      11-03-2022, 01:31 PM   #1
ErikV55
ErikV55's Avatar
18
Drives: 2017 X5 xDrive35i M Sport
panel gap between A pillars and fenders, normal?
Just noticed this today. Anyone else with f15 x5 have the same?
      11-04-2022, 09:19 AM   #2
yupetc
Drives: 2015 X535i
Don't know what your issue is. Those look fine to me. If you really want to pick a fight about gap in panels, go to your nearest parking lot and start paying attention to them Tesla's. After you check theirs out, you'll think BMW's gaps are superb.
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP
2017 540i - MHD2+, VRSF DP, TU Pump
      11-04-2022, 09:24 AM   #3
lonestar22
Ground Clearance?
lonestar22's Avatar
Drives: 540i & X5
there has to be something else for you to worry about other than this.
E90 330i - E90 335i - E92 335i
      11-04-2022, 12:11 PM   #4
ErikV55
ErikV55's Avatar
18
The piece from the fender is sticking out, like it's too far away from the car.
      11-04-2022, 01:23 PM   #5
yupetc
Drives: 2015 X535i
Couldn't really tell from the way your picture shows. But those fenders are made of fiberglass or some ABS variant. They are not metal. And they are secured by some M6 or M8 screws from multiple different locations. If this car's not been wrecked before, you probably can look for those screws and re-push and screw them again to get that protrusion down. I know this because I had to change out the windshield fluid reservoir and had to take the entire fender panel off. And I followed the original exact screw location to put everything back on, everything's flush. Best luck, buddy.
      11-05-2022, 10:57 PM   #6
ErikV55
ErikV55's Avatar
18
Thanks, I took it to re reputable body shop for their opinion and they said it just kinda varies on the X5s they've worked on. They checked the alignment of the panel etc. so leaving it for now.
      11-06-2022, 08:03 AM   #7
2008bimmerM3
2008bimmerM3's Avatar
51
Drives: JB
bmw are notorious for gaps, buy mercedes to be gap free
      11-07-2022, 01:24 AM   #8
tlow98
Drives: 2009 E91, 2014 F15 x35i
Ours doesn’t look like this at all. Weird.
      11-07-2022, 05:25 PM   #9
BlackBeans
BlackBeans's Avatar
75
Drives: E90 M3 | F15 X5 50i
Mine look kinda like that too. It's fine
