08-03-2021, 09:48 PM | #1 |
Rep 1,564
Something Every X5M owner should check every 80-100k miles.
Most F85/86's are well under 100K miles but I thought I would also post this here for future use and for the few that are or about to have their warranty expire:
The N63, S63, N63TU, and S63TU used in the E70, F15, & F85 are unique in that they all share the same oil pump and drive chain design up to the 2018 model year. Unlike the S63 & S63TU used in the M5, this chain drive does not have a tensioner so it is very likely and almost certain the drive chain will eventually become loose and is something that should be checked every 80-100K miles. I recently checked mine after reading some stories of engine failure and was lucky I did, it was more then 10 times out of spec and about to fall off. BMW made access to the oil pump and chain adjuster pretty straight forward. It will only add an extra hour or so to your normal oil change time. As a bonus, the lower pan gasket that is notorious for leaking as these engines age is replaced as part of the process. Below are instructions, parts and tools needed plus a short video on the adjustment procedure. Parts Needed (parts are the same for all engines and all platforms): (1) Lower Pan Gasket # 11137566808 https://www.fcpeuro.com/products/bmw...x5-11137566808 (25) Oil Pan Bolts # 07129909333 (you can save money and use Loctite 242 or other removable Loctite on old bolts) https://www.fcpeuro.com/products/bmw...mw-07129909333 (6) Reinforcement plate bolts (Do not reuse, these are one time use only) #33306772888 https://www.fcpeuro.com/products/bmw...er-33306772888 Gasket Tack: https://www.amazon.com/Permatex-8006.../dp/B000HBNV9E Tools Needed: Torque Wrench Torque Wrench Angle Gauge Cordless Ratchet (highly recommended, 31 bolts to remove and reinstall) 3/8" extensions 8mm long reach hex socket T45 Torx socket E10 External Torx socket 16mm Socket Instructions (short video below with more details on chain adjustment): 1 - Drive up on 4 ramps or jack up truck as level as possible. 2 - Drain Oil, Reinstall oil drain plug. 3 - Remove the Reinforcment plate. 4 - Remove Oil level sensor connector(Fig.1) 5- Remove the 25 E10 Torx bolts (Fig.2) holding on the lower engine pan (Fig.3). 6 - Remove the oil pump rear T45 torx bolt (Fig.2) 7 - Tighten chain adjuster using 8mm hex socket (see video for more info) 8 - Adjust to 10-12mm total (5-6mm side to side) chain movement. 9 - Reinstall Oil Pump T45 Torx bolt, tighten to 27Nm. 10 - Clean lower oil pan and Install new gasket, (ridged side faces towards engine), use gasket tack to keep in place. 11 - Replace 25 E10 Torx bolts with new or apply removable Loctite 242 to threads if reusing the old bolts and install lower pan. Tighten in standard crisscross pattern all bolts first to 10Nm, then 24Nm. 12 - Replace oil filter & refill oil. 13 - Install reinforcement plate and Tighten new bolts to 56Nm, then use Torque Angle Gauge and further tighten an additional 90 degrees. Last edited by Sophisticated Redneck; 08-03-2021 at 10:03 PM.. |
20
Violator4587.50 musa424.00 ajob463.50 Klienfeld303287.00 XRatedM138.50 Cbozz690.00 SaNGRia996.50 cncmastr1599.00 m3fuz199.00 slow_roll109.00 Autobacs1397.50 Logical212.50 m5james432.00 bad///Mechanic0.00 GotV8?1052.50 Slickrick2211.00 ArthurMorgan94.50 tfunk88204.00 Upurock47.00 CryptoHeff3.00 |
08-03-2021, 10:42 PM | #2 |
Rep 271
Good stuff! I just watched this teardown yesterday and was surprised to see the chain flopping around (30 minute and 53 second mark):
08-04-2021, 02:49 AM | #3 |
Rep 901
So thankful for your post! Are there signs/symptoms when this starts happening? I wonder if it could happen before 80k miles. This sounds like a preventative maintenance item that should be done at the earliest opportunity.
08-04-2021, 07:59 AM | #4 |
Rep 644
Interesting… just like a bike chain, chain stretch here is still a thing. Good to know and to watch for!
