11-03-2022, 10:48 AM | #1 |
Rep 144
Failed catalytic converter theft
So I go to the store yesterday after work, then hit Chipotle on the way in. I see what looks to be maybe a branch stuck under my car from a distance, then as I got closer I see someone had pried my undercarriage panels trying to steal my catalytic converter. Didn't get close, but did probably a couple hundred dollars worth of damage. Because of where it is actually located you would think X5's aren't targeted for cat thefts but someone did try. Anyone else have this happen?
11-04-2022, 03:41 AM | #3 |
Rep 552
It's picked up here in Florida too. But no, not happened (knock on wood).
11-04-2022, 09:15 AM | #4 |
Rep 666
In Houston if you drive any Toyota truck, you better make sure the stops you make lasts less than 2 minutes because from the moment you enter a store, these cat-pervs can get in and out from under within 2 minutes.
At my work facility, two our our workers' trucks got their cats cut. And all we can see on camera were shadowy guys under the truck and within 2 mins, they were able to pull out with the loot. Also, any worktruck in this area will get their windows smashed in for tool bags and etc. Safety is a great concern these days. As economy gets worse and prices soar, people are getting desperate. And here we're seeing the whole country cutting funds to the Police force. The new policies are just going backwards, how did we vote our representation to get this far?
11-04-2022, 10:18 AM | #5 |
Ground Clearance?
235
Rep 1,654
alot of times with BMWs theyll take off with the resonators (which look like cats on some models) but our X5s dont even have resonators so they just end up out of luck.
E90 330i - E90 335i - E92 335i |
11-04-2022, 11:55 AM | #6 |
Rep 666
You're absolutely right? Our cats are located well within the engine bat at the bottom and having that flex plate right under the engine bay definitely deters any real effort trying to take the cat off. Good luck to these thieves when they get to our cars. I hope they get their knuckles busted and their arms burned for trying.
Surgx572.50 |
11-09-2022, 06:05 AM | #9 | |
Rep 2,667
https://www.houstonpublicmedia.org/a...-plug-deficit/ |
11-09-2022, 12:40 PM | #10 | |
Rep 666
I may be wrong with my info because I'm pulling this info from my head and it's all coming from the radio I listen to from my daily commute to and from work. 30 minutes on the road and listening to radio gets me to believe everything I'm saying has some basis. I surely had no idea the budget is actually been increased for HPD. But I gotta say, even with this budget increase, Houston's crime has been on a rampant rise. I work in the East Downtown area and just on my work premises, we've gotten theft twice and a catalytic converter incidence once on this year alone. Building across the street has their contractors' work truck broken into to steal a tool bag, twice, this year. I also often run errands for tooling and parts, at Northern Tools, I've arrived twice at their parking lot, observing some pissed off customers calling for HPD because their window got smashed into; I didn't budd into those incidences so I don't know what valuables were stolen. Those are late last year. I'm only traversing the area a little bit, and seeing some theft incidents is considered quite frequent for me. Before COVID times, I've almost never heard of any incidents. I feel criminals are becoming more, and they are desperate these days. So it leads me to think that our Police budget isn't sufficient enough to keep the place safe. I get to go home to a very nice suburb neighborhood, despite the danger I see around work. Houston is quickly changing, and a lot of run-down places are being leveled and rebuilt into something new. So I hope this movement will slowly drive crime out and upgrade the area. BTW, Houston Astro's just won the Championship. And yesterday we've had a huge parade going on. And this morning, also on the radio, we're hearing that hundreds of Toyoto's, specifically Tundra models got their Catalytic Converters cut in a one-day parking lot run. Tons of people came downtown yesterday, so within a certain radius we park our cars. I guess they just go cherry-pickin and the loot is quite good.
11-09-2022, 08:37 PM | #11 | ||
Rep 2,667
https://abc13.com/houston-crime-rate...rder/12184070/ All I am saying is that it is getting easier to get people to believe anything these days, even if getting to the facts is easier than ever. |
yupetc398.50 |
11-10-2022, 10:58 AM | #12 | |
Rep 666
11-10-2022, 12:21 PM | #13 | |
Rep 670
At the bottom of that provided link, there is another story stating that Homicide is up over previous year. Click for link The same news outlet stating 10% reduction in violent crimes, is also reporting and increase in homicides, i.e., a violent crime. "According to Houston police, there have been 279 homicides in Houston in 2022. This time in 2021, there were 267 homicides. In 2020, that number was 205." |
11-10-2022, 01:19 PM | #14 | |
Rep 2,667
Pew research is a reasonable non partisan source. https://www.pewresearch.org/fact-tan...%20months%20of |
11-10-2022, 02:59 PM | #15 | |
Rep 670
For Pew, they are referencing crime data based on a Federal Survey....If you skip Pew and go to the FBI and view their National Incident-Based Reporting, you will find that they themselves admit that their data is not complete because it requires the participation of cities to report. Many cites don't disclose for various reasons including for politics (don't make our state look bad). ON TOPIC: I think there are multiple factors feeding the thirst for CAT theft (economy, police enforcement, theft classification, precocious metal content, buyers not requiring proof of title etc.). It's a shame and very peculiar that suddenly CATs, which have been around for decades, are suddenly fashionable to steal.... |
11-11-2022, 08:46 AM | #16 | ||
Rep 2,667
1. The data is all over the place and people can use any data that suits their narrative when it comes to crime. 2. Some data like funding levels for police is easier to verify. 3. So, when someone claims that crime is going up because funding is going down. One can verify if the funding is actually going down. The data I posted for Houston showed that funding went up in 2022 driven by Federal funding for law enforcement. I was not making a political argument. I was just stating the facts that can be verified. How did you infer that I said that reducing police funding is leading to reduced crime? I never made that claim. You are trying to say something I did not say to discredit what I was actually saying. Not sure if that was deliberate or ignorance. |
11-11-2022, 09:52 AM | #17 | ||
Rep 670
Which brings us back to what I said - I'm not sure how one could defend that decreasing police budgets has no impact on crime surge or somehow equates to less crime. |
11-11-2022, 10:35 AM | #18 | |
Rep 630
11-11-2022, 10:44 AM | #19 |
Rep 670
100% - Some states are "repurposing" their budgets for other initiatives as well.
11-11-2022, 10:56 AM | #20 | |||
Rep 2,667
So, crime going up (which may or may not be the case) wasn't because budgets were being cut. How is this confusing if you read the thread? You seem to be latching on to a political point of view or something. That makes you happy. Go for it! |
11-11-2022, 11:46 AM | #21 | |
Rep 670
I will say again, that is a very difficult argument to defend. |
11-11-2022, 01:11 PM | #22 |
Rep 666
Let's cut the arguments here. We all meant well. We should steer our replies to align with the OP's topic. Anyways, the fact of the matter is that CAT thieving is becoming rampant. It brings the nostalgic 80's and 90's back in my mind when stealing car radios was the fashionable to-do for those kiniving thieves.
Surgx572.50 |
