04-15-2024, 01:44 AM | #1 |
Rep 1
Rear turn signal fuse location
Hi.
My left rear (LED) turn signal har stopped working. My brakesignal (in the same fixture) is fine. Where is the fuse located? I'm just trying to find out if i need to change the whole light-fixture. |
04-15-2024, 05:47 AM | #2 |
Rep 33
I don't see fuses for the turn signals
https://fuse-box.info/bmw/bmw-x5-f15...uses-and-relay I think they may be powered by the BDC (Body Domain Controller) module or a lighting module. You'll probably need to figure out which wire on the taillight connector the turn signal is, check for voltage on it and take it from there. |
04-15-2024, 04:27 PM | #3 |
Rep 7,588
Ditto above...the lights are under the control of the BDC module (A258).
