04-30-2024, 10:59 AM | #1 |
Rep 4
Surround view cameras, not Showing after retrofit NBT to evo
Hi, thank you for the opportunity. I have a little understanding about coding and retrofit. My issue is that I have a Bmw X5- f15. And I was trying to get the 4g working. So I went on eBay and bought an atm module and a nbt evo. After I installed them along with the rest of the necessary wiring harness. I had it coded.
Everything is working BUT cameras, none of my 4 original cameras work with the evo. The seller said that they coding is right that it must be a wiring issue because I have an android screen, but when I switch back to the original nbt and the cameras work. I’m wondering if anybody can help me. Maybe they used the wrong codes. I really, really need help please. I attached a picture of what comes out now when I reverse or try the surround view. |
04-30-2024, 11:17 AM | #2 |
Rep 2,528
Looks like a bad wiring/wrong harness/incorrect pin out put. Something similar to this:
https://cartechnology.co.uk/showthre...d=60550&page=2 Is you rearview camera working? I see it is not checked. |
05-04-2024, 12:33 PM | #4 |
Rep 4
Thank you for replying. I checked the link and I will change the quadlock. If you have a link for which one to buy for a BMW x5,f15 with 5 cameras. I’ll let you know if it works. Thank you, thank you.
