10-11-2022, 09:22 PM | #1 |
Rep 93
Stuck coding DME - DME2_12_ETHERNET
Hey all,
I've got a 2014 x5 with 2021-07-550 software flashed to the DME. I had to have it Bench unlocked to install Bootmod3, however I am still unable to flash an older firmware to the DME. It seems a lot of people have encountered the: DME2_12_ETHERNET error while flashing, but I cannot find anyone with a solution. Am I doing something wrong? Any ideas how to program an older version of I-Level with esys to the DME? (bootmod3 tune isn't working with the newer firmware) Car hooked up to another running car to meet any charging requirements. Here is the results of a TAL execution using esys 3.40: Read SVT before TAL execution started. TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. <run()-> Value of 'httpServerActivation': true> <run()-> Value of 'isDeactivateHttp': false> <ExecutionID=2022/10/11-18:35:35.555> <[] prepareTALExecution started [PROGRESS]> <[] prepareTALExecution finished [PROGRESS]> <[] finalizeTALExecution started [PROGRESS]> <[] finalizeTALExecution finished [PROGRESS]> <TAL execution finished [TAL_EXECUTION_FINISHED]> TAL-Execution finished with status: "FinishedForHWTransactions". TAL execution finished. Duration: "16s". <> Read SVT after TAL execution started. Read SVT after TAL execution finished. <> Read SVT before TAL execution started. TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. <run()-> Value of 'httpServerActivation': true> <run()-> Value of 'isDeactivateHttp': false> <ExecutionID=2022/10/11-18:36:17.149> <[] prepareTALExecution started [PROGRESS]> <[] prepareTALExecution finished [PROGRESS]> <[] prepareVehicleForFlash started [PROGRESS]> <[] prepareVehicleForFlash finished [PROGRESS]> <[DME2 - 12] prepareECUforBLUpdate started [PROGRESS]> <[DME2 - 12] prepareECUforBLUpdate finished [PROGRESS]> <[DME2 - 12] authenticateECUforBLUpdate started [PROGRESS]> <[DME2 - 12] authenticateECUforBLUpdate finished [PROGRESS]> <[DME2 - 12 - btld_00001242-003_089_001] Transaction type: blFlash; Message: TA started [TRANSACTION]> <[DME2 - 12] performECUBLUpdate started with protocol UDS [PROGRESS]> <[DME2 - 12 - btld_00001242-003_089_001] Transaction type: blFlash; Message: 0% progress on ECUIdME2_0x12 [0% of btld_00001242-003_089_001] [TRANSACTION]> <[DME2 - 12 - btld_00001242-003_089_001] Transaction type: blFlash; Message: 1% progress on ECUIdME2_0x12 [87% of btld_00001242-003_089_001] [TRANSACTION]> <[DME2 - 12 - btld_00001242-003_089_001] Transaction type: blFlash; Message: 1% progress on ECUIdME2_0x12 [100% of btld_00001242-003_089_001] [TRANSACTION]> <[DME2 - 12] performECUBLUpdate finished with protocol UDS [PROGRESS]> <[DME2 - 12 - btld_00001242-003_089_001] Transaction type: blFlash; Message: TA finished [TRANSACTION]> <[DME2 - 12] installECUBL started [PROGRESS]> <MCDDiagService<id=43200, job=com.bmw.psdz.jobs.uds.MCD3_InstallECUBL, service=RC_CPD - RoutineControl CheckProgrammingDependencies, description=error: positive response with negative content, link=DME2_12_ETHERNET> [DIAGSERVICE]> <[DME2 - 12] installECUBL error [PROGRESS]> <[] job failed with negative response error: code: the programming dependencies are not correct description: MCD3_InstallECUBL failed - service RoutineControl CheckProgrammingDependencies delivered incorrectResultError_SWE_SWE; LinkName: DME2_12_ETHERNET severity: ERROR [THROWABLE]> <[DME2 - 12] There was an error during TAL execution, please check the log files. [WARN]> <[DME2 - 12] - [Exception - DME2 - 12] job failed with negative response error: code: the programming dependencies are not correct description: MCD3_InstallECUBL failed - service RoutineControl CheckProgrammingDependencies delivered incorrectResultError_SWE_SWE; LinkName: DME2_12_ETHERNET severity: ERROR > <[DME2 - 13] prepareECUforBLUpdate started [PROGRESS]> <[DME2 - 13] prepareECUforBLUpdate finished [PROGRESS]> <[DME2 - 13] authenticateECUforBLUpdate started [PROGRESS]> <[DME2 - 13] authenticateECUforBLUpdate finished [PROGRESS]> <[DME2 - 13 - btld_00001242-003_089_001] Transaction type: blFlash; Message: TA started [TRANSACTION]> <[DME2 - 13] performECUBLUpdate started with protocol UDS [PROGRESS]> <[DME2 - 13 - btld_00001242-003_089_001] Transaction type: blFlash; Message: 0% progress on ECUIdME2_0x13 [0% of btld_00001242-003_089_001] [TRANSACTION]> <[DME2 - 13 - btld_00001242-003_089_001] Transaction type: blFlash; Message: 1% progress on ECUIdME2_0x13 [98% of btld_00001242-003_089_001] [TRANSACTION]> <[DME2 - 13 - btld_00001242-003_089_001] Transaction type: blFlash; Message: 1% progress on ECUIdME2_0x13 [100% of btld_00001242-003_089_001] [TRANSACTION]> <[DME2 - 13] performECUBLUpdate finished with protocol UDS [PROGRESS]> <[DME2 - 13 - btld_00001242-003_089_001] Transaction type: blFlash; Message: TA finished [TRANSACTION]> <[DME2 - 13] installECUBL started [PROGRESS]> <MCDDiagService<id=43200, job=com.bmw.psdz.jobs.uds.MCD3_InstallECUBL, service=RC_CPD - RoutineControl CheckProgrammingDependencies, description=error: positive response with negative content, link=DME2_13_ETHERNET> [DIAGSERVICE]> <[DME2 - 13] installECUBL error [PROGRESS]> <[] job failed with negative response error: code: the programming dependencies are not correct description: MCD3_InstallECUBL failed - service RoutineControl CheckProgrammingDependencies delivered incorrectResultError_SWE_SWE; LinkName: DME2_13_ETHERNET severity: ERROR [THROWABLE]> <[DME2 - 13] There was an error during TAL execution, please check the log files. [WARN]> <[DME2 - 13] - [Exception - DME2 - 13] job failed with negative response error: code: the programming dependencies are not correct description: MCD3_InstallECUBL failed - service RoutineControl CheckProgrammingDependencies delivered incorrectResultError_SWE_SWE; LinkName: DME2_13_ETHERNET severity: ERROR > <[] finalizeVehicleFlash started [PROGRESS]> <[] finalizeVehicleFlash finished [PROGRESS]> <[] prepareVehicleForCoding started [PROGRESS]> <[] prepareVehicleForCoding finished [PROGRESS]> <[] finalizeVehicleCoding started [PROGRESS]> <[] finalizeVehicleCoding finished [PROGRESS]> <[] finalizeTALExecution started [PROGRESS]> <[] finalizeTALExecution finished [PROGRESS]> <TAL execution finished [TAL_EXECUTION_FINISHED]> TAL-Execution finished with status: "FinishedWithError". TAL execution finished. Duration: "1min 4s". <> Read SVT after TAL execution started. Read SVT after TAL execution finished. |
Tags |
dme, dme2_12_ethernet, flash, i-level |
