10-04-2021, 10:23 AM | #1 |
Rep 53
New Owner - should B&O center speaker have wrinkles?
Hi,
Just received my new-to-me 2016 X5M. The B&O center speaker has wrinkles around it - is this normal? Or is there a protective film on it that should be removed? Thank you. |
10-04-2021, 11:01 AM | #3 |
Rep 1,235
Weird
Definitely a protective film or defect in the material. I would have a BMW dealer evaluate that.
10-04-2021, 11:09 AM | #4 |
Rep 53
10-04-2021, 11:10 AM | #5 |
Rep 271
Looks like my Elise's steering wheel where I left the windows closed in the garage during the winter and we had bursts of warm weather can causes condensation to form on everything.
10-04-2021, 11:52 AM | #6 |
Rep 53
10-04-2021, 01:21 PM | #7 |
184
Rep 308
Here is mine....I should dust the interior I also poked at it, doesnt seem that theres any film or anything on mine which could distort like that on mine
10-04-2021, 01:24 PM | #8 | |
Rep 53
Mine appears to look like yours - but with wrinkles, so most likely not a protective film. Wonder if I can gently heat it with a hair dryer and smooth it down with a card... |
10-04-2021, 01:37 PM | #9 |
184
Rep 308
I'd ask the dealer to take a quick look, personally im not sure how applying heat to the speaker would work out....if that maybe could deform or damage anything else in there.
10-04-2021, 02:19 PM | #10 |
199
Rep 363
Mine has a little bit of that wrinkling, but not to the extent your does. It’s annoying, but doesn’t appear to be impacting sound quality.
2017 X5 ///M
2019 X3 XDrive 30i 2003 Porsche C4S |
10-04-2021, 02:32 PM | #12 |
199
Rep 363
Same here
2017 X5 ///M
10-04-2021, 09:18 PM | #13 |
Rep 172
This post cannot be more timely - thank you OP. Mine is not as bad as some of the examples shown but I was wondering what would cause the issue as well. I’m was planning on asking my SA during my next trip to the dealership.
T4RUSAF49.50 |
10-04-2021, 09:33 PM | #14 |
Rep 53
10-04-2021, 10:09 PM | #16 |
Rep 872
This is an issue that occurs on the vehicles that use this speaker, such as the F10, F11, etc, where the cutout for the B&O speaker is "hand" cut....and in some cases, an over cut occurs too close to the defroster ventilation housing, letting excessive heat to escape directly onto the speaker assembly, essentially cooking the speaker itself.
Since the trimming/cut-back is done by hand, some dashboards are more prone to this issue than others. Dashboards are molded to support the standard H-K speaker configuration. You can test if your speaker is being "cooked" by running your windshield defrost, and after about 15 minutes, corresponding to maximum coolant temperature has been achieved, and if it's blistering hot, expect speaker delamination as shown by the O.P. Using the defroster will warm up the speaker on all dashboards, but the O.P.s speaker should be so hot that it will be uncomfortable after only a few seconds of touching the speaker because it is getting defrost air, at the same temperature as being applied directly to the windshield. I have pictures of grossly mis-cut dashboards for the center B&O speaker on another BMW forum...so if someone wants to see those, I can provide a link upon request. The dealership will not replace the dashboard. If this a problem for some of you, you can put thermal insulation in between the left vent housing and the speaker, and repeat for the right vent housing and the speaker, or use sealant...but sealant may also outgas on your windshield glass..and it's a pain to remove. Last edited by M_Bimmer; 10-04-2021 at 10:57 PM.. |
1230vani660.00 |
10-04-2021, 10:15 PM | #17 | |
Rep 53
I assume I'd have to remove the speaker to install the insulation? And I assume I'm SOL with regard to the finish delamination? |
10-04-2021, 10:16 PM | #18 |
Rep 872
Removal of the speaker on the F85 is easier than on the F10, since the windhield on the F85 provides incrementally better access to the two torx screws closest to the windshield.
Be careful removing the center speaker metal cover and the plastic black surround trim. There are metal tangs that "clasp" a post, and if you lift up one corner more than other corners, you will bend the tangs....the cover and trim are not sold separately, and the center speaker itself will be north of $600 on eBay, 2x from the dealership. If you get all 4 torx (T-20) screws out, your speaker may be stuck to the dashboard and may NOT lift out easily. Use a trim removal tool around the edge, and your speaker should lift out w/o issue. Last edited by M_Bimmer; 10-09-2021 at 07:35 PM.. |
10-04-2021, 10:25 PM | #19 | |
Rep 53
10-04-2021, 11:00 PM | #20 |
Rep 872
Hyperlink to the same issue over on the F10 ///M5 forum.....
https://f10.m5post.com/forums/showthread.php?t=1579907 You could buy the knock-off (hyper link in the thread above, post #7), and transfer your real speaker and electronic board over to the knockoff.....still pricey at $346.12..... |
10-05-2021, 06:19 AM | #21 | |
Rep 53
I'm a little unclear on the steps to remove the speaker. Pics would be greatly appreciated when/if you have time; just pointing out what's what. And, just wondering - has anyone had the defective speaker replaced by BMW? Last edited by 11earl; 10-05-2021 at 03:23 PM.. |
