02-11-2023, 01:30 AM | #1 |
Rep 2
weird water leak that ruined tailgate module, from the gas cap water drain hole.
Hey Bimmer Gang,
I have an odd one. The hole in the gas cap area, that’s meant to drain water, is quite literally flooding the truck of my x5. It’s ruined my tailgate module and I just replaced it, but didn’t install it yet as if I go to a car wash, it would just get wet again. When I finally discovered it was wet, it was 8 inches up water flooded. I can’t seem to find where this hole leads to. Has anyone had this problem before? Any advise to fix? I tested and confirmed that it is in fact this hole. |
02-11-2023, 01:52 AM | #2 |
Rep 5,025
This also happens on BMWs from the rear brake light seal area.
So, when you pour water in the hole, it comes in the car? It’s crazy they routed that through the car. Ugh. |
02-12-2023, 02:45 AM | #4 |
Rep 105
I also noticed that during heavy rains, when I open either the driver or passenger door, water seems to fall out. luckily I haven't seen any water inside the car, it seems like it's just gets stuck under the door. not sure it that is normal or not.
02-12-2023, 02:47 AM | #5 | |
Rep 2
I tired looking for a diagram but couldn’t find anything. |
02-12-2023, 04:20 AM | #6 | |
Rep 1,038
You may need to remove the wheel liner to see if and what is going where. It's held in by plastic clips, but some of them are the BMW FU style where they are one use only. Last edited by Chilled; 02-12-2023 at 04:26 AM.. |
02-12-2023, 02:52 PM | #7 | |
Rep 672
I'm not doubting your test confirmation, but I certainly would not stop your search there. Several other threads here have tracked the source of water entry elsewhere. For example click then see post #8 found the issue was further up along the rear sunroof drain holes. |
