02-23-2022, 12:36 PM | #1 |
Rep 29
Rod bearings change
Hello guys,
I’m wondering if i should prevent and change the rod bearings for my 2016 x5m. Do you know if that engine has commun issue with the RB or this is not necessary. Also when should i change the timing chain kit on that engine? Thank you very much for your help! |
02-23-2022, 05:58 PM | #2 | |
Rep 1,235
Not sure
For what it's worth... Following to learn as well. |
02-23-2022, 07:29 PM | #3 |
Rep 940
There have been some local S63s that have blown up. I just hit 50k and will be doing oil samples. Just sent one off last week. If it comes back questionable I will get them done.
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
9vapors653.50 Andresfe9810.50 |
02-24-2022, 04:49 PM | #4 |
Rep 60
is this "oil samples" done at a bmw dealership? I've been wondering whether or not to have mine changed.
02-24-2022, 04:54 PM | #5 | |
Rep 940
I'm going to see what they say, but when my aluminum gets to 10ppm or more I will have them changed. My local BMW race shop said it's around $4k out the door. My wife loves this car so we are going to keep for a while. $4k is a lot cheaper than $20k… https://www.blackstone-labs.com/
02-25-2022, 11:11 AM | #7 | |
457
Rep 353
You can always message a trusted engine builder, like RK Autowerke for example.
2016 BMW X5M F85 | 2019 - Present
2015 BMW X5 F15 5.0i m-sport | 2016-2019 2001 BMW X5 3.0i Sport | 2005 - 2008 |
9vapors653.50 |
02-28-2022, 03:20 PM | #8 |
Rep 940
Here is my first sample.
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ Last edited by sly1types; 02-28-2022 at 03:32 PM.. |
02-28-2022, 03:31 PM | #9 |
Rep 29
I have decided to change my rod bearings. i ordered the ACL rod bearings. i will do it by myself. if someone have some instructions about that, i will check the ISTA if is there something. i am looking for the oil pan and rod bolts torque specs. i couldn’t find anything yet on the internet about that. If you have any tips for me i will much appreciate. i will try to make as much as i can photos of the entire work, to maybe make a DIY. I also ordered new oil pan bolts and new rod bolts.
Thank you guys! |
Cbozz690.00 |
02-28-2022, 03:34 PM | #10 | |
Rep 940
02-28-2022, 03:40 PM | #11 |
Rep 29
I’m afraid to lose the engine that’s why i’m doing it. i found some very small metal shavings last week when i did the oil change. there wasn’t a lot but enough to make me not sleep well . the oil analysis are very difficult to do it in my country, i couldn’t find a company to do it (Luxembourg). But i think by changing them as a prevention, will not do anything bad.
sly1types431.50 |
03-01-2022, 11:42 AM | #12 |
Rep 940
I did send BlackStone a follow up email and they said some of the older models were lead and thought the newer ones are indeed aluminum/copper.
03-04-2022, 04:39 AM | #13 |
Rep 29
Could someone help me to understand the rod bolts torque table?
I can’t understand what should i choose 1AZ or 2AZ. when they say loosen screw 180• they mean to unscrew the bolt by 180 degrees? and the last loosen screw doesn’t says the degrees. Please someone help me to understand it. Thank you very much! |
03-04-2022, 04:15 PM | #14 |
Rep 870
@ Ionutz009,
To answer your question: Procedure 11 24, 1AZ torque procedure is if you are replacing the piston connecting rod AND using a new connecting rod bolt. Procedure 11 24, 2AZ torque procedure is if you are only using a new connecting rod bolt. Last edited by M_Bimmer; 03-04-2022 at 05:34 PM.. |
Ionutz0099.50 |
03-04-2022, 04:29 PM | #15 |
Rep 870
Mind sharing where you found a "new" S63B44B installed for $20K? (your comparison of $4k, which is inclusive of parts & labor, to $20K for a new engine, which should also include parts & labor, would be an apples-to-apples pricing comparison)
Even if this is just the "short" engine from BMW, $20K would still be a good price. Most would end up paying closer to $40K after all is said and done (all new hardware, seals and other misc parts, but mostly labor, and tax)......so your $4k (I assume includes labor, since parts only run $300-$400) of preventative maintenance on new main bearings, would be an even better deal...... |
03-04-2022, 04:31 PM | #16 | |
Rep 29
I couldn't find anything about rod bolts at 1111. Please see attached file. Thank you! |
03-04-2022, 04:41 PM | #17 | |
Rep 29
I can see that on the instruction page of replacing rod bearings they are using the same torque table for both plastigauge and final assembly. Also for the table at the 15th step there is no degrees for the loosen screw. Thank you very much for all your help! |
03-04-2022, 05:40 PM | #18 | |
Rep 870
I've got 9,890 miles on my S63B44B, and plan to do the bearing replacements shortly myself....will be pulling the bottom end to get the codes for the bearings....yes, it's ticking on the lower rear end. When you do yours, can you post pics of the old bearings? |
03-05-2022, 12:05 AM | #20 |
Rep 29
And if i let like that and after some miles my engine will break what i can do then? i will do it and we all can see if there is any issue on that engine, this is not to freak out someone but we already saw cases with rod bearings issues on this platform. Plus, i found metal shavings in the oil, no way i will take any risk to not doing it.
03-05-2022, 12:07 AM | #21 | |
Rep 29
03-05-2022, 07:08 AM | #22 | |
Rep 940
