch blinker on bimmercode for my 15 x5 but I cannot find #3 in expert mode . Ive coded everything else that I wanted except this one.Any help appreciated.The cheat sheet said
1.BDC_BODY 2.3068 3.BLINKZYKLEN_ANZAHL_TIPP |
10-17-2020, 08:57 AM | #3 | |
232
Rep 337
PIA_DEFAULT_TIPPBLINKEN |
bmwchue242.00 |
10-17-2020, 10:06 AM | #4 |
Rep 804
10-17-2020, 10:59 AM | #5 |
Rep 101
I was able to code 5 blinks a while ago, but there was an update recently. wonder why programmer would take that off.. I really do like 5 blinks much better than 3
Current:
2015 F15 X5 35i MSport - BSM/Black - RC RS - BMS CP Past: 2002 E53 X5 3.0i Sports Pkg - Titanium Silver/Black |
10-17-2020, 11:09 AM | #6 |
147
Rep 334
Any software updates will erase any coding previously done. You will have to re code to get 5 blinks again.
10-17-2020, 11:34 AM | #8 |
232
Rep 337
10-17-2020, 11:36 AM | #9 | |
Rep 101
I might skip the update then, I just checked and there's an update available Don't think i'm going to do it !
Current:
10-17-2020, 08:54 PM | #10 | |
OEM CSL Whore
1255
Rep 1,476
10-17-2020, 09:39 PM | #12 |
232
Rep 337
Never tried bimmercode, as do all my coding with esys. But bimmercode users Use the same function names as I see in esys. That makes me think that they are the same. Just check the cheat sheet from the official coding thread and compare the functions with the ones you use with bimmercode
10-17-2020, 09:41 PM | #13 | |
232
Rep 337
PIA_DEFAULT_TIPPBLINKEN Saw several people asking for the blinker coding after update. That’s what I coded with esys for 5 blinkers |
10-18-2020, 10:23 AM | #15 | ||
Rep 804
10-18-2020, 10:37 AM | #16 |
232
Rep 337
10-19-2020, 07:37 PM | #18 |
1644
Rep 2,995
Weird. I was wondering if I could make it less like 2 flashes, which seems enough for switching lanes.
10-19-2020, 09:47 PM | #19 |
Rep 2,590
Seattlesquash915.50 |
10-21-2020, 12:08 PM | #21 | |
Rep 7,590
The OP mentioned they couldn't find BLINKZYKLEN...did you try using the search feature in Bimmercode? In the IOS version...you can type "blinkzyklen" in the search box when you've gone into the EXPERT MODE and go to the 3068 selections.
10-23-2020, 04:11 PM | #22 |
232
Rep 337
Just checked it, you found it right, the value should be 02 for five blinkers