Klobb920.00 |
08-04-2021, 05:46 PM | #5 |
Rep 1,564
Thanks! Ya I think it was a flaw not to include a dynamic tensioner but wow that video kinda rips on these engines and that is the first gen N63, the S63TU in the in the F85 has variable valve lift and even more parts then previous gen, his mind would have melted...Yes they are complicated but I am at 171K miles original engine , and still knocking out 3.8 0-60 and low 12's in a near 10 year old 5500lb tank.....Can't complain.
Surgx572.50 |
08-04-2021, 05:54 PM | #6 | |
Rep 1,564
Possible it could happen before 80K, really depends on how the engine was assembled and how it was driven. The engine in the video had 171K miles on it so its a pretty extreme example, however my buddy did his F85 after seeing mine (he has 76K miles on his) and it was about halfway as loose as mine, probably not in danger of slipping off the sprocket but still out of spec buy quite a bit and he was glad he checked and adjusted it for peace of mind on a 20,000+ dollar engine. IMHO, it is definitely something to check if you just purchased a F85 with some serious miles on it or your warranty is about up. If it the chain were to slip off, you would have only a few seconds to shut down the engine before catastrophic engine damage occurs as the low oil pressure warning does not trigger until pressure drops below 7psi in all S63 engines. Last edited by Sophisticated Redneck; 08-04-2021 at 06:11 PM.. |
musa424.00 |
08-05-2021, 04:33 PM | #7 | |
Rep 1,234
Thank you
08-06-2021, 04:50 PM | #8 |
Rep 265
Thanks for this Sophisticated Redneck! I'm about to hit 90k miles on mine, will do it soon.
IG @E70_XRatedM | YT: E70M Garage
08-08-2021, 06:20 PM | #9 |
Rep 2,719
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
this is a no brainer on higher milage engines... $15 price of the gasket and an hour of your time is nothing compared to a new engine!!
08-08-2021, 07:03 PM | #10 |
Rep 1,353
Bro i am at 34k You made me worry. I really appreciate your time and effort to share this chronic issue. Thank You!
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 06-05-2023 at 12:16 AM.. |
08-08-2021, 07:32 PM | #11 |
Rep 7,586
All kind of fantastic info…thanks.
///MCollection183.50 |
08-25-2021, 11:49 AM | #12 |
Rep 1,564
Thanks to all for compliments, hopefully this will help someone on future save a engine. Some more data points would be great though so learn just how prevalent of a problem this is, so if anyone checks their oil pump chain, please report back here with what you find.
ajob463.50 |
08-25-2021, 07:27 PM | #13 |
172
Rep 340
Drives: Several
Garage List 2004 Ferrari 360 Sp ... [0.00]
2015 Ford F150 Lari ... [0.00] 2015 Porsche GT3 [0.00] 2017 BMW X5M [0.00] 2020 BMW X7 M50i [0.00] |
Great info. Gonna add this to the maintenence list. I've been noticing a slight metallic bearing like noise when at idle. Esp in a bank drive thru or fast food drive through. Is that a normal sound? Or could it be this issue in the thread? Or is a belt wheel/bearing going bad?
2017 43K miles
2023 GMC Denali Ultimate
2021 Porsche Cayenne GTS 2019 Ford Raptor SuperCrew 2015 Porsche GT3 2004 Ferrari 360 Spider 6M |
11-21-2021, 05:25 AM | #14 | |
Rep 178
11-21-2021, 07:40 AM | #15 |
224
Rep 379
11-21-2021, 06:48 PM | #16 |
Rep 178
11-22-2021, 07:08 PM | #18 |
Rep 1,038
12-01-2021, 11:49 PM | #20 |
Rep 2,719
Drives: M3
Ok I did it! I was changing my oil today and decided to take the pan off, I had the pan gasket. I also reused the pan bolts with loctite, I also reused the reinforcement bolts- I’ve taken that shield off a bunch of times always reusing the bolts and never had any issues.
Well after taking it all off I discovered a loose chain- not as loose as in OP video but pretty bad. Mind you I’m at 87k miles now. I ended up tightening the chain and cleaned up the oil pan.. One good tip for when you’re putting the pan back on with the gasket: Instead of using the gasket tack I used zip ties. Keeps it in perfect position and nothing will move it, no mess and simply cut off and slides out!! Here are some pics and videos! Before: And after:
12-02-2021, 03:23 AM | #21 | |
Rep 1,038
12-02-2021, 07:54 AM | #22 |
Rep 2,719
Drives: M3
It’s a skid plate plus it works as a stiffening tool for the chassis.
