06-07-2023, 08:55 AM | #1 |
Rep 144
Eibach Pro Kit on Non-Air Suspension F15 X5
About a month ago I had the Eibach Pro Kit installed on my 2017 X5 35i (without Air Suspension) and I wanted to share my progress/experience with the forum.
During my period of research prior to deciding to go with Eibach, I found an abundance of posts related to X5's with the rear Air Suspension, but a very low amount of posts specific to those X5's without the rear Air Suspension. For those unaware, usage of the Eibach Pro Kit differs based on the presence (or lack thereof) of the rear Air Suspension, thus the reasoning behind this post. For X5's with rear Air Suspension, the front springs from the Eibach Pro Kit can be used to lower the front ONLY, however in order to accomplish lowering for the rear, you would need to source adjustable lowering end links not included in the Eibach Pro Kit. If you aren't sure whether your X5 has Air Suspension or not, F15 X5's with the optional third row of seating have the rear Air Suspension while the Two Row (non 'M' spec) variants do not, unless spec'd with Air Suspension when originally ordered from the factory. In order to truly check, decoding your VIN is your best bet. For X5's without rear Air Suspension, the Eibach Pro Kit consists of two pairs of lowering springs. One for the front and one of the rear. My 2017 X5 without Air Suspension had the Eibach Pro Kit installed on May 10th and the following replies contain progress updates over a 1-month time period. My hope for this post is that it will serve as a reference for any F15 owner without Air Suspension that is considering the Eibach Pro Kit as a means of achieving a mild drop. Prior to Install View post on imgur.com Prior to install, my stock ride height on 19 inch Conti Run Flats was as follows: Front: 32 inches (Ground to Fender) View post on imgur.com Rear: 32.5 inches (Ground to Fender) View post on imgur.com Immediately Following Install View post on imgur.com Immediately following install, my ride height on 19 inch Conti Run Flats was as follows: Front: 31.5 inches (Ground to Fender) View post on imgur.com Rear: 32 inches (Ground to Fender) View post on imgur.com Post Install Impressions Ride is slightly different. It's hard to put my finger on, but it feels like the amount of body roll has been decreased and that there isn't as much bounce and "float" to the ride. Last edited by destroy26; 06-07-2023 at 02:45 PM.. Reason: Additional info |
06-07-2023, 08:56 AM | #2 |
Rep 144
1 Week Post Install
After 1 week on the new springs I can confidently say that I prefer the ride on Eibachs to the stock springs.
One Week Post Install View post on imgur.com One week following install, my stock ride height on 19 inch Conti Run Flats was as follows: Front: 31.25 inches (Ground to Fender) View post on imgur.com Rear: 31.5 inches (Ground to Fender) View post on imgur.com Last edited by destroy26; 06-07-2023 at 10:06 AM.. |
06-07-2023, 08:58 AM | #3 |
Rep 144
1 Month Post Install
My initial intent was to take pictures and measurements immediately following install, as well as the "2 week" and "1 month" intervals, however the "2 week" measurements were almost exactly similar to the "1 week" measurement. As a result, I decided to re-measure at the "1 month post install" interval.
1 Month Following Install View post on imgur.com 1 month following install, my stock ride height on 19 inch Conti Run Flats was as follows: Front: 31.25 inches (Ground to Fender) View post on imgur.com Rear: 31 inches (Ground to Fender) View post on imgur.com Last edited by destroy26; 06-07-2023 at 10:18 AM.. |
Edwardsc1255.50 |
06-07-2023, 10:22 AM | #4 |
Rep 144
Summary
After over a month on the Eibach Pro Kit, I absolutely prefer the look and ride to the OEM springs, with the side profile of the vehicle finally looking the way it should have looked stock from the factory.
Next "steps" for me are to get the front two windows tinted to match the rear, as well as to ditch the stock run flat tires in favor of Conti Extreme Contact DSW 06's. Hope this post helps those of you out there looking for reference materials while considering moving away from the OEM springs. Happy to share any additional info as needed. |
06-07-2023, 12:24 PM | #5 | ||
Rep 3,658
06-07-2023, 01:49 PM | #7 |
Rep 210
Drives: 2015 BMW X5 50i
This is great, I've been looking at this kit for a few months now but haven't pulled the trigger yet. I was just measuring my ride height last week and looking at comparisons. This is just what I needed, great write up!
2015 X5 50i - Current
2011 E92 M3 - Sold 2016 F30 340i - Sold |
destroy26168.00 |
06-07-2023, 02:12 PM | #8 |
172
Rep 301
I installed the same springs last month but didn't get the same amount of drop as OP. My car had 60K on it so maybe there was already sag in the OEM springs.
Ride quality is pretty much the same. I only noticed a difference when hitting the speed bumps in my neighborhood. |
destroy26168.00 |
06-07-2023, 02:34 PM | #11 |
Rep 144
Honestly two reasons:
1) Eibach has a good reputation of being a "moderate" drop that (depending on who you ask) either improves ride quality or doesn't affect it too much, as opposed to sacrificing ride quality for aesthetics (eg: a lower drop). 2) Keeping my first point in mind, my wife gets carsick incredibly easily. I would have loved to get just a touch more aggressive with the drop but didn't want to have ride quality (or my wife) suffer for aesthetic purposes lol. Last edited by destroy26; 06-07-2023 at 02:47 PM.. |
meds1976114.50 |
06-07-2023, 02:36 PM | #12 | |
Rep 144
What size wheels are you running? |
06-07-2023, 02:40 PM | #13 | |
Rep 144
06-07-2023, 04:49 PM | #14 | |
Rep 240
Drives: F16 X6 M50i
destroy26168.00 |
06-07-2023, 04:59 PM | #15 | |
Rep 144
I really wanted to go the muffler delete route and (wisely) thought to have her listen to an example of what that sounded like prior to doing so. Ended up being a hard "no" lol |
meds1976114.50 |
06-08-2023, 04:22 AM | #16 |
172
Rep 301
I'm on aftermarket wheels with tire sizes that are "wrong" for the car. I wasn't comparing your actual ride height measurements with mine, just the amount of drop vs stock. Right after changing them with the car having done no miles, there was no difference at all. After about 150 miles I got .5 inch in the front and nothing in the back. The car has been parked for about 5 weeks since then. I will do another 200 miles next week then measure again.
destroy26168.00 |
06-08-2023, 08:37 AM | #17 | |
Rep 144
Hope it settles more for you! |
06-08-2023, 01:13 PM | #18 |
172
Rep 301
My wheels are 20x10.5 with 315/35 on all four corners. I don't remember the offset off the top of my head, but I have 15mm F and 20mm R spacers on also which will change offset drastically.
I hope it drops some more as I don't plan on ever changing springs again. The rears were a nightmare to get in. The fronts were a breeze. |
destroy26168.00 |
06-08-2023, 01:14 PM | #19 |
Rep 144
