      10-26-2022, 08:55 PM   #1
lizzzzie
Drives: BMW 2014 x5
2014 '14 X5 Retractable Cargo / Trunk Cover
I am trying to install the retractable trunk / cargo cover.
Either the left side or the right side will lock into place. I cannot get both sides to lock, so when I pull the retractable cover one side is moving forward.
What am I doing wrong? Is there a trick to get the cargo cover installed or in the "lock" positions on both sides?
This is my first BWM and a new car for me. Trying to figure it all out.
TIA
      10-27-2022, 09:57 AM   #2
Qsilver7
Qsilver7's Avatar
I believe there are instructions in the owners manual. If you don't have the paperback version...there is an owners manual embedded in iDrive.
There's also a great search feature in the iDrive manual, as well...and there are multiple ways to search.
From memory, I believe you just slide the "cassette" back into the catches on both side and press it in on the right side and you should here it click into place. I usually give the left side a little bit more preference (first)...then end up pressing the right side until I hear the click.
EDIT: yep..here's the instructions from the owners manual
      10-27-2022, 11:06 AM   #3
lizzzzie
Drives: BMW 2014 x5
Thank you!
Thank you, Qsilver7! I'll check it out.
      10-27-2022, 07:12 PM   #4
Qsilver7
Qsilver7's Avatar
Hopefully you have the correct cargo cover cassette and you get the hang of how to latch it back in place..
