      10-11-2023, 09:57 PM   #1
razdan
Drives: X5 F15
2015 BMW x5  [0.00]
Post 2015 X5 35d Coolant codes
I have a 2015 X5 35d
I have had plenty of work done to the car but need help getting rid of some codes.
I have replaced the drive belt after it ripped.
The pully, gaskets around the engine.
Replaced the oil cooler gaskets, and intake manifold gaskets.
I had a coolant leak for a bit before it was fixed, not sure this could of caused any of the coolant leaks.
I have the EGR recall work done on it twice.
Here are the 4 codes that come back and I do not know where to start with the work.
241F00 Preheat Control Unit: Output stage cylinder 1 faulty
290B00 Air mass system measured air mass too low
2B5400 Coolant Pump, low-temperature EGR, activation: open circuit
2C3100 Auxiliary Coolant pump for low-temperature EGR: Does not respond.
I found the air mass system measured air mass too low about a vacuum leak has something to do when I took off the intake manifold and will inspect it.
      10-25-2023, 08:07 PM   #2
XxBBVTMxX
XxBBVTMxX's Avatar
-this sounds like the unit that controls your glow plugs might be faulty, or a bad glow plug in that cylinder….
-You Tube smoke test, you might have a leak somewhere you need to find. There’s also a sensor for that to the back of your intake manifold. Look it up on “RealOEM”. Could be your valve cover seal needs replacement. Is there oil somewhere on the engine?
-look up EGR Temperature sensor…
-https://f10.5post.com/forums/showthread.php?t=1544283
